我们从汇编来看,各种变量在内存中的存放位置
1,使用交叉编译器将Ç转换语言汇编分类中翻译 写一个Ç语言程序: static int x; static int y = 10; int z; int w = 20; int main() { int s; s=x; s=y; s=z; s=w; return 0; } (arm32) 使用交叉编译器将其编译成.o文件:arm-linux-androideabi-gcc-4.-c main.c 使用obj9转储工具将.o反定义:arm-linux-androideabi-objdump - d main.o hehezhou@buildsrv-165:~/workspace/test/test1$ arm-linux-androideabi-objdump -D main.o main.o: file format elf32-littlearm Disassembly of section .text: 00000000 《main》: 0: e52db004 push {fp} ; (str fp, [sp, #-4]!) 4: e28db000 add fp, sp, #0 8: e24dd00c sub sp, sp, #12 c: e59f3054 ldr r3, [pc, #84] ; 68 《main+0x68》 10: e08f3003 add r3, pc, r3 14: e59f2050 ldr r2, [pc, #80] ; 6c 《main+0x6c》 18: e08f2002 add r2, pc, r2 1c: e5922000 ldr r2, [r2] 20: e50b2008 str r2, [fp, #-8] 24: e59f2044 ldr r2, [pc, #68] ; 70 《main+0x70》 28: e08f2002 add r2, pc, r2 2c: e5922000 ldr r2, [r2] 30: e50b2008 str r2, [fp, #-8] 34: e59f2038 ldr r2, [pc, #56] ; 74 《main+0x74》 38: e7932002 ldr r2, [r3, r2] 3c: e5922000 ldr r2, [r2] 40: e50b2008 str r2, [fp, #-8] 44: e59f202c ldr r2, [pc, #44] ; 78 《main+0x78》 48: e7933002 ldr r3, [r3, r2] 4c: e5933000 ldr r3, [r3] 50: e50b3008 str r3, [fp, #-8] 54: e3a03000 mov r3, #0 58: e1a00003 mov r0, r3 5c: e24bd000 sub sp, fp, #0 60: e49db004 pop {fp} ; (ldr fp, [sp], #4) 64: e12fff1e bx lr 68: 00000050 andeq r0, r0, r0, asr r0 6c: 0000004c andeq r0, r0, ip, asr #32 70: 00000040 andeq r0, r0, r0, asr #32 。.. Disassembly of section .data: 00000000 《y》: 0: 0000000a andeq r0, r0, sl 00000004 《w》: 4: 00000014 andeq r0, r0, r4, lsl r0 Disassembly of section .bss: 00000000 《x》: 0: 00000000 andeq r0, r0, r0 Disassembly of section .comment: 00000000 《.comment》: 0: 43434700 movtmi r4, #14080 ; 0x3700 4: 4728203a ; 《UNDEFINED》 instruction: 0x4728203a 8: 2029554e eorcs r5, r9, lr, asr #10 c: 2e392e34 mrccs 14, 1, r2, cr9, cr4, {1} 10: 30322078 eorscc r2, r2, r8, ror r0 14: 31303531 teqcc r0, r1, lsr r5 18: 28203332 stmdacs r0!, {r1, r4, r5, r8, r9, ip, sp} 1c: 72657270 r***vc r7, r5, #112, 4 20: 61656c65 cmnvs r5, r5, ror #24 24: 00296573 eoreq r6, r9, r3, ror r5 Disassembly of section .ARM.attributes: 00000000 《.ARM.attributes》: 0: 00002a41 andeq r2, r0, r1, asr #20 4: 61656100 cmnvs r5, r0, lsl #2 8: 01006962 tsteq r0, r2, ror #18 c: 00000020 andeq r0, r0, r0, lsr #32 10: 45543505 ldrbmi r3, [r4, #-1285] ; 0xfffffafb 14: 08040600 stmdaeq r4, {r9, sl} 18: 12010901 andne r0, r1, #16384 ; 0x4000 1c: 15011404 strne r1, [r1, #-1028] ; 0xfffffbfc 20: 18031701 stmdane r3, {r0, r8, r9, sl, ip} 24: 1a011901 bne 46430 《w+0x4642c》 28: Address 0x0000000000000028 is out of bounds. (arm64) 