扫一扫,分享给好友
在Keil官网上下载PACK包速度特别慢,方便大家下载STM32的PACK包,
将STM32所有系列的PACK上传至网盘供大家下载,点击普通下载, 下载后解压出包安装即安装可,官网更新后我会进行更新。 stm32全系列库函数(标准库/HAL库) 点击城市模式快速定位下载,附上更新记录 Keil.STM32F0xx_DFP.2.1.0.pack Version: 2.1.0 更新记录: Device support: Updated Cube FW to STM32Cube_FW_F0 V1.11.0. Updated SVD file. Updated documentation. Corrected flash programming algorithms. Added capability to launch the Option Byte Loading after flash download. STM32CubeMX integration: Added support for Timebase Source TIMx in gpdsc.ftl. Corrected launching STM32CubeMX via “play” button for existing projects overwrites with a new 》STM32CubeMX project file instead of loading it. MX_Devive_h.ftl: Updated parsing of USART virtual mode. Updated generation of macros: Added handling for ‘(’ and ‘)’ symbols. Examples: Updated compiler to AC6. Added Event Recorder. CMSIS-Driver: CAN: 更正了 SetBitrate 函数以保持静默和环回模式不变。 更正了 SetMode 功能以在激活 NORMAL 模式时清除 Silent 和 Loopback 模式。 更正 MessageSend 函数以仅访问发送所需的数据。 更正了中止消息发送功能。 I2C: 更正的引脚配置:MX_I2C2_SMBA_GPIO_PuPdOD 替换为 MX_I2Cx_yyy_GPIO_PuPdOD。 USART:更正了 UARTx/USARTx 相关标识符。 USB 设备: 更新了 USBD_EndpointConfigure 函数以检查请求的最大数据包大小是否适合配置的 FIFO(编译时间配置)。 更正了非控制 IN 端点的传输计数。 Keil.STM32F1xx_DFP.2.3.0.pack Version: 2.3.0 更新记录: Added DBGMCU INI files for setting up debug configuration. Fixed case insensitive include of device header file (fixing build error on Linux)。 Updated CMSIS driver: CAN: Corrected MessageSend function to only access required data for sending Corrected abort message send functionality Corrected SetBitrate function EMAC: Corrected ETH DMA initialization. Now done when MAC transmitter or receiver is enabled (resolving netInitialize/netUnnitialize/netInitialize issue)。 USB Host and Device : Added support for CMSIS-RTOS2 USART: Corrected ARM_USART_SET_IRDA_PULSE control Updated Board drivers: Updated Board Support LED_*.c files. Updated Examples: Updated emWin examples to emWin V5.46e. Updated USB Host examples thread stack settings Keil.STM32F2xx_DFP.2.9.0.pack Version: 2.9.0 更新记录: 将 stm32f2xx_hal_conf.h 版本增加到 1.2.1。 CMSIS 驱动程序: 添加了对 Arm Compiler 6 的支持。 能够: 更正了中止消息发送功能。 SPI: 使 I/O 速度可配置。 更正了主模式下的数据移位寄存器溢出。 美国艺术学院: 使 I/O 速度可配置。电路板示例: 更新了所有示例: 将事件记录器放入未初始化的内存区域。 使用 ARM.CMSIS-Driver.2.2.0.pack 和 ARM.CMSIS.5.3.0.pack。 添加了网络 SNMP_Agent 示例。 Keil.STM32F3xx_DFP.2.1.0.pack Version: 2.1.0 更新记录: This DFP works either with STM32CubeMX (STM32CubeMX V4.23.0 and STM32Cube_FW_F3 V1.9.0 or higher)or Standalone (no support for STM32CubeMX)。 STM32CubeMX is mandatory for use of CMSIS-Driver and MDK-Middleware. This packs contains a subset of the files from STM32Cube_FW_F3 version 1.9.0 (Drivers, STCube documentation and fonts)。 Updated documentation for STM32Cube Framework usage. New projects require the component ‘Device:STM32Cube Framework:STM32CubeMX’ for configuration of pins and clocks via STM32CubeMX. Device support: Removed devices not being supported by STM32CubeMX 4.23.0 (STM32F301C6Yx, STM32F301K6Tx)。 Added DBGMCU INI files for use with debug adapter that lack support for debug descriptions. Board support: 添加了 STM32303S-EVAL 板和示例项目的板支持接口。 示例项目: 为 STM32303E-EVAL 添加了 emWin 示例。 添加了 STM32303S-EVAL 的示例项目。 更新了每个目标的分离输出文件夹的所有示例:“调试”输出文件夹“调试”目标,“发布”目标的“发布”输出文件夹 。 