adc.c /joystick.c /remoter.c 代码详解
(1)adc.c adc.c 在HARDWARE分组下。 adc.c 主要实现采集摇杆电位器电压 AD 值。 ① //初始化ADC,使用DMA传输 //通道PA0PA1PA3PA4 void Adc_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; ADC_InitTypeDef ADC_InitStructure; DMA_InitTypeDef DMA_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);//使能GPIOAB时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);//使能ADC1时钟 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//使能DMA时钟 //PA012 作为模拟通道输入引脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚 GPIO_Init(GPIOA, &GPIO_InitStructure); //PB01 作为模拟通道输入引脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; GPIO_Init(GPIOB, &GPIO_InitStructure); //DMA 配置 DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1-》DR; //ADC1-》DR地址 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&adc_value;//内存地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = 5*ADC_SAMPLE_NUM; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址固定 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址增加 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //半字 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环传输 DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); DMA_Cmd(DMA1_Channel1, ENABLE); ADC_DeInit(ADC1); //复位ADC1,将外设 ADC1 的全部寄存器重设为缺省值 ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在独立模式 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //扫描模式,用于多通道采集 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //连续转换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //转换由软件而不是外部触发启动 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐 ADC_InitStructure.ADC_NbrOfChannel = 5; //顺序进行规则转换的ADC通道的数目 ADC_Init(ADC1, &ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器 ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1 ADC_DMACmd(ADC1, ENABLE);//使能ADC1 DMA RCC_ADCCLKConfig(RCC_PCLK2_Div6); //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M //配置连续转换通道,55.5个采样周期 ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5); //1个通道转换一次耗时21us 4个通道 ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5); //采样个数ADC_SAMPLE_NUM ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5); //总共耗时4*21*ADC_SAMPLE_NUM(64)=5.4ms《10ms ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 4, ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 5, ADC_SampleTime_239Cycles5); ADC_ResetCalibration(ADC1); //使能复位校准 while(ADC_GetResetCalibrationStatus(ADC1)); //等待复位校准结束 ADC_StartCalibration(ADC1); //开启AD校准 while(ADC_GetCalibrationStatus(ADC1)); //等待校准结束 ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能指定的ADC1的软件转换启动功能 } DMA(Direct Memory Access):直接存储器访问。 DMA传输将数据从一个地址空间复制到另一个地址空间。当CPU初始化这个动作后,传输动作本身是由DMA控制器来实现和完成。采用DMA传输数据不仅不会让处理器的工作延迟,反而可以解放处理器去处理其他事项。 DMA传输方式无需CPU直接控制传输,也没有中断处理方式那样保留现场和恢复现场的过程,通过硬件为RAM与I/O设备开辟一条直接传送数据的通路,能使CPU得效率大为提高。 STM32最多有2个DMA控制器,DMA1有7个通道。DMA2有5个通道。每个通道专门用来管理来自于一个或多个外设对存储器访问的请求。还有一个仲裁来协调各个DMA请求的优先权。 ② #define ADC_SAMPLE_NUM 10 u16 adc_value[5*ADC_SAMPLE_NUM];//ADC采集值存放缓冲区 //ADC均值滤波 void ADC_Filter(u16* adc_val) { u16 i=0; u32 sum[5]={0,0,0,0}; for(;i《ADC_SAMPLE_NUM;i++) { sum[0]+=adc_value[5*i+0];//adc_value是ADC采集出来的数据 sum[1]+=adc_value[5*i+1]; sum[2]+=adc_value[5*i+2]; sum[3]+=adc_value[5*i+3]; sum[4]+=adc_value[5*i+4]; } adc_val[0]=sum[0]/ADC_SAMPLE_NUM; adc_val[1]=sum[1]/ADC_SAMPLE_NUM; adc_val[2]=sum[2]/ADC_SAMPLE_NUM; adc_val[3]=sum[3]/ADC_SAMPLE_NUM; adc_val[4]=sum[4]/ADC_SAMPLE_NUM; } ③ u16 getAdcValue(u8 axis) { u32 sum=0; for(u8 i=0;i《ADC_SAMPLE_NUM;i++) { sum += adc_value[5*i+axis]; } return sum/ADC_SAMPLE_NUM; } (2)joystick.c joystick.c在COMMUNICATE分组下。 joystick.c 主要实现将 AD值转为 THRUST、YAW、PITCH、ROLL 对应百分比。 