1、FSMC简介:FSMC即灵活的静态存储控制器,FSMC管理1GB空间,拥有4个Bank连接外部存储器,每个Bank有独立的片选信号和独立的时序配置;支持的存储器类型有SRAM、PSRAM、NOR/ONENAND、ROM、LCD接口(支持8080和6800模式)、NANDFlash和16位的PCCard。
2、在设计中将FPGA当做SRAM来驱动,使用库函数来实现FSMC的初始化配置代码如下: //初始化外部SRAM void FSMC_SRAM_Init(void) { FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure; //定义FSMC初始化的结构体变量 FSMC_NORSRAMTimingInitTypeDef readWriteTiming; //用来设置FSMC读时序和写时序的指针变量 GPIO_InitTypeDef GPIO_InitStructure; //初始化FSMC总线的IO口 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE|RCC_APB2Periph_AFIO,ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE); //开启FSMC的时钟 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_14 |GPIO_Pin_15|GPIO_Pin_0|GPIO_Pin_1 |GPIO_Pin_7|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_4|GPIO_Pin_5; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //IO口配置为复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9 |GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOE, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_6; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOE, &GPIO_InitStructure); readWriteTiming.FSMC_AddressSetupTime = 14; readWriteTiming.FSMC_AddressHoldTime = 0x00; readWriteTiming.FSMC_DataSetupTime = 16; readWriteTiming.FSMC_BusTurnAroundDuration = 0; readWriteTiming.FSMC_CLKDivision = 0x00; readWriteTiming.FSMC_DataLatency = 0x00; readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; FSMC_NORSRAMInitStructure.FSMC_Bank=FSMC_Bank1_NORSRAM1; FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM; FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth= FSMC_MemoryDataWidth_16b; FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode=FSMC_BurstAccessMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable; FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable; FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable; FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE); delay_ms(50); } FPGA代码: //fsmc read / write ep4ce6 demo module fsmc( ab, //address db, //data wrn, //wr rdn, //rd resetn, //resetn csn, //cs clk ); input[2:0] ab; inout[15:0] db; input wrn; input rdn; input resetn; input csn; input clk; reg [15:0] ina = 16‘d0; //存储数据供ARM读 reg [15:0] inb = 16’d1; reg [15:0] inc = 16‘d2; reg [15:0] ind = 16’d3; reg [15:0] ine = 16‘d4; reg [15:0] inf = 16’d5; reg [15:0] ing = 16‘d6; reg [15:0] inh = 16’d7; reg [15:0] outa; reg [15:0] outb; reg [15:0] outc; reg [15:0] outd; reg [15:0] oute; reg [15:0] outf; reg [15:0] outg; reg [15:0] outh; wire rd; wire wr; reg [15:0] indata; assign rd = !csn & !rdn; // orignal code : !(csn & rdn) = !csn | !rdn (摩根定律) get rd pulse ____|~~~~|______ assign wr = !csn & !wrn; //orignal code : !(csn & wrn) = !csn | !wrn (摩根定律) get wr pulse ____|~~~~|______ /*********当不进行读写操作时db=indata********* *********当进行写操作时db=16‘hzzzz********** *********当进行读操作时db=indata**********/ assign db = rd? indata:16’hzzzz; //write data, 根据地址线选择八个空间写入,每个空间16位 always @(negedge wr or negedge resetn) begin if(!resetn)begin outa 《= 16‘h0000; outb 《= 16’h0000; outc 《= 16‘h0000; outd 《= 16’h0000; oute 《= 16‘h0000; outf 《= 16’h0000; outg 《= 16‘h0000; outh 《= 16’h0000; end else begin case (ab) 3‘b000:outa 《= db; 3’b001:outb 《= db; 3‘b010:outc 《= db; 3’b011:outd 《= db; 3‘b100:oute 《= db; 3’b101:outf 《= db; 3‘b110:outg 《= db; 3’b111:outh 《= db; default:; endcase end end //red data 根据地址线选择8个空间读取,每个空间 16位 always @(rd or !resetn) begin if(!resetn)indata 《= 16‘h0000; else begin case (ab) 3’b000:indata 《= ina; 3‘b001:indata 《= inb; 3’b010:indata 《= inc; 3‘b011:indata 《= ind; 3’b100:indata 《= ine; 3‘b101:indata 《= inf; 3’b110:indata 《= ing; 3‘b111:indata 《= inh; default:; endcase end end endmodule |
1957 浏览 1 评论
1740 浏览 1 评论
1209 浏览 2 评论
800 浏览 2 评论
1765 浏览 2 评论
2010浏览 9评论
859浏览 4评论
303浏览 3评论
653浏览 3评论
654浏览 3评论
GMT+8, 2025-2-12 19:33 , Processed in 0.880550 second(s), Total 75, Slave 59 queries .