Keil.STM32F4xx_DFP.2.15.0.pack Version: 2.14.0 更新记录: Warning: --C99 is no longer enforced via the device description. Enable ‘C99 Mode’ in ‘Options for Target’ dialog’s ‘C/C++’ tab. Updated Pack to include subset of STM32Cube_FW_F4 Firmware Package version V1.24.1 using HAL Drivers V1.7.6. Corrected RTE_Device.h UART5 pin configuration. MX_Device_h.ftl: Updated parsing of USART virtual mode. Updated generation of macros: Added handling for ‘(’ and ‘)’ symbols. Corrected launching STM32CubeMX via “play” button for existing projects overwrites with a new STM32CubeMX project file instead of loading existing project. Updated SVD files: Added SPI4RST missing field to STM32F401xE.svd, STM32F411xx.svd and STM32F412xG.svd. Updated Flash Algorithm: Added new target for STM32F4xx_1536.FLM including fix for GetSecNum() in this target. Updated Boards Examples: MCBSTM32F400: Added USB Device RNDIS example. GUI_VNC example GUIThread priority corrected from osPriorityIdle to osPriorityNormal. Updated File System Demo: corrected invalid free space value shown in case of unmounted drives. Graphics examples use Segger emWin version 5.50.0. All examples: Enable Event Recorder in debug targets. Updated LCDConf.c (ready for GUI_USE_ARGD = 1)。 Terminating app_main thread with osThreadExit() to avoid endless loop. CMSIS-Driver All: corrected compiler warnings if GNU extensions is enabled in C/C++ settings for ARM Compiler 5. CAN: Corrected SetBitrate function to leave Silent and Loopback mode as they were. Corrected SetMode function to clear Silent and Loopback mode when NORMAL mode is activated. Corrected MessageSend function to only access required data for sending. EMAC: ETH DMA initialization is done when MAC transmitter or receiver is enabled 。 I2C: Corrected 10-bit addressing mode. Corrected ARM_I2C_EVENT_BUS_CLEAR event signaling. Replaced dead loop waiting with waiting with timeout. SPI: Added checking if pointer to SPI_PIN is valid, before it is used. USART: 更正了 POWER_OFF 序列。DMA 在中止后被取消初始化。 添加了在使用之前检查指向 USART_PIN 的指针是否有效。 USB 设备: 更新了 USBD_EndpointConfigure 函数以检查请求的最大数据包大小是否适合配置的 FIFO(编译时间配置)。 修正了 STM32F469xx 和 STM32F479xx 器件的 VBUS 检测。 更正了 USBD_PowerControl 功能,以便在未启用外部 PHY 时不启用 ULPI 时钟。 Keil.STM32F7xx_DFP.2.14.0.pack Version: 2.12.0更新记录: Updated Pack to include subset of STM32Cube_FW_F7 Firmware Package version V1.15.0 using HAL Drivers V1.2.7 Added support for Low Level (LL) drivers. Corrected RTE_Device.h file (I2C3_SDA) Corrected condition for selecting HAL RCC MX_Device_h.ftl: Updated parsing of USART virtual mode Updated generation of macros: Added handling for ‘(’ and ‘)’ symbols Corrected launching STM32CubeMX via “play” button for existing projects overwrites with a new STM32CubeMX project file instead of loading existing. Updated Board Examples: graphics examples use Segger emWin version 5.50.0. examples enable Event Recorder in debug targets Updated LCDConf.c (ready for GUI_USE_ARGD = 1) CMSIS-Driver: CAN: Corrected SetBitrate function to leave Silent and Loopback mode as they were. Corrected SetMode function to clear Silent and Loopback mode when NORMAL mode is activated. Corrected MessageSend function to only access required data for sending. EMAC: Corrected __MEMORY_AT(x) define to be compliant with Arm Compiler 6. Corrected: ETH DMA initialization moved to enable of MAC transmitter or receiver solving netInitialize/netUnnitialize/netInitialize sequence. I2C: Corrected transfers for data sizes greater than 255 (Complete Reload handling)。 Corrected I2C_SlaveReceive functionality. Corrected code alignment. MCI: Added data cache handling. USART: 添加了在使用前检查指向 USART_PIN 的有效指针。 