本节内容:
如何解决转速不流畅问题; 视频地址请观看 ODrive odrivetool 速度闭环控制 BLDC motor servo Open source odrv0.reboot() 重启ODrive start_liveplotter(lambda:[odrv0.axis1.encoder.vel_estimate,odrv0.axis1.controller.vel_setpoint]) 启动图形界面 odrv0.axis1.controller.vel_setpoint=100 设置速度为100个脉冲每秒 odrv0.axis1.controller.vel_setpoint=50 odrv0.axis1.controller.vel_setpoint=200 odrv0.axis1.controller.vel_setpoint=1440 odrv0.axis1.controller.vel_setpoint=14400设置速度为14400个脉冲每秒,即10转/秒,速度达不到设定 odrv0.axis1.controller.vel_setpoint=0 odrv0.axis1.motor.config.motor_type=MOTOR_TYPE_HIGH_CURRENT,将电机设定为大功率电机 odrv0.save_configuration(),保存配置 odrv0.reboot(),重启,测试闭环速度控制 odrv0.axis1.controller.vel_setpoint=14400,设置速度为14400个脉冲每秒,即10转/秒,速度已达到设定 odrv0.axis1.controller.vel_setpoint=0 odrv0.axis1.controller.vel_setpoint=100设置速度为100个脉冲每秒 odrv0.axis1.controller.vel_setpoint=200 odrv0.axis1.controller.vel_setpoint=300 odrv0.axis1.controller.vel_setpoint=500 odrv0.axis1.controller.vel_setpoint=50 odrv0.axis1.controller.vel_setpoint=1440设置速度为1440个脉冲每秒 odrv0.axis1.controller.vel_setpoint=28800 odrv0.axis1.controller.vel_setpoint=14400 odrv0.axis1.controller.vel_setpoint=0 低速时转动不稳定,调整PID参数 odrv0.axis1.controller.config.vel_gain odrv0.axis1.controller.config.vel_integrator_gain odrv0.axis1.controller.vel_setpoint=100 odrv0.axis1.controller.config.vel_integrator_gain=0.1速度环积分增益 odrv0.axis1.controller.vel_setpoint=50 odrv0.axis1.controller.config.pos_gain=10 odrv0.axis1.controller.config.pos_gain=5 odrv0.axis1.controller.vel_setpoint=100 odrv0.axis1.controller.vel_setpoint=200 odrv0.axis1.controller.config.vel_integrator_gain=0.5 odrv0.axis1.controller.config.vel_integrator_gain=0.2 odrv0.axis1.controller.config.vel_integrator_gain=0.1 odrv0.axis1.controller.config.vel_integrator_gain=0.05 odrv0.axis1.controller.vel_setpoint=50调整后转速稳定平缓 odrv0.axis1.controller.vel_setpoint=100 odrv0.axis1.controller.vel_setpoint=1000 odrv0.axis1.controller.vel_setpoint=10000 |
2494 浏览 0 评论
9491 浏览 4 评论
37307 浏览 19 评论
5126 浏览 0 评论
25360 浏览 34 评论
1811浏览 2评论
2087浏览 1评论
2578浏览 1评论
1829浏览 0评论
837浏览 0评论
GMT+8, 2025-3-7 03:59 , Processed in 1.226515 second(s), Total 75, Slave 59 queries .
