OCP1201VAD支持最大1.5A电流输出(5.3V过压护),电流精度1%,同时兼容手电筒和闪光灯PWM调光,产品系列化程度高。
产品特点 ▪Drives up to 1.5A LED flash current ▪Drives up to 300mA LED torch current ▪High Efficiency PWM boost converter ▪Dimming frequency:20kHz~200kHz ▪Independent flash mode enable and torch mode enable pins ▪Integrated Soft-Start eliminates lnrush current ▪Thermal sensing and current scale back ▪Small solution size 产品电路图 |
GMT+8, 2024-9-21 19:32 , Processed in 0.564083 second(s), Total 76, Slave 60 queries .
