STM32 F4系列中断向量表
External Interrupts DCD WWDG_IRQHandler ; Window WatchDog DCD PVD_IRQHandler ; PVD through EXTI Line detection DCD TAMP_STAMP_IRQHandler ; Tamper and TimeStamps through the EXTI line DCD RTC_WKUP_IRQHandler ; RTC Wakeup through the EXTI line DCD FLASH_IRQHandler ; FLASH DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line0 DCD EXTI1_IRQHandler ; EXTI Line1 DCD EXTI2_IRQHandler ; EXTI Line2 DCD EXTI3_IRQHandler ; EXTI Line3 DCD EXTI4_IRQHandler ; EXTI Line4 DCD DMA1_Stream0_IRQHandler ; DMA1 Stream 0 DCD DMA1_Stream1_IRQHandler ; DMA1 Stream 1 DCD DMA1_Stream2_IRQHandler ; DMA1 Stream 2 DCD DMA1_Stream3_IRQHandler ; DMA1 Stream 3 DCD DMA1_Stream4_IRQHandler ; DMA1 Stream 4 DCD DMA1_Stream5_IRQHandler ; DMA1 Stream 5 DCD DMA1_Stream6_IRQHandler ; DMA1 Stream 6 DCD ADC_IRQHandler ; ADC1, ADC2 and ADC3s DCD CAN1_TX_IRQHandler ; CAN1 TX DCD CAN1_RX0_IRQHandler ; CAN1 RX0 DCD CAN1_RX1_IRQHandler ; CAN1 RX1 DCD CAN1_SCE_IRQHandler ; CAN1 SCE DCD EXTI9_5_IRQHandler ; External Line[9:5]s DCD TIM1_BRK_TIM9_IRQHandler ; TIM1 Break and TIM9 DCD TIM1_UP_TIM10_IRQHandler ; TIM1 Update and TIM10 DCD TIM1_TRG_COM_TIM11_IRQHandler ; TIM1 Trigger and Commutation and TIM11 DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare DCD TIM2_IRQHandler ; TIM2 DCD TIM3_IRQHandler ; TIM3 DCD TIM4_IRQHandler ; TIM4 DCD I2C1_EV_IRQHandler ; I2C1 Event DCD I2C1_ER_IRQHandler ; I2C1 Error DCD I2C2_EV_IRQHandler ; I2C2 Event DCD I2C2_ER_IRQHandler ; I2C2 Error DCD SPI1_IRQHandler ; SPI1 DCD SPI2_IRQHandler ; SPI2 DCD USART1_IRQHandler ; USART1 DCD USART2_IRQHandler ; USART2 DCD USART3_IRQHandler ; USART3 DCD EXTI15_10_IRQHandler ; External Line[15:10]s DCD RTC_Alarm_IRQHandler ; RTC Alarm (A and B) through EXTI Line DCD OTG_FS_WKUP_IRQHandler ; USB OTG FS Wakeup through EXTI line DCD TIM8_BRK_TIM12_IRQHandler ; TIM8 Break and TIM12 DCD TIM8_UP_TIM13_IRQHandler ; TIM8 Update and TIM13 DCD TIM8_TRG_COM_TIM14_IRQHandler ; TIM8 Trigger and Commutation and TIM14 DCD TIM8_CC_IRQHandler ; TIM8 Capture Compare DCD DMA1_Stream7_IRQHandler ; DMA1 Stream7 DCD FSMC_IRQHandler ; FSMC DCD SDIO_IRQHandler ; SDIO DCD TIM5_IRQHandler ; TIM5 DCD SPI3_IRQHandler ; SPI3 DCD UART4_IRQHandler ; UART4 DCD UART5_IRQHandler ; UART5 DCD TIM6_DAC_IRQHandler ; TIM6 and DAC1&2 underrun errors DCD TIM7_IRQHandler ; TIM7 DCD DMA2_Stream0_IRQHandler ; DMA2 Stream 0 DCD DMA2_Stream1_IRQHandler ; DMA2 Stream 1 DCD DMA2_Stream2_IRQHandler ; DMA2 Stream 2 DCD DMA2_Stream3_IRQHandler ; DMA2 Stream 3 DCD DMA2_Stream4_IRQHandler ; DMA2 Stream 4 DCD ETH_IRQHandler ; Ethernet DCD ETH_WKUP_IRQHandler ; Ethernet Wakeup through EXTI line DCD CAN2_TX_IRQHandler ; CAN2 TX DCD CAN2_RX0_IRQHandler ; CAN2 RX0 DCD CAN2_RX1_IRQHandler ; CAN2 RX1 DCD CAN2_SCE_IRQHandler ; CAN2 SCE DCD OTG_FS_IRQHandler ; USB OTG FS DCD DMA2_Stream5_IRQHandler ; DMA2 Stream 5 DCD DMA2_Stream6_IRQHandler ; DMA2 Stream 6 DCD DMA2_Stream7_IRQHandler ; DMA2 Stream 7 DCD USART6_IRQHandler ; USART6 DCD I2C3_EV_IRQHandler ; I2C3 event DCD I2C3_ER_IRQHandler ; I2C3 error DCD OTG_HS_EP1_OUT_IRQHandler ; USB OTG HS End Point 1 Out DCD OTG_HS_EP1_IN_IRQHandler ; USB OTG HS End Point 1 In DCD OTG_HS_WKUP_IRQHandler ; USB OTG HS Wakeup through EXTI DCD OTG_HS_IRQHandler ; USB OTG HS DCD DCMI_IRQHandler ; DCMI DCD CRYP_IRQHandler ; CRYP crypto DCD HASH_RNG_IRQHandler ; Hash and Rng DCD FPU_IRQHandler ; FPU |
1307 浏览 1 评论
1319 浏览 1 评论
729 浏览 2 评论
537 浏览 2 评论
1341 浏览 2 评论
1733浏览 9评论
448浏览 4评论
396浏览 3评论
385浏览 3评论
365浏览 3评论
GMT+8, 2024-9-21 22:03 , Processed in 0.877478 second(s), Total 75, Slave 59 queries .
