最近用到电磁式蜂鸣器,由于电源部分处理的不好,对电流的实时大小要有很明确的数值,平时用的万用表就派不上用场了,只好找了一款电流检测IC-Max471。
MAX471 是一款精密高端的电流检测放大器,在很多应用场景下都可以用的到,如电池/DC电源供电的系统中可以见到。 MAX471主要有一下特性: © Complete High-Side Current Sensing © Precision Internal Sense Resistor (MAX471) © 2% Accuracy Over Temperature © Monitors Both Charge and Discharge © 3A Sense Capability with Internal Sense Resistor (MAX471) © Higher Current-Sense Capability with External Sense Resistor (MAX472) © 100µA Max Supply Current © 18µA Max Shutdown Mode © 3V to 36V Supply Operation © 8-Pin DIP/SO Packages 下面直接就是典型应用电路: |
GMT+8, 2024-9-20 19:55 , Processed in 0.483135 second(s), Total 46, Slave 40 queries .