使用交叉编译器将其编译成.o文件:aarch64-linux-android-gcc-4.9-c main.c 使用转储工具将.o反定义:aarch64-linux-android-objdump -D main.o hehezhou@buildsrv-165:~/workspace/test/test1$ aarch64-linux-android-objdump -D main.o main.o: file format elf64-littleaarch64 Disassembly of section .text: 0000000000000000 《main》: 0: d10043ff sub sp, sp, #0x10 4: 90000000 adrp x0, 0 《main》 8: 91000000 add x0, x0, #0x0 c: b9400000 ldr w0, [x0] 10: b9000fe0 str w0, [sp,#12] 14: 90000000 adrp x0, 0 《main》 18: 91000000 add x0, x0, #0x0 1c: b9400000 ldr w0, [x0] 20: b9000fe0 str w0, [sp,#12] 24: 90000000 adrp x0, 4 《main+0x4》 28: f9400000 ldr x0, [x0] 2c: b9400000 ldr w0, [x0] 30: b9000fe0 str w0, [sp,#12] 34: 90000000 adrp x0, 4 《main+0x4》 38: f9400000 ldr x0, [x0] 3c: b9400000 ldr w0, [x0] 40: b9000fe0 str w0, [sp,#12] 44: 52800000 mov w0, #0x0 // #0 48: 910043ff add sp, sp, #0x10 4c: d65f03c0 ret Disassembly of section .data: 0000000000000000 《y》: 0: 0000000a .word 0x0000000a 0000000000000004 《w》: 4: 00000014 .word 0x00000014 Disassembly of section .bss: 0000000000000000 《x》: 0: 00000000 .word 0x00000000 Disassembly of section .comment: 0000000000000000 《.comment》: 0: 43434700 .inst 0x43434700 ; undefined 4: 4728203a .inst 0x4728203a ; undefined 8: 2029554e .inst 0x2029554e ; undefined c: 2e392e34 uqsub v20.8b, v17.8b, v25.8b 10: 30322078 adr x24, 6441d 《w+0x64419》 14: 31303531 adds w17, w9, #0xc0d 18: 28203332 stnp w18, w12, [x25,#-256] 1c: 72657270 .inst 0x72657270 ; undefined 20: 61656c65 .inst 0x61656c65 ; undefined 24: 00296573 .inst 0x00296573 ; NYI 以aarch64的初始值分析 (1)、可以含有初始值的static int y = 10和int w = 20 都在数据段 最终未值的static x在bs static int x; static int y = 10; int z; int w = 20; Disassembly of section .data: 0000000000000000 《y》: 0: 0000000a .word 0x0000000a 0000000000000004 《w》: 4: 00000014 .word 0x00000014 Disassembly of section .bss: 0000000000000000 《x》: 0: 00000000 .word 0x00000000 (2),我们再来看简化代码 0000000000000000 《main》: 0: d10043ff sub sp, sp, #0x10 4: 90000000 adrp x0, 0 《main》 8: 91000000 add x0, x0, #0x0 c: b9400000 ldr w0, [x0] 10: b9000fe0 str w0, [sp,#12] 14: 90000000 adrp x0, 0 《main》 18: 91000000 add x0, x0, #0x0 1c: b9400000 ldr w0, [x0] 20: b9000fe0 str w0, [sp,#12] 24: 90000000 adrp x0, 4 《main+0x4》 28: f9400000 ldr x0, [x0] 2c: b9400000 ldr w0, [x0] 30: b9000fe0 str w0, [sp,#12] 34: 90000000 adrp x0, 4 《main+0x4》 38: f9400000 ldr x0, [x0] 3c: b9400000 ldr w0, [x0] 40: b9000fe0 str w0, [sp,#12] 44: 52800000 mov w0, #0x0 // #0 48: 910043ff add sp, sp, #0x10 4c: d65f03c0 ret |
2554 浏览 0 评论
1153浏览 2评论
752浏览 1评论
505浏览 0评论
269浏览 0评论
435浏览 0评论
GMT+8, 2024-12-24 10:58 , Processed in 1.591529 second(s), Total 78, Slave 60 queries .
