扫一扫,分享给好友
我就打开例程然后编译,他就报错了,路径没中文没空格。网上找了几天了,救救我呗
portable_CC3220SF_LAUNCHXL_tirtos_ccs: 报错信息: Cannot build project. Referenced RTSC Configuration project 'tirtos_builds_CC3220SF_LAUNCHXL_release_ccs' contains build-errors. console信息: Buildfile generation error occurred.. Cannot build project. Referenced RTSC Configuration project 'tirtos_builds_CC3220SF_LAUNCHXL_release_ccs' contains build-errors. Build stopped.. tirtos_builds_CC3220SF_LAUNCHXL_release_ccs: 报错信息: cannot open source file "ti/sy***ios/family/arm/m3/Hwi.h"(Ctrl左键都可以打开,但是就是提示不能打开) cannot open source file "xdc/std.h"(Ctrl左键都可以打开,但是就是提示不能打开) gmake: *** [../src/sy***ios/sy***ios.aem4] Error 2 gmake: Target 'all' not remade because of errors. gmake[1]: *** [BIOS.obj] Error 1 gmake[1]: *** [m3_Hwi_asm.obj] Error 1 gmake[1]: Target 'all' not remade because of errors. console信息: **** Build of configuration Debug for project tirtos_builds_CC3220SF_LAUNCHXL_release_ccs **** "D:\ti\ccs1030\ccs\utils\bin\gmake" -k -j 8 all -O making ../src/sy***ios/sy***ios.aem4 ... gmake[1]: Entering directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' clem4 D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/BIOS.c ... >> Compilation failure makefile:59: recipe for target 'BIOS.obj' failed "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/BIOS.c", line 36: fatal error: cannot open source file "xdc/std.h" 1 catastrophic error detected in the compilation of "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/BIOS.c". Compilation terminated. gmake[1]: *** [BIOS.obj] Error 1 gmake[1]: Leaving directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' gmake[1]: Entering directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' asmem4 D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm_switch.sv7M ... gmake[1]: Leaving directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' gmake[1]: Entering directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' asmem4 D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M ... 7 Assembly Errors, 1 Assembly Warning >> Compilation failure makefile:42: recipe for target 'm3_Hwi_asm.obj' failed "D:tisimplelink_cc32xx_sdk_3_10_00_04kerneltirtospackagestisy***iosfamilyarmm3package/internal/Hwi.xdc.h", line 15: fatal error: cannot open source file "ti/sy***ios/family/arm/m3/Hwi.h" Compilation terminated. "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", WARNING! at line 36: [E1000] error while processing C code in .cdecls directive .cdecls C,NOLIST,"package/internal/Hwi.xdc.h" "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", ERROR! at line 52: [E0004] Structure/Union tag symbol expected ti_sy***ios_family_arm_m3_Hwi_Module__state__V .tag ti_sy***ios_family_arm_m3_Hwi_Module_State "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", ERROR! at line 73: [E0004] Absolute, well-defined integer value expected .if ti_sy***ios_BIOS_mpeEnabled__D "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", REMARK at line 73: [R0001] After symbol substitution the line became: .if FALSE "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", ERROR! at line 99: [E0004] Absolute, well-defined integer value expected .elseif ti_sy***ios_BIOS_mpeEnabled__D "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", REMARK at line 99: [R0001] After symbol substitution the line became: .elseif FALSE "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", ERROR! at line 259: [E0009] Missing struct/union member or tag swiTaskKeyAddr: .word ti_sy***ios_family_arm_m3_Hwi_Module__state__V.swiTaskKeys "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", ERROR! at line 275: [E0004] Absolute, well-defined integer value expected .if ti_sy***ios_BIOS_mpeEnabled__D "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", REMARK at line 275: [R0001] After symbol substitution the line became: .if FALSE "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", ERROR! at line 286: [E0004] Absolute, well-defined integer value expected .if ti_sy***ios_BIOS_smpEnabled__D "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", REMARK at line 286: [R0001] After symbol substitution the line became: .if FALSE "D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/Hwi_asm.sv7M", ERROR! at EOF: [E0300] The following symbols are undefined: FALSE swiTaskKeys ti_sy***ios_family_arm_m3_Hwi_Module_State ti_sy***ios_family_arm_m3_Hwi_Module__state__V Errors in Source - Assembler Aborted gmake[1]: *** [m3_Hwi_asm.obj] Error 1 gmake[1]: Leaving directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' gmake[1]: Entering directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' asmem4 D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/IntrinsicsSupport_asm.sv7M ... gmake[1]: Leaving directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' gmake[1]: Entering directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' asmem4 D:/ti/simplelink_cc32xx_sdk_3_10_00_04/kernel/tirtos/packages/ti/sy***ios/family/arm/m3/TaskSupport_asm.sv7M ... gmake[1]: Leaving directory 'D:/cc3220/tirtos_builds_CC3220SF_LAUNCHXL_release_ccs/src/sy***ios' ../src/makefile.libs:56: recipe for target '../src/sy***ios/sy***ios.aem4' failed gmake[1]: Target 'all' not remade because of errors. gmake: *** [../src/sy***ios/sy***ios.aem4] Error 2 gmake: Target 'all' not remade because of errors. **** Build Finished **** 实在不行有偿也行,感谢好人 |
分析一下,谢谢,谢谢谢谢
普中科技F28335开发板中,如何使用aic23播放由代码生成的正弦波
1068 浏览 0 评论
1912 浏览 1 评论
819 浏览 1 评论
2059 浏览 0 评论
基于DSP C6000教学实验箱_数字图像处理教程:5-9 图像反色实验案例分享
2369 浏览 0 评论
GMT+8, 2024-9-20 16:36 , Processed in 0.892096 second(s), Total 42, Slave 35 queries .
