STM32F4定时器5 中断异常进不去问题
出现问题现象: 用定时器5来发脉冲,有时候当指令发送后,定时器不发脉冲,debug时发现程序执行到打开定时器5后,进不去中断,之后就一直进不去中断,才导致发不了脉冲。 定时器5配置代码如下: void TIM5_PWM_Init(u32 arr,u32 psc) { NVIC_InitTypeDef NVIC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5,ENABLE); //TIM5时钟使能 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); //使能PORTF时钟 GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_TIM5); //GPIOA3复用为定时5 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; //GPIOA3 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //复用功能 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉 GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA3 TIM_TimeBaseStructure.TIM_Prescaler=psc; //定时器分频 TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式 TIM_TimeBaseStructure.TIM_Period=arr; //自动重装载值 TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1; TIM_TimeBaseInit(TIM5,&TIM_TimeBaseStructure);//初始化定时5 //初始化TIM5 Channe4 PWM模式 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //选择定时器模式:TIM脉冲宽度调制模式1 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性:TIM输出比较极性低 TIM_OCInitStructure.TIM_Pulse = arr/2;//arr+1; TIM_OC4Init(TIM5, &TIM_OCInitStructure); //根据T指定的参数初始化外设 TIM_OC4PreloadConfig(TIM5, TIM_OCPreload_Enable); //使能TIM5在CCR4上的预装载寄存器 TIM5-》CNT = 0; TIM_ARRPreloadConfig(TIM5,ENABLE);//ARPE使能 TIM_ClearFlag(TIM5, TIM_FLAG_Update); TIM_ITConfig(TIM5,TIM_IT_Update,ENABLE); //允许定时器5更新中断 TIM_ITConfig(TIM5,TIM_IT_CC4,DISABLE); //失能定时器5更新中断 TIM_Cmd(TIM5, DISABLE); //不使能TIM5 NVIC_InitStructure.NVIC_IRQChannel=TIM5_IRQn; //定时器5中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x00; //抢占优先级1 NVIC_InitStructure.NVIC_IRQChannelSubPriority=0x01; //子优先级0 NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE; NVIC_Init(&NVIC_InitStructure); } 调试结果: 解决: 后来换定时器2偶尔也还会出现这种情况,换成其他定时器就不会出现这种问题。所以,建议大家在用STM32F407ZET6(我所用的芯片)时,小心一点,最好不要使用这两个定时器(TIM2和TIM5)使用其他的定时器。 |
1780 浏览 1 评论
1621 浏览 1 评论
1081 浏览 2 评论
728 浏览 2 评论
1679 浏览 2 评论
1938浏览 9评论
731浏览 4评论
570浏览 3评论
596浏览 3评论
556浏览 3评论
GMT+8, 2024-12-24 03:17 , Processed in 1.038497 second(s), Total 76, Slave 60 queries .
