硬件环境
芯片 STM32F334C8Tx 开发板 STM32F3348-Discovery 升降压电路 试验目的 输入电压范围2-5V,恒定升压到10V输出 实现原理 根据原理图得知,要实现BOOST功能,需要控制PA8恒为高电平 然后控制PA10为高电平,PA11低电平时为电感L3充电。 再控制PA11为高电平,PA10低电平,让电感与输入电压一起放电,达到升压的目的 软件配置 1、ADC采样 因为BOOST电路有纹波,为了实现ADC的精准采样,需要在纹波上升沿中间的瞬间进行准确采样 需要将ADC配置为HRTIM触发采样 首先进行ADC基本配置 hadc1.Instance = ADC1; //OK hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;//OK hadc1.Init.Resolution = ADC_RESOLUTION_12B;//OK hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;//OK hadc1.Init.ContinuousConvMode = DISABLE; //OK hadc1.Init.DiscontinuousConvMode = DISABLE;//OK hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;//OK hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; //OK hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;//OK hadc1.Init.NbrOfConversion = 1;//OK hadc1.Init.DMAContinuousRequests = DISABLE;//OK hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;//OK hadc1.Init.LowPowerAutoWait = DISABLE; //OK hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;//OK if (HAL_ADC_Init(&hadc1) != HAL_OK) { Error_Handler(); } 然后配置ADC为HRTIM触发采样 /** Configure Injected Channel */ sConfigInjected.InjectedChannel = ADC_CHANNEL_2; //OK sConfigInjected.InjectedRank = ADC_INJECTED_RANK_1; //OK sConfigInjected.InjectedSingleDiff = ADC_SINGLE_ENDED;//OK sConfigInjected.InjectedNbrOfConversion = 2;//OK sConfigInjected.InjectedSamplingTime = ADC_SAMPLETIME_7CYCLES_5;//OK sConfigInjected.ExternalTrigInjecConvEdge = ADC_EXTERNALTRIGINJECCONV_EDGE_RISING;//OK sConfigInjected.ExternalTrigInjecConv = ADC_EXTERNALTRIGINJECCONV_HRTIM_TRG2;//OK sConfigInjected.AutoInjectedConv = DISABLE;//OK sConfigInjected.InjectedDiscontinuousConvMode = DISABLE;//OK sConfigInjected.QueueInjectedContext = DISABLE;//OK sConfigInjected.InjectedOffset = 0;//OK sConfigInjected.InjectedOffsetNumber = ADC_OFFSET_NONE;//OK if (HAL_ADCEx_InjectedConfigChannel(&hadc1, &sConfigInjected) != HAL_OK) { Error_Handler(); } /** Configure Injected Channel */ sConfigInjected.InjectedChannel = ADC_CHANNEL_4;//OK sConfigInjected.InjectedRank = ADC_INJECTED_RANK_2;//OK sConfigInjected.InjectedSamplingTime = ADC_SAMPLETIME_19CYCLES_5;//OK if (HAL_ADCEx_InjectedConfigChannel(&hadc1, &sConfigInjected) != HAL_OK) { Error_Handler(); } 最后启动ADC /* Run the ADC calibration in single-ended mode */ HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED); /* Start ADC1 Injected Conversions */ HAL_ADCEx_InjectedStart(&hadc1); 2、HRTIM配置 HRTIM需要配置的东西很多,需要对以下结构体进行初始化并调用库函数进行配置 HRTIM_TimeBaseCfgTypeDef timebase_config; HRTIM_TimerCfgTypeDef timer_config; HRTIM_OutputCfgTypeDef output_config; HRTIM_CompareCfgTypeDef compare_config; HRTIM_DeadTimeCfgTypeDef HRTIM_TIM_DeadTimeConfig; HRTIM_ADCTriggerCfgTypeDef adc_trigger_config; HRTIM_FaultCfgTypeDef fault_config; 首先是HRTIM的基本配置 /* ----------------------------*/ /* HRTIM Global initialization */ /* ----------------------------*/ /* Initialize the HRTIM handle (and clear it before for greater portability) */ hhrtim.Instance = HRTIM1; //OK hhrtim.Init.HRTIMInterruptResquests = HRTIM_IT_NONE; //OK hhrtim.Init.SyncOptions = HRTIM_SYNCOPTION_NONE; //OK /* Initialize HRTIM */ HAL_HRTIM_Init(&hhrtim); //OK /* HRTIM DLL calibration: periodic calibration, set period to 14祍 */ HAL_HRTIM_DLLCalibrationStart(&hhrtim, HRTIM_CALIBRATIONRATE_14); //OK /* Wait calibration completion*/ if (HAL_HRTIM_PollForDLLCalibration(&hhrtim, 100) != HAL_OK) //OK { Error_Handler(); /* if DLL or clock is not correctly set */ } 再配置HRTIM的频率为250KHZ timebase_config.Period = BUCK_PWM_PERIOD; /* 250kHz switching frequency */ //OK timebase_config.RepetitionCounter = 31; /* 1 ISR every 32 PWM periods */ //OK timebase_config.PrescalerRatio = HRTIM_PRESCALERRATIO_MUL32; //OK timebase_config.Mode = HRTIM_MODE_CONTINUOUS; //OK HAL_HRTIM_TimeBaseConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, &timebase_config); HAL_HRTIM_TimeBaseConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, &timebase_config); 再对TIMERA和TIMEB的一些参数进行配置 timer_config.DMARequests = HRTIM_TIM_DMA_NONE;//OK timer_config.DMASrcAddress = 0x0;//OK timer_config.DMADstAddress = 0x0;//OK timer_config.DMASize = 0x0;//OK timer_config.HalfModeEnable = HRTIM_HALFMODE_DISABLED;//OK timer_config.StartOnSync = HRTIM_SYNCSTART_DISABLED;//OK timer_config.ResetOnSync = HRTIM_SYNCRESET_DISABLED;//OK timer_config.DACSynchro = HRTIM_DACSYNC_NONE;//OK timer_config.PreloadEnable = HRTIM_PRELOAD_ENABLED;//OK timer_config.UpdateGating = HRTIM_UPDATEGATING_INDEPENDENT;//OK timer_config.BurstMode = HRTIM_TIMERBURSTMODE_MAINTAINCLOCK;//OK timer_config.RepetitionUpdate = HRTIM_UPDATEONREPETITION_ENABLED;//OK timer_config.ResetUpdate = HRTIM_TIMUPDATEONRESET_DISABLED; //OK timer_config.InterruptRequests = HRTIM_TIM_IT_REP; //OK timer_config.PushPull = HRTIM_TIMPUSHPULLMODE_DISABLED;//OK timer_config.FaultEnable = HRTIM_TIMFAULTENABLE_FAULT1;//OK timer_config.FaultLock = HRTIM_TIMFAULTLOCK_READWRITE;//OK timer_config.DeadTimeInsertion = HRTIM_TIMDEADTIMEINSERTION_ENABLED;//OK timer_config.DelayedProtectionMode = HRTIM_TIMER_A_B_C_DELAYEDPROTECTION_DISABLED;//OK timer_config.UpdateTrigger= HRTIM_TIMUPDATETRIGGER_NONE;//OK timer_config.ResetTrigger = HRTIM_TIMRESETTRIGGER_NONE;//OK HAL_HRTIM_WaveformTimerConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, &timer_config); HAL_HRTIM_WaveformTimerConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, &timer_config); 对 TA1 TA2 TB1 and TB2 的波形进行配置 output_config.Polarity = HRTIM_OUTPUTPOLARITY_HIGH; //OK output_config.SetSource = HRTIM_OUTPUTSET_TIMCMP1;//OK output_config.ResetSource = HRTIM_OUTPUTRESET_TIMPER; output_config.IdleMode = HRTIM_OUTPUTIDLEMODE_NONE;//OK output_config.IdleLevel = HRTIM_OUTPUTIDLELEVEL_INACTIVE;//OK output_config.FaultLevel = HRTIM_OUTPUTFAULTLEVEL_INACTIVE; output_config.ChopperModeEnable = HRTIM_OUTPUTCHOPPERMODE_DISABLED;//OK output_config.BurstModeEntryDelayed = HRTIM_OUTPUTBURSTMODEENTRY_REGULAR;//OK HAL_HRTIM_WaveformOutputConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, HRTIM_OUTPUT_TA1, &output_config); HAL_HRTIM_WaveformOutputConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, HRTIM_OUTPUT_TA2, &output_config); /* Set compare registers for duty cycle on TA1 在TA1上设置占空比寄存器*/ compare_config.AutoDelayedMode = HRTIM_AUTODELAYEDMODE_REGULAR; compare_config.AutoDelayedTimeout = 0; compare_config.CompareValue = BUCK_PWM_PERIOD - 0x60; /* Start with minimal duty cycle */ HAL_HRTIM_WaveformCompareConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, HRTIM_COMPAREUNIT_1, &compare_config); output_config.Polarity = HRTIM_OUTPUTPOLARITY_HIGH; output_config.SetSource = HRTIM_OUTPUTSET_TIMCMP1; output_config.ResetSource = HRTIM_OUTPUTRESET_TIMPER; output_config.IdleMode = HRTIM_OUTPUTIDLEMODE_NONE; output_config.IdleLevel = HRTIM_OUTPUTIDLELEVEL_INACTIVE; output_config.FaultLevel = HRTIM_OUTPUTFAULTLEVEL_INACTIVE; output_config.ChopperModeEnable = HRTIM_OUTPUTCHOPPERMODE_DISABLED; output_config.BurstModeEntryDelayed = HRTIM_OUTPUTBURSTMODEENTRY_REGULAR; HAL_HRTIM_WaveformOutputConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, HRTIM_OUTPUT_TB1, &output_config); HAL_HRTIM_WaveformOutputConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, HRTIM_OUTPUT_TB2, &output_config); /* Set compare registers for duty cycle on TB1 */ compare_config.AutoDelayedMode = HRTIM_AUTODELAYEDMODE_REGULAR; compare_config.AutoDelayedTimeout = 0; compare_config.CompareValue = BUCK_PWM_PERIOD+1; /* 0% duty cycle */ HAL_HRTIM_WaveformCompareConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, &compare_config); 死区时间配置,这一步配置完后,PA10和PA11高低电平不会完全重叠,将留一小段时间同时为低电平,如果不这样做的话,输入电源将存在短路现象 HRTIM_TIM_DeadTimeConfig.FallingLock = HRTIM_TIMDEADTIME_FALLINGLOCK_WRITE;//OK HRTIM_TIM_DeadTimeConfig.FallingSign = HRTIM_TIMDEADTIME_FALLINGSIGN_POSITIVE; //OK HRTIM_TIM_DeadTimeConfig.FallingSignLock = HRTIM_TIMDEADTIME_FALLINGSIGNLOCK_READONLY; //OK HRTIM_TIM_DeadTimeConfig.FallingValue = DT_FALLING; //OK HRTIM_TIM_DeadTimeConfig.Prescaler = HRTIM_TIMDEADTIME_PRESCALERRATIO_MUL8; HRTIM_TIM_DeadTimeConfig.RisingLock = HRTIM_TIMDEADTIME_RISINGLOCK_WRITE; //OK HRTIM_TIM_DeadTimeConfig.RisingSign = HRTIM_TIMDEADTIME_RISINGSIGN_POSITIVE; //OK HRTIM_TIM_DeadTimeConfig.RisingSignLock = HRTIM_TIMDEADTIME_RISINGSIGNLOCK_READONLY; //OK HRTIM_TIM_DeadTimeConfig.RisingValue = DT_RISING; //OK HAL_HRTIM_DeadTimeConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, &HRTIM_TIM_DeadTimeConfig); /* Same parameters for Timer B */ HAL_HRTIM_DeadTimeConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, &HRTIM_TIM_DeadTimeConfig); 配置之后的波形: 将ADC与HRTIM关联起来,让HRTIM触发ADC采样 compare_config.AutoDelayedMode = HRTIM_AUTODELAYEDMODE_REGULAR; compare_config.CompareValue = BUCK_PWM_PERIOD/2; /* Samples at 50% of period */ compare_config.AutoDelayedTimeout = 0; HAL_HRTIM_WaveformCompareConfig(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, HRTIM_COMPAREUNIT_2, &compare_config); adc_trigger_config.Trigger = HRTIM_ADCTRIGGEREVENT24_TIMERA_CMP2; adc_trigger_config.UpdateSource = HRTIM_ADCTRIGGERUPDATE_TIMER_A; HAL_HRTIM_ADCTriggerConfig(&hhrtim, 故障模式配置,故障输入时(PA12为低电平认为),将不输出PWM /* ---------------------*/ /* FAULT initialization */ /* ---------------------*/ fault_config.Filter = HRTIM_FAULTFILTER_NONE;//OK fault_config.Lock = HRTIM_FAULTLOCK_READWRITE;//OK fault_config.Polarity = HRTIM_FAULTPOLARITY_LOW;//OK fault_config.Source = HRTIM_FAULTSOURCE_DIGITALINPUT; //OK HAL_HRTIM_FaultConfig(&hhrtim, HRTIM_FAULT_1, &fault_config); HAL_HRTIM_FaultModeCtl(&hhrtim, HRTIM_FAULT_1, HRTIM_FAULTMODECTL_ENABLED); ADC采样数据的读取 根据原理图的分压电阻,来读取ADC并计算电压 /* -------------------------------------------------------------------------*/ /* Input and output voltages measures (can be displayed in a watch window) */ /* -------------------------------------------------------------------------*/ Vin = (HAL_ADCEx_InjectedGetValue(&AdcHandle, ADC_INJECTED_RANK_1) * 3300)/0xFFF; /* VIN bridge conversion is 4.97 (6.8K / 6.8K + 27K) */ Vin = (497 * Vin )/100; /* Values in mV (for debug convenience) */ Vout = (HAL_ADCEx_InjectedGetValue(&AdcHandle, ADC_INJECTED_RANK_2) * 3300)/0xFFF; /* VOUT bridge conversion is 5.03 (3.3K / 3.3K + 13.3K) */ Vout = (503 * Vout)/100; /* Values in mV (for debug convenience) */ BOOST自动升压 首先永久开启PA8为高电平 /* BUCK side PMOS turned ON permanently BUCK侧PMOS永久开启 */ __HAL_HRTIM_SETCOMPARE(&hhrtim, HRTIM_TIMERINDEX_TIMER_A, HRTIM_COMPAREUNIT_1, BUCK_PWM_PERIOD); 1 2 读取当前占空比 CurrentDuty = __HAL_HRTIM_GETCOMPARE(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1); 1 根据电压来自动调节占空比大小,boost_cnt的作用是,让调节慢一些,否则调节太快了可能不稳定 if(Vout <= 1000) { if(CurrentDuty > (BUCK_PWM_PERIOD / 4)) CurrentDuty -= 2; } else if(Vout <= 9000) { if(CurrentDuty > (BUCK_PWM_PERIOD / 4)) CurrentDuty -= 1; } else if(Vout <= 9980) { boost_cnt ++; if(boost_cnt >= 10) { if(CurrentDuty > (BUCK_PWM_PERIOD / 4)) CurrentDuty -= 1; boost_cnt = 0; } } if(Vout >= 10020) { boost_cnt ++; if(boost_cnt >= 10) { if(CurrentDuty < BUCK_PWM_PERIOD - 1) CurrentDuty += 1; boost_cnt = 0; } } else if(Vout >= 15000) { if(CurrentDuty < BUCK_PWM_PERIOD - 2) CurrentDuty += 2; } 重新配置占空比 if(Vout <= 9900) { __HAL_HRTIM_SETCOMPARE(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, CurrentDuty); } if(Vout >= 10100) { __HAL_HRTIM_SETCOMPARE(&hhrtim, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, CurrentDuty); } 结果 根据KEIL的WATCH窗口,可以看到数据,测试成功 |
4768个成员聚集在这个小组
加入小组3414 浏览 0 评论
4327 浏览 1 评论
4367 浏览 0 评论
GMT+8, 2025-2-24 10:41 , Processed in 0.585349 second(s), Total 45, Slave 39 queries .
