本例,使用1ch进行ADC转换,对应的引脚为PA1,连续转换,在main中只要调用void Init_AD(INT8U ch)后,便可以初始化。初始化后,调用void Read_ADC(INT8U ch)便可以随时读取ADC的转换结果;
ADC_tran.c文件如下: #include #include #include #include "lcd1602.h" #define INT8U unsigned char #define INT16U unsigned int #define CH 0x01 INT16U adc_data; char str[20]; void Init_AD(INT8U ch) { DDRA &= (0< } void Read_ADC(INT8U ch) { ADMUX |= ch; //选择读取的通道ch; adc_data = ADC; //读取ADC转换结果; Display_String(0,0," "); //清屏; sprintf(str,"power is %d",adc_data); //把需要显示的数据写入字符串; Display_String(0,0,str); //显示字符串STR; _delay_ms(200); //防止屏幕闪烁太快; } ADC_tran.h文件如下: #ifndef ADC_TRAN_H_ #define ADC_TRAN_H_ #include #include #include #include "lcd1602.h" #define CH 0x01 extern void Init_AD(INT8U ch); extern void Read_ADC(INT8U ch); #endif /* ADC_TRAN_H_ */ 最后,为了方便显示,调用了LCD驱动来显示,以为可参考上一篇关于LCD驱动的文章https://blog.csdn.net/rzchong1988/article/details/101764091; 最终的main如下: #define F_CPU 4000000UL #include "lcd1602.h" #include "ADC_tran.h" int main(void) { Init_LCD1602(); Init_AD(CH); while(1) { Read_ADC(CH); } } |
2639 浏览 0 评论
855浏览 1评论
311浏览 1评论
627浏览 0评论
356浏览 0评论
571浏览 0评论
GMT+8, 2025-3-7 00:14 , Processed in 1.098476 second(s), Total 77, Slave 59 queries .