joystick—摇杆,THRUST—油门值 YAW—偏航角,PITCH—俯仰角,ROLL—滚转角 ① /*摇杆初始化*/ void joystickInit(void) { if(isInit) return; Adc_Init(); jsParam = &configParam.jsParam; isInit = true; } ② /*获取摇杆ADC值*/ void getFlyDataADCValue(joystickFlyui16_t *adcValue) { adcValue-》thrust = getAdcValue(ADC_THRUST); adcValue-》roll = getAdcValue(ADC_ROLL); adcValue-》pitch = getAdcValue(ADC_PITCH); adcValue-》yaw = getAdcValue(ADC_YAW); } ③ /*ADC值转换成飞控数据百分比*/ void ADCtoFlyDataPercent(joystickFlyf_t *percent) { s16 adcValue; //THRUST adcValue = getAdcValue(ADC_THRUST) - jsParam-》thrust.mid; adcValue = deadband(adcValue,MID_DB_THRUST); if(adcValue》=0) percent-》thrust = (float)adcValue/(jsParam-》thrust.range_pos-MID_DB_THRUST-DB_RANGE); else percent-》thrust = (float)adcValue/(jsParam-》thrust.range_neg-MID_DB_THRUST-DB_RANGE); //ROLL adcValue = getAdcValue(ADC_ROLL) - jsParam-》roll.mid; adcValue = deadband(adcValue, MID_DB_ROLL); if(adcValue 》= 0) percent-》roll = (float)adcValue/(jsParam-》roll.range_pos-MID_DB_ROLL-DB_RANGE); else percent-》roll = (float)adcValue/(jsParam-》roll.range_neg-MID_DB_ROLL-DB_RANGE); //PITCH adcValue = getAdcValue(ADC_PITCH) - jsParam-》pitch.mid; adcValue = deadband(adcValue, MID_DB_PITCH); if(adcValue 》= 0) percent-》pitch = (float)adcValue/(jsParam-》pitch.range_pos-MID_DB_PITCH-DB_RANGE); else percent-》pitch = (float)adcValue/(jsParam-》pitch.range_neg-MID_DB_PITCH-DB_RANGE); //YAW adcValue = getAdcValue(ADC_YAW) - jsParam-》yaw.mid; adcValue = deadband(adcValue, MID_DB_YAW); if(adcValue 》= 0) percent-》yaw = (float)adcValue/(jsParam-》yaw.range_pos-MID_DB_YAW-DB_RANGE); else percent-》yaw = (float)adcValue/(jsParam-》yaw.range_neg-MID_DB_YAW-DB_RANGE); } (3)remoter.c remoter.c在COMMUNICATE分组下。 remoter.c 主要实现将百分比乘以设定速度值并打包成 ATKP 包格式,然后以 10ms 周期性发送到 radiolink.c 的发送队列中,即 commanderTask。 /*发送飞控命令任务*/ void commanderTask(void* param) { float max_thrust = LOW_SPEED_THRUST; float max_pitch = LOW_SPEED_PITCH; float max_roll = LOW_SPEED_ROLL; joystickFlyf_t percent; while(1) { vTaskDelay(10); switch(configParam.flight.speed) { case LOW_SPEED: max_thrust = LOW_SPEED_THRUST; max_pitch = LOW_SPEED_PITCH; max_roll = LOW_SPEED_ROLL; break; case MID_SPEED: max_thrust = MID_SPEED_THRUST; max_pitch = MID_SPEED_PITCH; max_roll = MID_SPEED_ROLL; break; case HIGH_SPEED: max_thrust = HIGH_SPEED_THRUST; max_pitch = HIGH_SPEED_PITCH; max_roll = HIGH_SPEED_ROLL; break; } ADCtoFlyDataPercent(&percent); //THRUST if(configParam.flight.ctrl == ALTHOLD_MODE || configParam.flight.ctrl == THREEHOLD_MODE)/*定高模式 和定点模式*/ { flydata.thrust = percent.thrust * ALT_THRUST; flydata.thrust += ALT_THRUST; flydata.thrust = limit(flydata.thrust, 0, 100); } else { flydata.thrust = percent.thrust * (max_thrust - MIN_THRUST); flydata.thrust += MIN_THRUST; flydata.thrust = limit(flydata.thrust, MIN_THRUST, max_thrust); } //ROLL flydata.roll = percent.roll * max_roll; flydata.roll = limit(flydata.roll, -max_roll, max_roll); //PITCH flydata.pitch = percent.pitch * max_pitch; flydata.pitch = limit(flydata.pitch, -max_pitch, max_pitch); //YAW flydata.yaw = percent.yaw * MAX_YAW; flydata.yaw = limit(flydata.yaw, -MAX_YAW, MAX_YAW); /*发送飞控数据*/ if(getRCLock()==false && radioinkConnectStatus()==true && getIsMFCanFly()==true) { remoterData_t send; switch(configParam.flight.mode) { case HEAD_LESS: send.flightMode = 1; break; case X_MODE: send.flightMode = 0; break; } switch(configParam.flight.ctrl) { case ALTHOLD_MODE: send.ctrlMode = 1; break; case MANUAL_MODE: send.ctrlMode = 0; break; case THREEHOLD_MODE: send.ctrlMode = 3; break; } if(flydata.thrust《=MIN_THRUST && send.ctrlMode==0) { send.thrust = 0; } else { send.thrust = flydata.thrust; } if(getTrimFlag() == true) { send.pitch = 0; send.roll = 0; } else { send.pitch = flydata.pitch ; send.roll = flydata.roll; } send.yaw = flydata.yaw; send.trimPitch = configParam.trim.pitch; send.trimRoll = configParam.trim.roll; /*发送飞控数据*/ sendRmotorData((u8*)&send, sizeof(send)); } /*发送遥感数据至匿名上位机*/ if(radioinkConnectStatus()==true) { atkp_t p; joystickFlyui16_t rcdata; rcdata.thrust = flydata.thrust*10 + 1000; rcdata.pitch = percent.pitch*500 + 1500; rcdata.roll = percent.roll*500 + 1500; rcdata.yaw = percent.yaw*500 + 1500; p.msgID = DOWN_RCDATA; p.dataLen = sizeof(rcdata); memcpy(p.data, &rcdata, p.dataLen); radiolinkSendPacket(&p); } } } |
1980 浏览 1 评论
1764 浏览 1 评论
1233 浏览 2 评论
819 浏览 2 评论
1777 浏览 2 评论
2015浏览 9评论
895浏览 4评论
320浏览 3评论
673浏览 3评论
662浏览 3评论
GMT+8, 2025-2-24 18:19 , Processed in 1.087570 second(s), Total 75, Slave 59 queries .