更正了 POWER_OFF 序列。DMA 在中止后被取消初始化。 USB 设备: 更新了 USBD_EndpointConfigure 函数以检查请求的最大数据包大小是否适合配置的 FIFO(编译时间配置)。 I/O 输出速度可配置 SPI: 更新 SPI_TRANSFER_INFO 结构 - tx_buf 类型从 uint8_t * 更改为 const uint8_t *。 添加了在使用前检查 SPI_PIN 的有效指针。 Keil.STM32H7xx_DFP.2.7.0.pack Version: 2.5.0 更新记录: 板支持: 添加了 STM32H7B3I_EVAL 板支持。 闪烁示例 Flash 编程: 更新了 1MB 闪存大小的 STM32H7xxxG 器件的内部 Flash 编程算法。 更新了 STM32H743I Eval Rev B01 (2015) 和 B03 (2018) 的外部 FMC-NOR 编程算法。 添加了对 STM32H747I Disco 板的外部 QSPI 编程算法的支持。 添加了对 STM32H750B-Disco 板的外部 MMC 编程算法的支持。 Keil.STM32G0xx_DFP.1.2.0.pack Version: 1.2.0更新记录: 将 STM32Cube 固件 G0 库更新至 V1.3.0 版本。 添加了 CubeMX 支持。 添加了以下设备支持: STM32G030、STM32G031、STM32G041 器件。 更新了设备文档。 更新了每个 STM32G0xx 子系列的 SVD 文件。 Keil.STM32G4xx_DFP.1.2.0.pack Version: 1.1.0 更新记录: STM32G4 系列设备支持的初始公开版本: 需要 STM32CubeMX 5.2 或更高版本和 STM32CubeG4 固件包 V1.0.0 添加调试序列: 配置 ETM Trace。 添加了对 STM32G474E-EVAL 的电路板支持: 添加了 Blinky 示例。 Keil.STM32L0xx_DFP.2.1.0.pack Version: 2.0.1 更新记录: 设备支持: 添加了 STM32L010 器件。 将 STM32L0 HAL 更新至 V1.10.0 更新了文档。 更新了 Flash Option 汇编程序文件。 CMSIS 驱动程序: USB设备: 更新了 USBD_EndpointConfigure 函数以检查请求的最大数据包大小是否适合配置的 FIFO(编译时间 配置)。 USB 设备:更正了非控制 IN 端点的传输计数 USART:更正了与 UARTx/USARTx 相关的打字错误 更正: 通过“播放”按钮为现有项目启动 STM32CubeMX 会使用新的 STM32CubeMX 项目文件覆盖而不是加载它。 MX_Device_h.ftl: 更新了 USART 虚拟模式的解析 更新的宏生成:添加了对 ‘(’ 和 ‘)’ 符号的处理 Keil.STM32L1xx_DFP.1.3.0.pack Version: 1.2.0 更新记录==: 更新了 STM32L1xx 器件支持文件。 添加了 STM32L162xE 设备支持。 添加了 STM32L100xxA 器件支持。 添加了 STM32L151xxX 器件支持。 添加了 STM32L152xxX 设备支持。 添加了 STM32L162xxX 设备支持。 添加了 STM32L162xxA 器件支持。 更新了文档。 返工组件启动。 重新设计的例子。 Keil.STM32L4xx_DFP.2.5.0.pack Version: 2.3.0更新记录: Updated STM32CubeL4 Firmware to version 1.15.0 (requires STM32CubeMX 5.5.0 or higher) Added device support for STM32L4P5 and STM32L4Q5 Series (reworked device descriptions) Flash Programming: Added support to the OSPI loader for the STM32L4P5x Disco Board and STM32L4Pxx/L4Qxx. Corrected: STM32L4Rx dualbank erase function Package Description (pdsc): Added capability to launch the Option Byte Loading after a Flash Download. Added new STM32Cube HAL Components: MMC, PKA and PSSI. Added new STM32Cube LL Component: PKA. Added a patch to stm32l4xx_hal_def.h to support ARM Compiler 6. FrameworkCubeMX_gpdsc.ftl: Added support for Timebase Source TIMx. CMSIS-Driver: USB Device: 更新了 USBD_EndpointConfigure 函数以检查请求的最大数据包大小是否适合 》configured FIFO(编译时间配置)。 添加了 STM32L412、STM32L422、STM32L432、STM32L433、STM32L442、STM32L443、》STM32L452 和 STM32L462 设备的驱动程序。 电路板支持: 更新了 CMSIS-RTOS 使用 osThreadExit() 终止 app_main 线程以避免无限循环的示例。 添加了 B-L475E-IOT01 板。 为 STM32L476G-EVAL 板添加了闪烁低功耗。 Keil.STM32L5xx_DFP.1.3.0.pack Version: 1.1.0 更新记录: STM32L5 设备系列支持包的初始公共版本: STM32L552 和 STM32L562 设备系列。 基于 STM32Cube L5 固件包版本 1.0.0。 推荐与 MDK 5.29 一起使用。 Keil.STM32MP1xx_DFP.1.3.0.pack Version: 1.2.0 更新记录: 从启动组件中删除了 production.config 文件并相应地更新了 shell 脚本。 更新了 STM32CubeMP1 固件包。 更新示例: 使用 osThreadExit() 终止 app_main 线程以避免无限循环 版本:1.1.0 更新记录: 添加了 STM32MP157C-DK2 探索板支持和示例。 更新了示例的内核和跟踪时钟配置。 Keil.STM32W1xx_DFP.1.0.0.pack Version: 1.0.0 更新记录: STM32W1 器件系列包的第一个发布版本。 Keil.STM32WBxx_DFP.1.1.0.pack Version: 1.1.0 更新记录: 添加了对 STM32WB35CExx/WB35CCxx 和 STM32WB50xxxx、STM32WB30xxxx 设备的支持。 更新 STM32WB55xG 器件和 SVD 文件。 修复 STM32WB55xG 器件的闪存大小。 |
2538 浏览 1 评论
1962 浏览 1 评论
1496 浏览 2 评论
984 浏览 2 评论
3144 浏览 2 评论
1316浏览 4评论
564浏览 3评论
843浏览 3评论
801浏览 3评论
830浏览 3评论
GMT+8, 2025-7-4 13:26 , Processed in 0.571839 second(s), Total 42, Slave 36 queries .
