DS1216,DS1216B, DS1216C芯片资料:
DS1216,DS1216B, DS1216C概述 The DS1216 SmartWatch RAM and SmartWatch ROM sockets are 600-mil-wide DIP sockets with a built-in CMOS watch function, an NV RAM controller circuit, and an embedded lithium energy source. The sockets provide an NV RAM solution for memory sized from 2k x 8 to 512k x 8 with package sizes from 26 pins to 32 pins. When a socket is mated with a CMOS SRAM, it provides a complete solution to problems associated with memory volatility and uses a common energy source to maintain time and date. The SmartWatch ROM sockets use the embedded lithium source to maintain the time and date only. A key feature of the SmartWatch is that the watch function remains transparent to the RAM. The SmartWatch monitors VCC for an out-of-tolerance condition. When such a condition occurs, an internal lithium energy source is automatically switched on and write protection is unconditionally enabled to prevent loss of watch and RAM data. DS1216,DS1216B, DS1216C关键特性 Keeps Track of Hundredths of Seconds, Seconds, Minutes, Hours, Days, Date of the Month, Months, and Years Converts Standard 2k x 8 Up to 512k x 8 CMOS Static RAMs into Nonvolatile Memory Embedded Lithium Energy Cell Maintains Watch Information and Retains RAM Data Watch Function is Transparent to RAM Operation Automatic Leap Year Compensation Valid Up to 2100 Lithium Energy Source is Electrically Disconnected to Retain Freshness Until Power is Applied for the First Time Proven Gas-Tight Socket Contacts Full ±10% Operating Range Accuracy Better Than ±1 Minute/Month at +25°C 通过美国保险商实验室协会(UL)认证 |
152个成员聚集在这个小组
加入小组101 浏览 0 评论
请问MAX9291MAX9288上电后,i2c通信不通的原因?
499浏览 1评论
4008浏览 1评论
266浏览 1评论
340浏览 1评论
419浏览 1评论
GMT+8, 2025-1-25 08:27 , Processed in 0.508116 second(s), Total 44, Slave 37 queries .
