` 板子SLWSTK6021A开发板搭载JLINK,按照传统的JLINK应该有固件MCU才对,看了半天没找到,原来是在墨水瓶下方。
核心MCU:The EFR32BG22C112 Wireless Gecko family of SoCs is part of the Wireless Gecko portfolio. EFR32BG22C112 Wireless Gecko SoCs are ideal for enabling energy-friendly Bluetooth 5.2 networking for IoT devices.The single-die solution combines a 38.4 MHz Cortex-M33, with a high performance 2.4GHz radio to provide an industry-leading, energy efficient wireless SoC for IoT connected applications. •32位ARM®Cortex®-M33内核,38.4 MHz最大工作频率 •高达352 kB的闪存和32 kB的RAM •低有源功率的高能效无线电核心 和睡眠电流 •集成PA,最高可达0 dBm(2.4 GHz)TX电源 •使用信任根和安全装载机(RTSL) 开发环境IDE Simplicity Studio 5,更希望推出Keil或者IAR的SDK。 Silicon Labs(亦称“芯科科技”,NASDAQ: SLAB)日前发布Simplicity Studio 5,新版Simplicity Studio可以通过具有Web风格的集中式用户界面为各种无线协议提供一致的访问和开发体验。基于最新版本的Eclipse和C/C ++开发工具,增加了稳健性,提高了性能,并让您能够使用Eclipse Marketplace中的插件定制您的体验。 https://v.youku.com/v_show/id_XNTE4NjY2MDI0MA==.html ` |
1 个讨论
PEM呼吸灯
uint8_t pwm_lut[] = { 0, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 6, 6, 6, 7, 7, 7, 8, 8, 8, 9, 9, 10, 10, 10, 11, 11, 12, 12, 13, 13, 14, 15, 15, 16, 17, 17, 18, 19, 19, 20, 21, 22, 23, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 34, 35, 36, 37, 39, 40, 41, 43, 44, 46, 48, 49, 51, 53, 54, 56, 58, 60, 62, 64, 66, 68, 71, 73, 75, 78, 80, 83, 85, 88, 91, 94, 97, 100, }; void blink_pwm_init(void) { // Enable PWM output sl_pwm_start(&sl_pwm_led0); } void blink_pwm_process_action(void) { for (uint8_t i = 0; i < 100; i++) { sl_pwm_set_duty_cycle(&sl_pwm_led0, pwm_lut[i]); sl_sleeptimer_delay_millisecond(6); if (i == 0) { sl_sleeptimer_delay_millisecond(190); } } for (uint8_t i = 100; i > 0; i--) { sl_pwm_set_duty_cycle(&sl_pwm_led0, pwm_lut[i]); sl_sleeptimer_delay_millisecond(6); if (i == 100) { sl_sleeptimer_delay_millisecond(190); } } } |
你正在撰写讨论
GMT+8, 2024-9-22 05:27 , Processed in 0.731682 second(s), Total 67, Slave 50 queries .
