问题:本项目同时开启了两个外部中断,其一,GPS模块1PPS引脚输出到单片机PA4引脚,先初始化,但始终不能进入中断;其二,BL8025模块中断输出链接单片机PC13,后初始化,可正常执行;
{ GPIO_InitTypeDef GPIO_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); /* Enable SYSCFG clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Connect EXTI13 Line to PC13 pin */ SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource13); // EXTI_DeInit(); EXTI_InitStructure.EXTI_Line = EXTI_Line13; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); }
{ GPIO_InitTypeDef GPIO_InitStructure; //¶¨ÒåÏà¹Ø½á¹¹Ìå EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; //ÍⲿÖжϻ½ÐÑ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//ÉèΪÊäÈë GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;// GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Enable SYSCFG clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Connect EXTI13 Line to PC13 pin */ SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource4); EXTI_DeInit(); EXTI_InitStructure.EXTI_Line = EXTI_Line4; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } 解决问题思路: 1.硬件方面:用示波器测量GPS模块1pps引脚是否有波形输出和高电平电压值,经过测试没问题; 2.软件方面:去掉除开PA4外部中断配置其他设置,在PA4外部中断函数中加入串口打印,经过测试可以执行;然后,再逐一打开其他配置,直到打开BL8025配置,首次遇到,不能执行中断;然后再对BL8025配置段落逐一关闭设置,发现问题在EXTI_DeInit(),再深入了解,发现本句话含义是,清楚外部中断之前配置;而BL8025模块配置PC13外部中断的时候,后执行,把之前配置PA4相关信息重新置零了;***********记录下********** 3. plan b方案是,在调试模式,查看外部中断寄存器配置,逐一比对; |
1780 浏览 1 评论
1621 浏览 1 评论
1081 浏览 2 评论
728 浏览 2 评论
1679 浏览 2 评论
1938浏览 9评论
732浏览 4评论
570浏览 3评论
596浏览 3评论
557浏览 3评论
GMT+8, 2024-12-24 07:28 , Processed in 0.861692 second(s), Total 76, Slave 60 queries .
