51单片机 16X192点阵程序动态显示任意汉字
程序参考源代码如下: #include ***it ST=P3^5; ***it E1=P3^4; ***it MR=P3^7; char cashe[12]; char code wd[12][16]={ {0xFF,0xC0,0xFE,0xFE,0xFE,0xFE,0x80,0xFE,0xFD,0xFD,0xFB,0xF7,0xEF,0xDF,0x3F,0xFF}, {0xFF,0x03,0xFF,0xFF,0xFF,0xFF,0x01,0x7F,0x7F,0x7F,0x7F,0x7F,0x7D,0x7D,0x81,0xFF},/“无”,0/ /* (16 X 16 , 宋体 )*/ {0xDF,0xDF,0xDF,0xCF,0x57,0x58,0x5F,0xDF,0xDE,0xDE,0xDE,0xDD,0xDD,0xDB,0xDB,0xD7}, {0x7F,0x6F,0x73,0x77,0x7F,0x01,0x5F,0x5F,0xDF,0xDF,0xDF,0xDF,0xDD,0xDD,0xE1,0xFF},/“忧”,1/ /* (16 X 16 , 宋体 )*/ {0xFE,0xFE,0xFE,0xC0,0xDE,0xDE,0xC0,0xDE,0xDE,0xDE,0xC0,0xDE,0xFE,0xFE,0xFF,0xFF}, {0xFF,0xFF,0xFF,0x07,0xF7,0xF7,0x07,0xF7,0xF7,0xF7,0x07,0xF7,0xFD,0xFD,0x01,0xFF},/“电”,2/ /* (16 X 16 , 宋体 )*/ {0xFF,0xC0,0xFF,0xFF,0xFF,0xFE,0xFE,0xFE,0x00,0xFE,0xFE,0xFE,0xFE,0xFE,0xFA,0xFD}, {0xFF,0x0F,0xDF,0xBF,0x7F,0xFF,0xFF,0xFB,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/“子”,3/ /* (16 X 16 , 宋体 )*/ {0xFF,0x83,0xBB,0xAB,0xAA,0xAA,0xA9,0xAB,0xAB,0xAA,0xEE,0xD7,0xDB,0xBB,0x7F,0xFF}, {0x7F,0x3F,0x7F,0x01,0xFD,0xFD,0xBD,0xBD,0x5D,0xED,0x05,0xED,0xFD,0xFD,0xEB,0xF7},/“购”,4/ /* (16 X 16 , 宋体 )*/ {0xEF,0xEF,0xAF,0xAE,0x82,0xAD,0x6B,0xEB,0xE6,0xCD,0x2B,0xEF,0xEE,0xED,0xEB,0xFF}, {0x7F,0x7F,0x7F,0x03,0xAB,0xAB,0x6B,0x6B,0xDB,0xDB,0xBB,0x7B,0xFB,0xFB,0xD7,0xEF},/“物”,5/ /* (16 X 16 , 宋体 )*/ }; void del(int i)//============================//延时程序 {while(i–);} aline() =======================发送一行的显示程序 { char i=0; TI=0; for(i=0;i<12;i++) {SBUF=cashe;while(~TI);TI=0;} //将缓存中的信息转存入595的存储器中,到此不显示 } main() { int m=0,n=0; TI=0; SM0=0; SM1=0; E1=0; while(1) for(m=0;m<16;m++) //共有16行 循环16次显示这16行 串行的595送出行的数据 { //由74hc154选中要显示的行 for(n=0;n<12;n++) //这个for循环用来向缓存数组中装载要显示的内容 {cashe[11-n]=wd[n][m];} //将第m个字的第n行信息装载 ,因为595串接 数据第一个进去的会在最后一个595中,最后进去的会在第一个595中 aline(); //将缓存中的一行信息载入595缓存中 ST=0;ST=1; //595产生上升沿 输出595锁存的数据 P2=m; //选中要显示的行输出数据 del(100);//延时一段时间,以造成视觉暂存效应 } } 最后,如果有什么意见或者建议欢迎您留言给我,让我们共同学习一起进步, 如果需要 程序完整源代码和 设计文件,请在下方留言或者私信我,看到后会第一时间回复。 谢谢! |
2572 浏览 0 评论
769浏览 1评论
529浏览 0评论
279浏览 0评论
467浏览 0评论
GMT+8, 2025-1-3 03:12 , Processed in 1.239257 second(s), Total 45, Slave 38 queries .
