一。EMIF介绍
CE空间:EMIF就是外部接入接口知识DSP上的接口,用于服务接口设备。CPU与外部接入的连接口。在上面的位置芯片参考图。 它的结构如下: 位的作用及配置:https ://blog.csdn.net/app_12062011/article/details8/786959 EMIF支持的地点: 1 异步下载,包括ROM,FLASH, 异步SRAM 2 同步发生动态降落(SBSRAM ) 3同步动态下载(SDRAM ) 二。EMIF 设计 EMIF 的设计要针对不同的地点,C55x 设置了 4 个片选信号 CE0~CE3,直接作为外部地点的选通信号 。EMIF编程实验 最重要的是配置 寄存器与SDRAM连接的配置过程: 配置开始->网络控制配置EMIF->CE空间内存配置SDRAM空间>SDCTLSDRAM工作模式->SDTIM配置刷新模式->配置扩展功能->配置结束 (就是通过EMIF的电路去控制SDRAM的接口?) 总的程序 /******************************************************************************/ /******************************************************************************/ /*----------------------------------------------------------------------------*/ /* MODULE NAME... EMIF */ /* FILENAME...... emif.c */ /* DATE CREATED.. Wed 2/4/2004 */ /* PROJECT....... write and read data between the CPU and SDRAM */ /* COMPONENT..... */ /* PREREQUISITS.. */ /*----------------------------------------------------------------------------*/ /*----------------------------------------------------------------------------*/ /* DESCRIPTION: */ /* */ /* This is an example for EMIF of C5509 */ /*----------------------------------------------------------------------------*/ #include #include #include #include #include Uint16 x; Uint32 y; CSLBool b; unsigned int datacount = 0; int databuffer[1000] ={0}; int *souraddr,*deminaddr; /*锁相环的设置*/ PLL_Config myConfig = { 0, //IAI: the PLL locks using the same process that was underway //before the idle mode was entered 1, //IOB: If the PLL indicates a break in the phase lock, //it switches to its bypass mode and restarts the PLL phase-locking //sequence 20, //PLL multiply value; multiply 24 times 1 //Divide by 2 PLL divide value; it can be either PLL divide value //(when PLL is enabled), or Bypass-mode divide value //(PLL in bypass mode, if PLL multiply value is set to 1) }; /*SDRAM的EMIF设置*/ EMIF_Config emiffig = { 0x221, //EGCR : the MEMFREQ = 00,the clock for the memory is equal to cpu frequence // the WPE = 0 ,forbiden the writing posting when we debug the EMIF // the MEMCEN = 1,the memory clock is reflected on the CLKMEM pin // the NOHOLD = 1,HOLD requests are not recognized by the EMIF 0xFFFF, //EMI_RST: any write to this register resets the EMIF state machine 0x3FFF, //CE0_1: CE0 space control register 1 // MTYPE = 011,Synchronous DRAM(SDRAM),16-bit data bus width 0xFFFF, //CE0_2: CE0 space control register 2 0x00FF, //CE0_3: CE0 space control register 3 // TIMEOUT = 0xFF; 0x7FFF, //CE1_1: CE0 space control register 1 0xFFFF, //CE1_2: CE0 space control register 2 0x00FF, //CE1_3: CE0 space control register 3 0x7FFF, //CE2_1: CE0 space control register 1 0xFFFF, //CE2_2: CE0 space control register 2 0x00FF, //CE2_3: CE0 space control register 3 0x7FFF, //CE3_1: CE0 space control register 1 0xFFFF, //CE3_2: CE0 space control register 2 0x00FF, //CE3_3: CE0 space control register 3 0x2911, //SDC1: SDRAM control register 1 // TRC = 8 // SDSIZE = 0;SDWID = 0 // RFEN = 1 // TRCD = 2 // TRP = 2 0x0410, //SDPER : SDRAM period register // 7ns *4096 0x07FF, //SDINIT: SDRAM initialization register // any write to this register to init the all CE spaces, // do it after hardware reset or power up the C55x device 0x0131 //SDC2: SDRAM control register 2 // SDACC = 0; // TMRD = 01; // TRAS = 0101; // TACTV2ACTV = 0001; }; main() { unsigned int error=0; /*初始化CSL库*/ CSL_init(); /*EMIF为全EMIF接口*/ CHIP_RSET(XBSR,0x0a01); /*设置系统的运行速度为120MHz*/ PLL_config(&myConfig); /*初始化DSP的外部SDRAM*/ EMIF_config(&emiffig); /*向SDRAM中写入数据*/ souraddr = (int *)0x40000; deminaddr = (int *)0x41000; while(souraddr *souraddr++ = datacount; //address : 40000-41000 write in : 0-1000 datacount++ ; } /*读出SDRAM中的数据*/ souraddr = (int *)0x40000; datacount = 0; while(souraddr databuffer[datacount++] = *souraddr++; printf("%dn",databuffer[datacount-1]); if(databuffer[datacount-1]!=(datacount-1)) error++; //printf("%d",datacount-1); } if(error==0) { printf("SDRAM test completed! No Error!"); } while(1); } /****************************************************************************** * End of pll2.c ******************************************************************************/ |
5315个成员聚集在这个小组
加入小组3573 浏览 0 评论
4472 浏览 1 评论
4532 浏览 0 评论
GMT+8, 2025-7-12 09:06 , Processed in 0.583844 second(s), Total 46, Slave 38 queries .
