项目需要在调试STM32时遇到外部晶振,查看RCC_CR芯片的时刻时刻总是出现0次,表示外部振发生第一个状态:
HSE当开启时,HSERDY出现,则芯片会启动内部16Mhz晶振,但此时PLL分频注入,整个系统降到16Mhz,无法持续,立即启动内部的HSI为系统,同时通过配置PLL,将系统配置到 168Mhz, 因为系统设置源是在系统启动厚,主之前设置的,在SetSysClock(),首先需要自己设置HSI为系统函数源,代码如下: /** * @brief 将 HSI 配置为系统时钟源 **/ void HSI_SetSysClock() { __IO uint32_t HSIStartUpStatus = 0; RCC_DeInit(); //设置恒指 RCC_HSICmd(启用); HSIStartUpStatus = RCC-》CR & RCC_CR_HSIRDY; 如果(HSIStartUpStatus == RCC_CR_HSIRDY) { /* 选择稳压器电压输出 Scale 1 模式 */ RCC-》APB1ENR |= RCC_APB1ENR_PWREN; PWR-》CR |= PWR_CR_VOS; // HCLK = SYSCLK / 1 RCC_HCLKConfig(RCC_SYSCLK_Div1); /* HCLK = SYSCLK / 1*/ RCC-》CFGR |= RCC_CFGR_HPRE_DIV1; #if 定义(STM32F40_41xxx) || 定义(STM32F427_437xx) || 定义(STM32F429_439xx) || 定义(STM32F412xG) || 定义(STM32F446xx) || 定义(STM32F469_479xx) /* PCLK2 = HCLK / 2*/ RCC-》CFGR |= RCC_CFGR_PPRE2_DIV2; /* PCLK1 = HCLK / 4*/ RCC-》CFGR |= RCC_CFGR_PPRE1_DIV4; #endif /* STM32F40_41xxx || STM32F427_437x || STM32F429_439xx || STM32F412xG || STM32F446xx || STM32F469_479xx */ #if 已定义(STM32F401xx) || 定义(STM32F413_423xx) /* PCLK2 = HCLK / 1*/ RCC-》CFGR |= RCC_CFGR_PPRE2_DIV1; /* PCLK1 = HCLK / 2*/ RCC-》CFGR |= RCC_CFGR_PPRE1_DIV2; #endif /* STM32F401xx || STM32F413_423xx */ #if 定义(STM32F40_41xxx) || 定义(STM32F427_437xx) || 定义(STM32F429_439xx) || 定义(STM32F401xx) || 定义(STM32F469_479xx) /* 配置主锁相环 */ RCC-》PLLCFGR = HSI_PLL_M | (PLL_N 《《 6》) | (((PLL_P 》》 1) -1) 《《 16》 | (RCC_PLLCFGR_PLLSRC_HSI) | (PLL_Q 《《 24》); #endif /* STM32F40_41xxx || STM32F401xx || STM32F427_437x || STM32F429_439xx || STM32F469_479xx */ #if 定义(STM32F412xG) || 定义(STM32F413_423xx) || 定义(STM32F446xx) /* 配置主锁相环 */ RCC-》PLLCFGR = HSI_PLL_M | (PLL_N 《《 6》) | (((PLL_P 》》 1) -1) 《《 16》 | (RCC_PLLCFGR_PLLSRC_HSI) | (PLL_Q 《《 24》) | (PLL_R 《《 28》); #endif /* STM32F412xG || STM32F413_423xx || STM32F446xx */ /* 启用主 PLL */ RCC-》CR |= RCC_CR_PLLON; /* 等到主 PLL 准备就绪 */ 而(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } #if 定义(STM32F427_437xx) || 定义(STM32F429_439xx) || 定义(STM32F446xx) || 定义(STM32F469_479xx) /* 启用 Over-drive 将时钟频率扩展到 180 Mhz */ PWR-》CR |= PWR_CR_ODEN; 而((PWR-》CSR & PWR_CSR_ODRDY) == 0) { } PWR-》CR |= PWR_CR_ODSWEN; 而((PWR-》CSR & PWR_CSR_ODSWRDY) == 0) { } /* 配置Flash预取、指令缓存、数据缓存和等待状态*/ FLASH-》ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS; #endif /* STM32F427_437x || STM32F429_439xx || STM32F446xx || STM32F469_479xx */ #if 定义(STM32F40_41xxx) || 定义(STM32F412xG) /* 配置Flash预取、指令缓存、数据缓存和等待状态*/ FLASH-》ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS; #endif /* STM32F40_41xxx || STM32F412xG */ #if 定义(STM32F413_423xx) /* 配置Flash预取、指令缓存、数据缓存和等待状态*/ FLASH-》ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_3WS; #endif /* STM32F413_423xx */ #if 定义(STM32F401xx) /* 配置Flash预取、指令缓存、数据缓存和等待状态*/ FLASH-》ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_2WS; #endif /* STM32F401xx */ /* 选择主 PLL 作为系统时钟源 */ RCC-》CFGR &=(uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC-》CFGR |= RCC_CFGR_SW_PLL; /* 等到主 PLL 用作系统时钟源 */ 而((RCC-》CFGR & (uint32_t)RCC_CFGR_SWS )!= RCC_CFGR_SWS_PLL); { } } } 将上述代码添加到,设置外部时钟源失败异常处理流程SetSysClock()函数中: 系统恢复如初,系统时钟源恢复到168Mhz,很开心。 |
1307 浏览 1 评论
1319 浏览 1 评论
729 浏览 2 评论
537 浏览 2 评论
1341 浏览 2 评论
1733浏览 9评论
448浏览 4评论
396浏览 3评论
386浏览 3评论
365浏览 3评论
GMT+8, 2024-9-22 01:32 , Processed in 0.781650 second(s), Total 78, Slave 62 queries .
