#include "reg52.h" #include "mfrc522.h" #include "intrins.h" #include #include "stdio.h" #define u8 unsigned char #define u32 unsigned int #define FOSC 12000000L //System frequency #define BAUD 2400 //UART baudrate ***it P11=P1^1;//作为一个辅助LED灯而已 bit CmdValid=0; u8 status; u8 pTagType[2]; u8 code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; //配带的那张白卡的扇区密码 u8 idata MLastSelectedSnr[4];//这个用来存放卡片的序列号,4个字节 u8 idata RevBuffer[16]; u8 me[16]={1,1,1,4,4,4,5,5,5,10,10,10,3,13,5,15};//想在块一写入 void ANT_INIT(); //定时器只是用来做波特率发生器 //使用定时器/计数器2的时候记得要在REG52.h头文件里添加:sfr T2CON = 0xC8; //否则会报错 void Timer2Init(void) //100微秒@12.000MHz { T2MOD = 0; //初始化模式寄存器 T2CON = 0x34; //Timer2 start run TL2 = RCAP2L = (65536-(FOSC/32/BAUD)); //Set auto-reload vaule TH2 = RCAP2H = (65536-(FOSC/32/BAUD)) >> 8; TR2 = 1; //定时器2开始计时 } void main() { Timer2Init(); P11=1; SCON = 0x50; //8-bit variable UART ES = 1; //Enable UART interrupt EA = 1; //Open master interrupt switch CmdValid=0; PcdReset(); //以下三条是天线的初始化,必须 PcdAntennaOff(); PcdAntennaOn(); // delay_10ms(250); M500PcdConfigISOType( 'A' );//工作模式“A” while(1) { ANT_INIT(); } } void ANT_INIT() { PcdHalt(); PcdRequest(PICC_REQALL,&pTagType);//寻卡成功 status=PcdAnticoll(&MLastSelectedSnr);//防冲撞成功 PcdSelect(MLastSelectedSnr); PcdAuthState(0x60,1,DefaultKey,MLastSelectedSnr); //status=PcdWrite(1,me); //这是写,使用时可以先注释掉下面一行代码 //status=PcdRead(1,RevBuffer);//这是读,使用时可以先注释掉上面一行代码 if(status==0) SBUF=MLastSelectedSnr[0];//触发串口中断 else TI=0; } /*---------------------------- UART interrupt service routine ----------------------------*/ void Uart_Isr() interrupt 4 using 1 { static unsigned char i=0; //白卡序列号 : BA A5 EF 0A if(TI==1) { TI=0; for(i=1;i<4;i++) { SBUF=MLastSelectedSnr; while(!TI); TI=0; } } } |
2391 浏览 0 评论
934浏览 2评论
567浏览 1评论
332浏览 0评论
GMT+8, 2024-9-20 23:47 , Processed in 1.108039 second(s), Total 48, Slave 40 queries .
