void adc_init(void)
{ ADC_InitTypeDef ADC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_ADCCLKConfig(RCC_ADCCLK_PCLK_Div4);//配置ADC的时钟频率 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); //ADC-IN:PA4~7 GPIO_InitStructure.GPIO_Pin= GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA,&GPIO_InitStructure); //ADC1配置 ADC_DeInit(ADC1); ADC_StructInit(&ADC_InitStructure);//结构体初始化里面包含ADC设置,例如AD位,触发模式,转换模式,对齐等 ADC_Init(ADC1, &ADC_InitStructure); // ADC Calibration ADC_GetCalibrationFactor(ADC1); // Enable the ADC1 ADC_Cmd(ADC1,ENABLE); while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADEN)); } //得到并返回ADC_index //ch:ADC通道 uint16_t adc_index_get(uint8_t ch) { uint16_t adc_index; ADC_ClearFlag(ADC1, ADC_FLAG_EOC); //设置指定ADC的规则组通道,设置它们的转化顺序和采样时间 //通道选择寄存器ADC1-》CHSELR赋值至关重要,少了没法实现多通道采集 if(ch==4) { ADC_ChannelConfig(ADC1, ADC_Channel_4 , ADC_SampleTime_239_5Cycles); ADC1-》CHSELR =ADC_Channel_4; } if(ch= =5) { ADC_ChannelConfig(ADC1, ADC_Channel_5 , ADC_SampleTime_239_5Cycles); ADC1-》CHSELR =ADC_Channel_5; } if(ch= =6) { ADC_ChannelConfig(ADC1, ADC_Channel_6 , ADC_SampleTime_239_5Cycles); ADC1-》CHSELR =ADC_Channel_6; } if(ch= =7) { ADC_ChannelConfig(ADC1, ADC_Channel_7 , ADC_SampleTime_239_5Cycles); ADC1-》CHSELR =ADC_Channel_7; } while(ADC_GetFlagStatus(ADC1, ADC_FLAG_ADRDY) == RESET); ADC_StartOfConversion(ADC1); while(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)!=1){} //等待ADC转换完成 adc_index = ADC_GetConversionValue(ADC1); ADC_StopOfConversion(ADC1); return adc_index; } if条件的()里面编辑时多了一个空格,否则编辑时没法正常显示 //多次采样获得平均值 //ch:ADC通道; times:采样次数 uint16_t get_adc_average(uint8_t ch,uint8_t times) { uint32_t temp_val = 0; uint8_t t; for(t=0; t《times; t++) { temp_val += adc_index_get(ch); delay_ms(5); } return (temp_val / times); } |
2082 浏览 1 评论
1819 浏览 1 评论
1292 浏览 2 评论
846 浏览 2 评论
1846 浏览 2 评论
2080浏览 9评论
992浏览 4评论
369浏览 3评论
709浏览 3评论
694浏览 3评论
GMT+8, 2025-3-26 01:57 , Processed in 0.812984 second(s), Total 47, Slave 41 queries .
