1. 创建verilog代码, 包括8位加法器代码和testbench代码。
adder8.v module adder8 ( input clk, input [7:0] a_i, input [7:0] b_i, output reg [8:0] c_o ); always @ (posedge clk) begin c_o 《= a_i + b_i; end endmodule adder8_tb.v // TB_SEED is random seed `ifndef TB_SEED `define TB_SEED 0 `endif module adder8_tb(); wire [8:0] result; reg [7:0] input_0; reg [7:0] input_1; reg clk; // clk2 is delay of clk, is used to verify result wire #5 clk2; assign clk2 = clk; initial begin $fsdbDumpfile(“adder8.fsdb”); $fsdbDumpvars(); $display(“TB_SEED is %d”, `TB_SEED); clk = 0; input_0 = 8‘d0; input_1 = 8’d0; #10000 $display(“All test PASS!”); $finish; end // system clk is 50MHz always begin #10 clk = ~clk; end //generate random input always @ (negedge clk) begin input_0 = $random() % 256; input_1 = $random() % 256; end //get verified output always @ (posedge clk2) begin if ((input_0 + input_1) != result) begin $display(“Test failed for %x + %x = %x”, input_0, input_1, result); $finish; end else begin $display(“%x + %x = %x”, input_0, input_1, result);end end //instantiate adder8 adder8 dut( .clk(clk), .a_i(input_0), .b_i(input_1), .c_o(result) ); endmodule 2.编写Makefile文件, VCS= vcs -sverilog -timescale=1ns/1ns +vpi -l build.log -debug_access+all SIMV = 。/simv -l simv.log ifndef TB_SEED TB_SEED = 1024 endif all: comp run comp: $(VCS) +define+TB_SEED=$(TB_SEED) +incdir+. adder8.v adder8_tb.v run: $(SIMV) +fsdbfile+top.fsdb dbg: verdi -f file.f -ssf top.fsdb & clean: rm -rf core csrc simv* vc_hdrs.h ucli.key urg* *.log *.fsdb novas.* verdiLog 注意:Makefile里面的空格排版位tab键。 file.f里面内容为: adder8_tb.v adder8.v 3.编译项目: Make 清除项目: Make clean 查看波形:Make dbg 编译日志文件为:build .log 仿真日志文件为:simv.log 仿真结果为: |
2070个成员聚集在这个小组
加入小组1032 浏览 2 评论
12916 浏览 0 评论
4176 浏览 7 评论
2395 浏览 9 评论
2239 浏览 2 评论
518浏览 2评论
933浏览 2评论
1032浏览 2评论
710浏览 1评论
770浏览 1评论
GMT+8, 2025-2-4 08:33 , Processed in 0.781685 second(s), Total 42, Slave 37 queries .
