Model Bus通信在工业上比较常用,最近需要开发与西门子PLC的model bus通信,需要读写连续地址,逻辑看起来没有问题,代码调试还没有做
private short[] ReadModelBus(ushort[] channel, int[] IO, out string msg) //可以写入多个IO或WORD { msg = “”; if (channel == null) { msg = “channel不能为空!”; return null; } if (IO != null) { if (channel.Length != IO.Length) { msg = “channel和IO值不一致!”; return null; } } ushort maxValue = channel.Max(); ushort minValue = channel.Min(); short[] datas = new short[maxValue - minValue]; int result = -1; bool bResult = tcpip.ReadMultiWordData(minValue, (ushort)(maxValue - minValue), datas, out result); //读出从最小到最大channel的所有的数据 if (!bResult) { if (result == -1) { msg = “不能连接PLC!”; return null; } else if (result != 0) { msg = string.Format(“Modbus TCP异常码={0:d02}”, result); return null; } } if (IO == null) { short[] RET_VALUE = new short[channel.Length]; for (int i = 0; i 《 channel.Length; i++) { RET_VALUE = (short)datas[channel - minValue]; } return RET_VALUE; } else { short[] RET_VALUE = new short[channel.Length]; for (int i = 0; i 《 channel.Length; i++) { RET_VALUE = (short)((datas[channel - minValue] 》》 IO) & 0x0001); } return RET_VALUE; } } |
GMT+8, 2025-4-5 10:16 , Processed in 0.598961 second(s), Total 78, Slave 57 queries .
