设置Timer3 中断
void TIM3_INT_Config(void) { NVIC_InitTypeDef NVIC_InitStructure; /* TIM3 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); /* TIM3 ÖжÏǶÌ×Éè¼Æ*/ NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } 设置Timer3 模式 void TIM3_OUT_Config(void) { TIM_TimeBaseInitTypeDef TIM3_TimeBaseStructure; TIM_OCInitTypeDef TIM3_OCInitStructure; /* ¼ÆËãÔ¤·ÖƵֵ */ TM3_PrescalerValue = (uint16_t) (SystemCoreClock / TM3_PRESCALER) - 1; /* Time ¶¨Ê±Æ÷»ù´¡ÉèÖà */ TIM3_TimeBaseStructure.TIM_Period = 65535; TIM3_TimeBaseStructure.TIM_Prescaler = 0; TIM3_TimeBaseStructure.TIM_ClockDivision = 0; TIM3_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM3, &TIM3_TimeBaseStructure); /* Ô¤·ÖƵÆ÷ÅäÖà */ TIM_PrescalerConfig(TIM3, TM3_PrescalerValue, TIM_PSCReloadMode_Immediate); /* Êä³ö±È½ÏʱÐòģʽÅäÖÃÉèÖà */ TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing; TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; /* Êä³ö±È½ÏʱÐòģʽÅäÖÃ: ƵµÀ3*/ TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM3_OCInitStructure.TIM_Pulse = TM3_CCR1_Val; //3000 TIM_OC3Init(TIM3, &TIM3_OCInitStructure); TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Disable); /* TIM ÖжÏʹÄÜ */ TIM_ITConfig(TIM3, TIM_IT_CC3 , ENABLE); /* TIM3 ʹÄÜ */ TIM_Cmd(TIM3, ENABLE); } 3. 中断子程序 void TIM3_IRQHandler(void) { if (TIM_GetITStatus(TIM3, TIM_IT_CC3) != RESET) { TIM_ClearITPendingBit(TIM3, TIM_IT_CC3); /* LED3 toggling with frequency = 219.7 Hz */ // LED1_Toggle(); // capture3 = TIM_GetCapture3(TIM3); // TIM_SetCompare3(TIM3, capture3 + TM3_CCR1_Val); OutToggle(); if(TimeRxFlag) { TimeInterval++; if(TimeInterval》4) { RxFrameEndFlag =1; } } if(KeyCtrl.bDebunceTime != 0) { KeyCtrl.bDebunceTime--; } // SevenSegShow(DispBuffer); capture3 = TIM_GetCapture3(TIM3); TIM_SetCompare3(TIM3, capture3 + TM3_CCR1_Val); } } |
2574 浏览 1 评论
1977 浏览 1 评论
1512 浏览 2 评论
993 浏览 2 评论
3213 浏览 2 评论
1361浏览 4评论
585浏览 3评论
856浏览 3评论
808浏览 3评论
859浏览 3评论
GMT+8, 2025-7-12 09:47 , Processed in 0.764234 second(s), Total 76, Slave 60 queries .
