STM32驱动LCD1602,不是很难,主要注意GPIO_Write(GPIOD,(GPIO_ReadOutputData(GPIOD) & 0xff00) | cmd);对电平的读取是整个驱动的核心,其他均与51驱动一致。
lcd.h文件 #ifndef __LCD_H__ #define __LCD_H__ #include “stm32f10x.h” #define LED0 PBout(5) #define LED1 PEout(5) #define RS PDout(9) #define RW PDout(10) #define EN PDout(11) void LCD_init(void); void Wcmd(u8 cmd); void Wdat(u8 dat); #endif lcd.c文件 #include “sys.h” #include “LCD.h” #include “delay.h” //发送命令 void Wcmd(u8 cmd) { RS = 0; RW = 0; EN = 1; GPIO_Write(GPIOD,(GPIO_ReadOutputData(GPIOD) & 0xff00) | cmd); delay_ms(2); EN = 0; } //发送数据 void Wdat(u8 dat) { RS = 1; RW = 0; EN = 1; GPIO_Write(GPIOD,(GPIO_ReadOutputData(GPIOD) & 0xff00) | dat); delay_ms(2); EN = 0; } // void LCD_init() { GPIO_InitTypeDef GPIO_Initlcd; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,ENABLE);// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE,ENABLE);// GPIO_Initlcd.GPIO_Mode=GPIO_Mode_Out_PP; //设置工作模式 GPIO_Initlcd.GPIO_Pin=GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11; //选定引脚 GPIO_Initlcd.GPIO_Speed=GPIO_Speed_50MHz; //选择工作频率 GPIO_Init(GPIOD,&GPIO_Initlcd); //控制寄存器写入 GPIO_Initlcd.GPIO_Mode=GPIO_Mode_Out_PP; //设置工作模式 GPIO_Initlcd.GPIO_Pin=GPIO_Pin_5; //选定引脚 GPIO_Initlcd.GPIO_Speed=GPIO_Speed_50MHz; //选择工作频率 GPIO_Init(GPIOB,&GPIO_Initlcd); GPIO_Initlcd.GPIO_Mode=GPIO_Mode_Out_PP; //设置工作模式 GPIO_Initlcd.GPIO_Pin=GPIO_Pin_5; //选定引脚 GPIO_Initlcd.GPIO_Speed=GPIO_Speed_50MHz; //选择工作频率 GPIO_Init(GPIOE,&GPIO_Initlcd); Wcmd(0x01); //清屏 Wcmd(0x02); //光标归位 Wcmd(0x06); //设置输入模式 Wcmd(0x0C); //显示设置 Wcmd(0x38); //功能设置 } 个人见解,感谢阅读。 |
2168 浏览 1 评论
1836 浏览 1 评论
1324 浏览 2 评论
865 浏览 2 评论
2205 浏览 2 评论
2110浏览 9评论
1020浏览 4评论
393浏览 3评论
722浏览 3评论
710浏览 3评论
GMT+8, 2025-4-9 16:47 , Processed in 0.496213 second(s), Total 44, Slave 38 queries .
