本文指导开发者在单板上运行第一个应用程序,其中包括新建应用程序、编译、烧写、运行等步骤,最终输出“Hello OHOS!”。
新建应用程序- 新建目录及源码
新建applications/sample/camera/apps/src/helloworld.c目录及文件,代码如下所示,用户可以自定义修改打印内容(例如:修改OHOS为World)。当前应用程序可支持标准C及C++的代码开发。
- #include <stdio.h>
- int main(int argc, char **argv)
- printf("n************************************************n");
- printf("nttHello OHOS!n");
- printf("n************************************************nn");
- return 0;
复制代码
- 新建编译组织文件
新建applications/sample/camera/apps/BUILD.gn文件,内容如下所示:
- import("//build/lite/config/component/lite_component.gni")
- lite_component("hello-OHOS") {
- features = [ ":helloworld" ]
- executable("helloworld") {
- output_name = "helloworld"
- sources = [ "src/helloworld.c" ]
- include_dirs = []
- defines = []
- cflags_c = []
- ldflags = []
复制代码
- 添加新组件
修改文件build/lite/components/applications.json,添加组件hello_world_app的配置,如下所示为applications.json文件片段,"##start##"和"##end##"之间为新增配置("##start##"和"##end##"仅用来标识位置,添加完配置后删除这两行):
- "components": [
- "component": "camera_sample_communication",
- "description": "Communication related samples.",
- "optional": "true",
- "dirs": [
- "applications/sample/camera/communication"
- "targets": [
- "//applications/sample/camera/communication:sample"
- "rom": "",
- "ram": "",
- "output": [],
- "adapted_kernel": [ "liteos_a" ],
- "features": [],
- "deps": {
- "components": [],
- "third_party": []
- ##start##
- "component": "hello_world_app",
- "dirs": [
- "applications/sample/camera/apps"
- "targets": [
- "//applications/sample/camera/apps:hello-OHOS"
- "rom": "",
- "ram": "",
- "output": [],
- "features": [],
- "deps": {
- "components": [],
- "third_party": []
- ##end##
- "component": "camera_sample_app",
- "description": "Camera related samples.",
- "dirs": [
- "applications/sample/camera/launcher",
- "applications/sample/camera/cameraApp",
- "applications/sample/camera/setting",
- "applications/sample/camera/gallery",
- "applications/sample/camera/media"
复制代码
- 修改单板配置文件
修改文件vendor/hisilicon/hispark_aries/config.json,新增hello_world_app组件的条目,如下所示代码片段为applications子系统配置,"##start##"和"##end##"之间为新增条目("##start##"和"##end##"仅用来标识位置,添加完配置后删除这两行):
- "subsystem": "applications",
- "components": [
- ##start##
- { "component": "hello_world_app", "features":[] },
- ##end##
- { "component": "camera_sample_app", "features":[] }
复制代码
编译
如果Linux编译环境通过Docker方式安装,具体编译过程请参见Docker方式获取编译环境的编译操作。如果Linux编译环境通过软件包方式安装,进入源码根目录,执行如下命令进行编译:
- hb set(设置编译路径)
- .(选择当前路径)
- 选择ipcamera_hispark_aries@hisilicon并回车
- hb build -f(执行编译)
复制代码
结果文件生成在out/hispark_aries/ipcamera_hispark_aries目录下。
图 1 设置图例
须知:Hi3518EV300单板的U-boot文件获取路径:device/hisilicon/hispark_aries/sdk_liteos/uboot/out/boot/u-boot-hi3518ev300.bin
烧录
Hi3518开发板的代码烧录仅支持USB烧录方式。
- 请连接好电脑和待烧录开发板,以Hi3518EV300为例,需要同时连接串口和USB口,具体可参考Hi3518开发板介绍。
- 打开电脑的设备管理器,查看并记录对应的串口号。
说明:如果对应的串口异常,请根据Hi3516/Hi3518系列开发板串口驱动安装指导安装USB转串口的驱动程序。
- 打开DevEco Device Tool,在Projects中,点击Settings打开工程配置界面。
- 在“Partition Configuration”页签,设置待烧录文件信息,默认情况下,DevEco Device Tool已针对Hi3518系列开发板进行适配,无需单独修改。
- 在“hi3518ev300”页签,设置烧录选项,包括upload_port、upload_partitions和upload_protocol。
- upload_port:选择步骤2中查询的串口号。
- upload_protocol:选择烧录协议,固定选择“hiburn-u***”。
- upload_partitions:选择待烧录的文件,默认情况下会同时烧录fastboot、kernel、rootfs和userfs。
- 所有的配置都修改完成后,在工程配置页签的顶部,点击Save进行保存。
- 打开工程文件,点击图标,打开DevEco Device Tool界面,在“PROJECT TASKS”中,点击hi3518ev300_fastboot下的Erase按钮,擦除U-Boot。
- 执行Erase擦除操作后,显示如下提示信息时,请重启开发板(下电再上电)。
- 重新上电后,显示如下信息时,表示擦除U-Boot成功。
- 擦除完成后,点击hi3518ev300下的Upload按钮,启动烧录。
- 启动烧录后,界面提示如下信息时,表示烧录成功。
镜像运行- 连接串口。
须知:若无法连接串口,请参考常见问题进行排查。
图 2 连接串口图
- 单击Monitor打开串口。
- 连续输入回车直到串口显示"hisilicon"。
- 单板初次启动或修改启动参数,请进入步骤2,否则进入步骤3。
- (初次烧写必选)修改U-boot的bootcmd及bootargs内容:该步骤为固化操作,可保存执行结果,但U-boot重新烧入,则需要再次执行下述步骤。
表 1 U-boot修改命令
执行命令
| 命令解释
setenv bootcmd "sf probe 0;sf read 0x40000000 0x100000 0x600000;go 0x40000000";
| 设置bootcmd内容,选择FLASH器件0,读取FLASH起始地址为0x100000,大小为0x600000字节的内容到0x40000000的内存地址,此处0x600000为6MB,与IDE中填写OHOS_Image.bin的文件大小必须相同。
setenv bootargs "console=ttyAMA0,115200n8 root=flash fstype=jffs2 rw rootaddr=7M rootsize=8M";
| 表示设置bootargs参数为串口输出,波特率为115200,数据位8,rootfs挂载于FLASH上,文件系统类型为jffs2 rw,以支持可读写JFFS2文件系统。“rootaddr=7M rootsize=8M”处对应填入实际rootfs.img的烧写起始位置与长度,与IDE内所填大小必须相同。
saveenv
| 表示保存当前配置。
reset
| 表示复位单板。
pri
| 表示查看显示参数。
须知:**“go 0x40000000”**为可选指令,默认配置已将该指令固化在启动参数中,单板复位后可自动启动。若想切换为手动启动,可在U-boot启动倒数阶段使用"回车"打断自动启动。
- 若启动时显示**"hisilicon #字样,请输入“reset”指令,等待系统自启动进入系统,系统启动后,显示“OHOS”字样,输入”./bin/helloworld”**并回车,显示成功结果如下图所示。
图 3 启动成功并执行应用程序图
