报错:
读出的设备ID,厂商ID等是正确的,但是检测出来不符合SFDP标准。 [SFUD](。.。.。.sfudsrcsfud.c:116) Start initialize Serial Flash Universal Driver(SFUD) V1.1.0. [SFUD](。.。.。.sfudsrcsfud.c:117) You can get the latest version on https://github.com/armink/SFUD 。 [SFUD](。.。.。.sfudsrcsfud.c:861) The flash device manufacturer ID is 0xEF, memory type ID is 0x40, capacity ID is 0x16. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:122) Error: Check SFDP signature error. It‘s must be 50444653h(’S‘ ’F‘ ’D‘ ’P‘)。 [SFUD]Warning: Read SFDP parameter header information failed. The W25Q32BV is not support JEDEC SFDP. [SFUD]Find a Winbond W25Q32BV flash chip. Size is 4194304 bytes. [SFUD](。.。.。.sfudsrcsfud.c:840) Flash device reset success. [SFUD]W25Q32BV flash device is initialize success. [SFUD]Error: Can’t enable write status. Erase the W25Q32BV flash data failed.stud_flash_def.h文件里,可以看到该FLASH已经适配。 sfud_cfg.h文件,添加接入的FLASH芯片,可添加多个 sfud_port.c修改引脚 注意:该处也需要修改,不然就会造成开头的错误!!! 测试成功:(使用 SFUDdemostm32f10x_non_os 的demo测试) [SFUD](。.。.。.sfudsrcsfud.c:116) Start initialize Serial Flash Universal Driver(SFUD) V1.1.0. [SFUD](。.。.。.sfudsrcsfud.c:117) You can get the latest version on https://github.com/armink/SFUD 。 [SFUD](。.。.。.sfudsrcsfud.c:861) The flash device manufacturer ID is 0xEF, memory type ID is 0x40, capacity ID is 0x16. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:131) Check SFDP header is OK. The reversion is V1.5, NPN is 0. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:173) Check JEDEC basic flash parameter header is OK. The table id is 0, reversion is V1.5, length is 16, parameter table pointer is 0x000080. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:203) JEDEC basic flash parameter table info: [SFUD](。.。.。.sfudsrcsfud_sfdp.c:204) MSB-LSB 3 2 1 0 [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0001] 0xFF 0xF9 0x20 0xE5 [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0002] 0x01 0xFF 0xFF 0xFF [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0003] 0x6B 0x08 0xEB 0x44 [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0004] 0xBB 0x42 0x3B 0x08 [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0005] 0xFF 0xFF 0xFF 0xFE [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0006] 0x00 0x00 0xFF 0xFF [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0007] 0xEB 0x40 0xFF 0xFF [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0008] 0x52 0x0F 0x20 0x0C [SFUD](。.。.。.sfudsrcsfud_sfdp.c:206) [0009] 0x00 0x00 0xD8 0x10 [SFUD](。.。.。.sfudsrcsfud_sfdp.c:215) 4 KB Erase is supported throughout the device. Command is 0x20. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:234) Write granularity is 64 bytes or larger. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:245) Target flash status register is non-volatile. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:271) 3-Byte only addressing. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:305) Capacity is 4194304 Bytes. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:311) Flash device supports 4KB block erase. Command is 0x20. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:311) Flash device supports 32KB block erase. Command is 0x52. [SFUD](。.。.。.sfudsrcsfud_sfdp.c:311) Flash device supports 64KB block erase. Command is 0xD8. [SFUD]Find a Winbond flash chip. Size is 4194304 bytes. [SFUD](。.。.。.sfudsrcsfud.c:840) Flash device reset success. [SFUD]W25Q32BV flash device is initialize success. [11:51:02.988]收←◆Erase the W25Q32BV flash data finish. Start from 0x00000000, size is 1024. Write the W25Q32BV flash data finish. Start from 0x00000000, size is 1024. Read the W25Q32BV flash data success. Start from 0x00000000, size is 1024. The data is: Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000000] 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000010] 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F [00000020] 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F [00000030] 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F [00000040] 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F [00000050] 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F [00000060] 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F [00000070] 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F [00000080] 80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F [00000090] 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F [000000A0] A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF [000000B0] B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF [000000C0] C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF [000000D0] D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF [000000E0] E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF [000000F0] F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF [00000100] 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000110] 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F [00000120] 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F [00000130] 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F [00000140] 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F [00000150] 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F [00000160] 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F [00000170] 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F [00000180] 80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F [00000190] 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F [000001A0] A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF [000001B0] B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF [000001C0] C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF [000001D0] D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF [000001E0] E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF [000001F0] F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF [00000200] 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000210] 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F [00000220] 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F [00000230] 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F [00000240] 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F [00000250] 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F [00000260] 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F [00000270] 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F [00000280] 80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F [00000290] 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F [000002A0] A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF [000002B0] B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF [000002C0] C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF [000002D0] D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF [000002E0] E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF [000002F0] F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF [00000300] 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000310] 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F [00000320] 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F [00000330] 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F [00000340] 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F [00000350] 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F [00000360] 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F [00000370] 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F [00000380] 80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F [00000390] 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F [000003A0] A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF [000003B0] B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF [000003C0] C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF [000003D0] D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF [000003E0] E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF [000003F0] F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF The W25Q32BV flash test is success. |
4770个成员聚集在这个小组
加入小组3414 浏览 0 评论
4327 浏览 1 评论
4367 浏览 0 评论
GMT+8, 2025-2-24 14:47 , Processed in 0.631412 second(s), Total 75, Slave 59 queries .
