插上模块,输入以下命令:$ dmesg | grep pci
$ lspci -v MYZR-IMX8M-EK300输出以下信息: ![]() root@myzr:~# dmesg | grep pci [ 3.291149] ehci-pci: EHCI PCI platform driver [ 3.314253] ohci-pci: OHCI PCI platform driver [ 5.563865] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator [ 5.572501] OF: PCI: host bridge /pcie@0x33800000 ranges: [ 5.576752] OF: PCI: No bus range found for /pcie@0x33800000, using [bus 00-ff] [ 5.593555] imx6q-pcie 33800000.pcie: pcie phy pll is locked. [ 5.842329] imx6q-pcie 33800000.pcie: phy link never came up [ 5.846713] imx6q-pcie 33800000.pcie: failed to initialize host [ 5.851339] imx6q-pcie 33800000.pcie: unable to add pcie port. [ 5.856799] imx6q-pcie: probe of 33800000.pcie failed with error -110 [ 5.864915] imx6q-pcie 33c00000.pcie: 33c00000.pcie supply epdev_on not found, using dummy regulator [ 5.873059] OF: PCI: host bridge /pcie@0x33c00000 ranges: [ 5.877227] OF: PCI: No bus range found for /pcie@0x33c00000, using [bus 00-ff] [ 5.894067] imx6q-pcie 33c00000.pcie: pcie phy pll is locked. [ 5.971961] imx6q-pcie 33c00000.pcie: Speed change timeout [ 5.976153] imx6q-pcie 33c00000.pcie: Roll back to GEN1 link! [ 5.980606] imx6q-pcie 33c00000.pcie: Link up, Gen1 [ 5.987200] imx6q-pcie 33c00000.pcie: PCI host bridge to bus 0000:00 [ 5.992283] pci_bus 0000:00: root bus resource [bus 00-ff] [ 5.996545] pci_bus 0000:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x0000-0xffff]) [ 6.004231] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27efffff] [ 6.009932] pci 0000:00:00.0: [16c3:abcd] type 01 class 0x060400 [ 6.009971] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit] [ 6.009982] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 6.010040] pci 0000:00:00.0: supports D1 [ 6.010048] pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold [ 6.010645] pci 0000:01:00.0: [8086:4229] type 00 class 0x028000 [ 6.010784] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit] [ 6.011224] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold [ 6.022488] pci 0000:00:00.0: BAR 0: assigned [mem 0x20000000-0x200fffff 64bit] [ 6.028597] pci 0000:00:00.0: BAR 14: assigned [mem 0x20100000-0x201fffff] [ 6.034248] pci 0000:00:00.0: BAR 6: assigned [mem 0x20200000-0x2020ffff pref] [ 6.040247] pci 0000:01:00.0: BAR 0: assigned [mem 0x20100000-0x20101fff 64bit] [ 6.046325] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 6.050338] pci 0000:00:00.0: bridge window [mem 0x20100000-0x201fffff] [ 6.056721] pcieport 0000:00:00.0: Signaling PME with IRQ 271 [ 6.061499] pcieport 0000:00:00.0: AER enabled with IRQ 271 root@myzr:~# lspci -v 00:00.0 PCI bridge: Synopsys, Inc. Device abcd (rev 01) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 271 Memory at 20000000 (64-bit, non-prefetchable) [size=1M] Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0 Memory behind bridge: 20100000-201fffff [virtual] Expansion ROM at 20200000 [disabled] [size=64K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable+ Count=1/1 Maskable+ 64bit+ Capabilities: [70] Express Root Port (Slot-), MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [148] L1 PM Substates Kernel driver in use: pcieport 01:00.0 Network controller: Intel Corporation PRO/Wireless 4965 AG or AGN [Kedron] Network Connection (rev 61) Subsystem: Intel Corporation PRO/Wireless 4965 AG or AGN [Kedron] Network Connection Flags: fast devsel Memory at 20100000 (64-bit, non-prefetchable) [disabled] [size=8K] Capabilities: [c8] Power Management version 3 Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [e0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Device Serial Number 00-1f-3b-ff-ff-1c-b8-fd |
10008 浏览 19 评论
10624 浏览 0 评论
3992 浏览 0 评论
8947 浏览 8 评论
2517 浏览 1 评论
GMT+8, 2025-2-23 04:31 , Processed in 0.426773 second(s), Total 41, Slave 33 queries .
