这是我聪明做的一个功能,有一些细节没注意,导致移植没通,现在记下来。
一、硬件部分 STM32F103C8T6:2个,记为STM32(1),STM32(2) TJA1050(CAN模块) ):2个,记为TJA(1),TJA(2) STM32(1)的RX接TJA(1)的RX,TX接TX。TJA(1)的CAN_H接另一个TJA(2)的CAN_H, CAN_L接CAN_L。然后TJA(2)的RX接STM32(2)的RX,TX接TX。 二、软件部分 注释:软件参考了网上的一些朋友的代码,如果雷同,纯属参考学习,谢谢! u8 CAN1_Mode_Init(u8 tsjw,u8 tbs2,u8 tbs1,u16 brp,u8 mode) { GPIO_InitTypeDef GPIO_InitStructure; CAN_InitTypeDef CAN_InitStructure; CAN_FilterInitTypeDef CAN_FilterInitStructure; #if CAN1_RX0_INT_ENABLE NVIC_InitTypeDef NVIC_InitStructure; #endif RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE); GPIO_PinRemapConfig(GPIO_Remap1_CAN1,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz GPIO_Init(GPIOA, &GPIO_InitStructure); CAN_InitStructure.CAN_TTCM=DISABLE; CAN_InitStructure.CAN_ABOM=DISABLE; CAN_InitStructure.CAN_AWUM=DISABLE; CAN_InitStructure.CAN_NART=DISABLE; CAN_InitStructure.CAN_RFLM=DISABLE; CAN_InitStructure.CAN_TXFP=DISABLE; CAN_InitStructure.CAN_Mode= CAN_Mode_Normal; CAN_InitStructure.CAN_SJW=tsjw; CAN_InitStructure.CAN_BS1=tbs1; CAN_InitStructure.CAN_BS2=tbs2; CAN_InitStructure.CAN_Prescaler=brp; CAN_Init(CAN1, &CAN_InitStructure); CAN_FilterInitStructure.CAN_FilterNumber=0; CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask; CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit; CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000; CAN_FilterInitStructure.CAN_FilterIdLow=0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000; CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0; CAN_FilterInitStructure.CAN_FilterActivation=ENABLE; CAN_FilterInit(&CAN_FilterInitStructure); #if CAN1_RX0_INT_ENABLE CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE); CAN_ITConfig(CAN1,CAN_IT_TME,ENABLE); CAN_ITConfig(CAN1,CAN_IT_BOF,ENABLE); NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); #endif return 0; } #if CAN1_RX0_INT_ENABLE void USB_LP_CAN1_RX0_IRQHandler(void) { int i=0; CanRxMsg RxMessage; RxMessage.StdId=0x00; RxMessage.ExtId=0x00; RxMessage.IDE=0; RxMessage.RTR=0; RxMessage.FMI=0; for(i=0;i《8;i++) RxMessage.Data[i]=0; CAN_Receive(CAN1, 0, &RxMessage); //USART1_DATA(RxMessage.Data,RxMessage.DLC); printf(“IRQ RxMessage.Data = %srn”, RxMessage.Data); } #endif u8 CAN1_Send_Msg(u8* msg,u8 len) { u8 mbox; u16 i=0; CanTxMsg TxMessage; TxMessage.StdId=0x12; TxMessage.ExtId=0x12; TxMessage.IDE=CAN_ID_STD; TxMessage.RTR=CAN_RTR_Data; TxMessage.DLC=len; for(i=0;i《len;i++) TxMessage.Data[i]=*(msg+i); mbox= CAN_Transmit(CAN1, &TxMessage); i=0; while((CAN_TransmitStatus(CAN1, mbox)==CAN_TxStatus_Failed)&&(i《0XFFF))i++; / if(i》=0XFFF)return 1; return 0; } int main(void) { u8 i,cnt,len,res; u8 canbuf[8]; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); uart_init(); CAN1_Mode_Init(CAN_SJW_1tq,CAN_BS2_6tq,CAN_BS1_7tq,6,0); printf(“stm32 startup!rn”); while(1) { #if 1 delay_ms(1000); len = 8; cnt = ‘a’; for(i=0;i《len;i++) { canbuf[i]=cnt+i; } res = CAN1_Send_Msg(canbuf, len); #endif } } 两个STM32都烧写程序,然后接上字节,1s会收到另一个STM32发来的8个字节的abcdefgh。 注意事项: 1、TJA1050供电5V 2、用printf打印数据,如果使用USART_SendData必须等待发送完成再发送下一个编码。循环打印可以参考如下: void USART1_DATA(unsigned char *lb,unsigned int len) { unsigned int i; for(i=0;i《len;i++) { USART_SendData(USART1,*lb); while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET) { } lb ++; } } 3、CAN_TX和CAN_RX的GPIO属性配置不一样,要注意一下。 4、CAN1_RX0_INT_ENABLE置为1。 |
1298 浏览 1 评论
1310 浏览 1 评论
721 浏览 2 评论
531 浏览 2 评论
1327 浏览 2 评论
1730浏览 9评论
440浏览 4评论
393浏览 3评论
381浏览 3评论
361浏览 3评论
GMT+8, 2024-9-20 23:37 , Processed in 1.023992 second(s), Total 77, Slave 62 queries .
