TI公司的TPA31xxD2系列是立体声高效数字功率放大器,能驱动2欧姆扬声器高达100W.工作电压4.5 V – 26 V,效率大于90%,TPA3130D2的高效率可采用单层PCB,不用散热器提供2x15W输出功率, TPA3118D2采用双层PCB, 不用散热器提供2x30W/8欧姆输出功率, TPA3116D2采用小型散热器可提供2x50W/4Ω输出功率,主要用于小/微型元件的条形音箱,后市场汽车电子,CRT TV和消费类音频。本文介绍了TPA31xxD2主要特性,方框图, 应用电路图以及评估板TPA3116D2EVM主要指标,电路图,材料清单和PCB布局图。
The TPA31xxD2 series are stereo efficient, digital amplifier power stage for driving speakers up to 100W/2Ω in mono. The high efficiency of the TPA3130D2 allows it to do 2x15W without external heat sink on a single layer PCB. The TPA3118D2 can even run 2x30W/8Ω without heat sink on a dual layer PCB. If even higher power is needed the TPA3116D2 does 2x50W/4Ω with a small heat-sink attached to its top side PowerPad. All three devices share the same footprint enabling a single PCB to be used across different power levels. The TPA31xxD2 advanced oscillator/PLL circuit employs a multiple switching frequency option to avoid AM interferences; this is achieved together with an option of Master/Slave option, making it possible to synchronize multiple devices. The TPA31xxD2 devices are fully protected against faults with short-circuit protection and thermal protection as well as over-voltage, under-voltage and DC protection. Faults are reported back to the processor to prevent devices from being damaged during overload conditions. TPA31xxD2主要特性: Supports Multiple Output Configurations 2×50-W into a 4-Ω BTL Load at 21 V (TPA3116D2) 2×30-W into a 8-Ω BTL Load at 24 V (TPA3118D2) 2×15-W into a 8-Ω BTL Load at 15 V (TPA3130D2) Wide Voltage Range: 4.5 V – 26 V Efficient Class-D Operation 》90% Power Efficiency Combined with Low Idle Loss Greatly Reduces Heat Sink Size Advanced Modulation Schemes Multiple Switching Frequencies AM Avoidance Master/Slave Synchronization Up to 1.2 MHz Switching Frequency Feedback Power Stage Architecture with High PSRR Reduces PSU Requirements Programmable Power Limit Differential/Single-Ended Inputs Stereo and Mono Mode with Single Filter Mono Configuration Single Power Supply Reduces Component Count Integrated Self-Protection Circuits Including Over-Voltage, Under-Voltage, Over-Temperature, DC-Detect, and Short Circuit with Error Reporting Thermally Enhanced Packages DAD (32-pin HTSSOP Pad-up) DAP (32-pin HTSSOP Pad-down) –40℃ to 85℃ Ambient Temperature Range TPA31xxD2应用: Mini-Micro Component, Speaker Bar, Docks After-Market Automotive CRT TV Consumer Audio Applications 图1. TPA31xxD2系列方框图 图2. TPA31xxD2系列简化应用电路图 图3. TPA31xxD2系列应用电路图 评估板TPA3116D2EVM The TPA3116D2EVM evaluation module (EVM) demonstrates the integrated circuits TPA3116D2 from Texas Instruments (TI)。 The TPA3116D2 is a 50-W (per channel), efficient, stereo, digital-amplifier power stage for driving two bridge-tied speakers or a single parallel bridge-tied load. The TPA3116D2 can drive a speaker with an impedance as low as 3.2 Ω (4 Ω typical)。 The TPA3116D2 is available in a 32-pin TSSOP. The TPA3116D2 evaluation module consists of a single 50-W, Class-D, stereo audio power amplifier complete with a small number of external components mounted on a circuit board that can be used to directly drive a speaker with an external analog audio source as the input. The EVM’s default output filter configuration supports LC filter operation, but can easily be configured to support filter-free operation or micro inductors. The EVM can also be configured as a 100-W, Class-D mono audio power amplifier. Designers can quickly evaluate the sound quality and verify specifications in their application with the TPA3116D2EVM. In addition, the TPA3116D2EVM User’s Guide contains the schematic, layout and bill of materials for a reference design. 评估板TPA3116D2EVM 主要指标: 图4. 评估板TPA3116D2EVM 外形图 图5. 评估板TPA3116D2EVM电路图 评估板TPA3116D2EVM材料清单: 图6. 评估板TPA3116D2EVM PCB布局图 详情请见: -1 和 -1 |
1005 浏览 0 评论
1281 浏览 1 评论
2704 浏览 5 评论
2996 浏览 9 评论
2897 浏览 6 评论
1616浏览 3评论
286浏览 2评论
559浏览 2评论
473浏览 2评论
539浏览 1评论
GMT+8, 2025-4-6 03:28 , Processed in 1.738805 second(s), Total 77, Slave 58 queries .
