Description
The SL1203 is a low noise, constant frequency (1.2MHz) switched capacitor voltage doubler. It produce a regulated output voltage from a 1.8V to 5V input with up to 100mA of output current. Low external parts count (one flying capacitor and two small bypass capacitors at VIN and VOUT) make the SL1203 ideally suited for small, battery-powered applications. The SL1203 have thermal shutdown capability and can survive a continuous short circuit from VOUT to GND. Built-in soft-start circuitry prevents excessive inrush current during start-up. High switching frequency enables the use of small ceramic capacitors. A low current shutdown feature disconnects the load from VIN and reduces quiescent current to <1uA. The SL1203 is available in the 6-pin SOT23-6. Features Fixed 3.3V ± 4% Output VIN Range: 1.8V to 5V Output Current: 100mA Constant Frequency Operation at All Loads Low Noise Constant Frequency (1.2MHz) Operation Automatic Soft-Start Reduces Inrush Current Shutdown Current<1uA Short-Circuit Protection No Inductors Available in Low Profile 6-Lead SOT23 Package Applications 2 AA Cell to 3.3V USB On-The-Go Devices White LED Drivers Handheld Devices Typical Applications |
GMT+8, 2025-1-24 21:51 , Processed in 0.455306 second(s), Total 42, Slave 32 queries .
