MIPI® DSI BRIDGE TO FLATLINK LVDS
Introduction ICN6201 is a bridge chip which receives MIPI® DSI inputs and sends LVDS outputs. MIPI® DSI supports up to 4 lanes and each lane operates at 1Gbps maximum; the totally maximum input bandwidth is 4Gbps; and the MIPI defined ULPS(ultra-low-power state) is also supported. ICN6201 decodes MIPI® DSI 18bepp RGB666 and 24bpp RGB888 packets. The LVDS output 18 or 24 bits pixel with 25MHz to 154MHz, by VESA or JEIDA format. ICN6201 support video resolution up to FHD (1920x1080) and WUXGA(1920x1200). ICN6201 adopts QFN40 and QFN 48pins package. Feature List Supports MIPI ® D-PHY Version 1.00.00 and MIPI ® DSI Version 1.02.00. Single Channel DSI Receiver with One, Two, Three and Four lanes configurable, each lanes operates up to 1Gbps. Receives 18bpp RGB666 and 24bpp RGB888 packets defined by DSI. Supports MIPI Low State, Ultra-Low Power State, Shut Down mode. Single Channel LVDS with output clock range of 25MHz to 154MHz. LVDS can be generated from MIPI HS clock or external reference clock. Support LVDS clock with center spreading up to 2%, modulation 30KHz ~ 60KHz. LVDS output with VESA or JEIDA format. LVDS output pin order can be swapped flexible. supply voltage: 1.8V. provide I2C slave interface. package: QFN40-pins with e-pad. Package: QFN48-pins with e-pad.
开启全新AI时代 智能嵌入式系统快速发展——“第六届国产嵌入式操作系统威廉希尔官方网站 与产业发展论坛”圆满结束
2022 浏览 0 评论
2024 RT-Thread全球巡回线下培训火热来袭!报名提问有奖!
14609 浏览 11 评论
2201 浏览 0 评论
IaaS+on+DPU(IoD)+下一代高性能算力底座威廉希尔官方网站 白皮书
3600 浏览 0 评论
飞凌嵌入式-ELFBOARD 常用的USB接口及其不同版本介绍第1期
1259 浏览 0 评论
68912 浏览 21 评论
GMT+8, 2024-9-22 19:32 , Processed in 0.553287 second(s), Total 67, Slave 48 queries .
