数码管动态显示
四位共阳极数码管,段码给0显示 main.c #include “sys.h” #include “delay.h” //#include “led.h” #include “num.h” int main(void) { RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //系统时钟设置PLL作为系统时钟 delay_init(); //初始化延时函数 NUM_MOVE(); //数码管动态函数 } num.c #include “num.h” #include “delay.h” //动态数码管段码 unsigned char seg[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //数码管初始化 void NUM_Init(void){ GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //使能GPIO端口时钟,数码管显示GPIO使能配置 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //位选使能 //段码设置 GPIO_InitStructure.GPIO_Pin = NUM_STATIC_GPIO; //数码管段选显示GPIO引脚配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz; //最高输出速率50MHz GPIO_Init(GPIOD, &GPIO_InitStructure); //IO口初始化 //位选设置 GPIO_InitStructure.GPIO_Pin = NUM_STATIC_BIT; //数码管位选显示GPIO引脚配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz; //最高输出速率50MHz GPIO_Init(GPIOC, &GPIO_InitStructure); //IO口初始化 GPIO_ResetBits(GPIOC, NUM_STATIC_BIT); //给数码管位码置0 } //数码管动态函数 void NUM_MOVE(void){ uint16_t i; NUM_Init(); while(1) { for(i=0;i《16;i++) { GPIO_Write(GPIOD,seg[i]); //段码输出 delay_ms(3000); } } } num.h #include “sys.h” //段码引脚 #define NUM_STATIC_GPIO GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7 #define NUM_STATIC_BIT GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3 //数码管动态函数 void NUM_MOVE(void); |
1298 浏览 1 评论
1310 浏览 1 评论
721 浏览 2 评论
531 浏览 2 评论
1327 浏览 2 评论
1729浏览 9评论
439浏览 4评论
392浏览 3评论
380浏览 3评论
360浏览 3评论
GMT+8, 2024-9-20 20:28 , Processed in 0.792644 second(s), Total 46, Slave 40 queries .
