小功率管
2N930 NPN LOW POWER 硅 晶体管 [53kb] 2N1613 NPN - 音频 output ,Video, Driver [NTE128][28KB] 2N2222A NPN General Purpose Amplifier [161KB] 2N3439 NPN 硅 PLANAR EPITAXIAL HIGH VOLTAGE 晶体管 [54kb] 2N3440 NPN 硅 PLANAR EPITAXIAL HIGH VOLTAGE 晶体管 [54kb] 2N3904 NPN 2N3906 PNP 2N5401 PNP 晶体管 [68kb] 2N5415 PNP 硅 晶体管 [67kb] 2N5416 PNP 硅 晶体管 [67kb] 2N5550 NPN 硅 晶体管 [69kb] 2N5551 NPN 硅 晶体管 [69kb] 2N6515 High Voltage-General Porpose amplifier [NTE] [23kb] 2N4921 NPN-中功率管[107kb] 2N4922 NPN-中功率管 [107kb] 2N4923 NPN-中功率管[107kb] AF125 Germanium PNP 晶体管 RF朓F Amp, FM Mixer OSC [NTE160][22kb] BC107 NPN-低噪声 (Comp.to BC177) [101KB] BC108 NPN-低噪声 (Comp.to BC178) [101KB] BC109 NPN-低噪声 (Comp.to BC179) [101KB] BC148 NPN - 音频放大,开关 [NTE123AP][23KB] BC177 PNP-低噪声 (Comp.to BC107) [101KB] BC178 PNP-低噪声 (Comp.to BC108) [101KB] BC179 PNP-低噪声 (Comp.to BC109) [101KB] BC182 NPN -音频放大、开关 (Compl to BC212-BC214) BC183 NPN -音频放大、开关 (Compl to BC212-BC214) BC184 NPN -音频放大、开关 (Compl to BC212-BC214) BC212 PNP -音频放大、开关 (Compl to BC182-BC184) [108KB] BC214 PNP -音频放大、开关 (Compl to BC182-BC184) [108KB] BC327 小信号 晶体管 (PNP) [Compl to BC337-BC338] BC301 NPN 硅 planar epitaxial 晶体管 [Comp. to BC303] [73kb] BC302 NPN 硅 planar epitaxial 晶体管 [Comp. to BC304] [73kb] BC303 PNP 硅 planar epitaxial 晶体管 [Comp. to BC301] [80kb] BC304 PNP 硅 planar epitaxial 晶体管 [Comp. to BC302] [80kb] BC328 小信号 晶体管 (PNP) [Compl to BC337-BC338] BC337 小信号 晶体管 (NPN) [Compl to BC327-BC328] BC338 小信号 晶体管 (NPN) [Compl to BC327-BC328] BC414 NPN-音频-开关 (Comp.to BC416)[NTE123AP][25KB] BC416 PNP-音频-开关 (Comp.to BC414)[NTE159][26KB] BC461 PNP High Voltage Amplifier & Driver [NTE189][23kb] BC516 PNP -达林顿管, 大电流 (Comp.to BC517) BC517 NPN -达林顿管, 大电流 (Comp.to BC516) BC546 NPN-音频-开关 (Comp.to BC556) [57KB] BC547 NPN-音频-开关 (Comp.to BC557) [57KB] BC548 NPN-音频-开关 (Comp.to BC558) [57KB] BC549 NPN-音频-开关 (Comp.to BC559) [57KB] BC550 NPN-音频-开关 (Comp.to BC560) [57KB] BC556 PNP-音频-开关 (Comp.to BC546) [55KB] BC557 PNP-音频-开关 (Comp.to BC547) [55KB] BC558 PNP-音频-开关 (Comp.to BC548) [55KB] BC559 PNP-音频-开关 (Comp.to BC549) [55KB] BC560 PNP-音频-开关 (Comp.to BC550) [55KB] BC635 NPN 中功率晶体管 [Compl to BC636] BC636 PNP 中功率晶体管 [Comp.to BC635 ] BC637 NPN 中功率晶体管 [Compl to BC638] BC638 PNP 中功率晶体管 [Comp.to BC637 ] BC639 NPN 中功率晶体管 [Compl to BC640] BC640 PNP 中功率晶体管 [Comp.to BC639 ] BCY70 PNP 晶体管 BCY71 PNP 晶体管 BCY78 PNP 开关 晶体管 BCY79 PNP 开关 晶体管 BCY87 Matched 双 NPN 晶体管 in a TO-71- SOT31 metal package. BCY88 Matched 双 NPN 晶体管 in a TO-71- SOT31 metal package. BCY89 Matched 双 NPN 晶体管 in a TO-71- SOT31 metal package. MPSL01 NPN-高电压、放大 MPSL51 PNP MPSA06 NPN-高电压、放大 [NTE] [23kb] MPSA42 NPN-硅 晶体管 高电压、放大 [882KB] MPSA43 NPN-硅 晶体管 高电压、放大 (Comp.to MPSA93) [295KB] MPSA56 PNP-音频 amplifier. switch [NTE] [25kb] MPSA92 PNP-硅 晶体管 高电压、放大 (Comp.to MPSA43) [73KB] MPSA93 PNP-硅 晶体管 高电压、放大 (Comp.to MPSA43) [73KB] 中、大功率管 2N3055 NPN- 功率放大. (Comp. to MJE2955) 2N6283 达林顿管, NPN-功率放大.(Comp. to 2N6286) [80K] 2N6284 达林顿管, NPN-功率放大.(Comp. to 2N6287) [80K] 2N6286 达林顿管, NPN-功率放大.(Comp. to 2N6283) [80K] 2N6287 达林顿管, PNP-功率放大.(Comp. to 2N6284) [80K] BD135 NPN- 音频 功率放大,开关 (Comp.to BD136) [39KB] BD136 PNP- 音频 功率放大,开关 (Comp.to BD135) [105KB] BD137 NPN- 音频 功率放大,开关 (Comp.to BD138) [39KB] BD138 PNP- 音频 功率放大,开关 (Comp.to BD137) [105KB] BD139 NPN- 音频 功率放大,开关 (Comp.to BD140) [39KB] BD140 PNP- 音频 功率放大,开关 (Comp.to BD139) [105KB] BD162 NPN 音频 功率放大,开关 晶体管 [NTE152][22kb] BD203 PNP- 音频 功率放大,开关 (Comp.to BD204)[NTE182][23KB] BD204 PNP- 音频 功率放大,开关 (Comp.to BD203)[NTE183][23KB] BD241C NPN-3 AMPERE POWER 晶体管 80, 100 VOLTS 40 WATTS (Comp.to BD242C) [109kb] BD242C PNP-3 AMPERE POWER 晶体管 80, 100 VOLTS 40 WATTS (Comp.to BD241C)[109kb] BD243 NPN Epitaxial 硅 晶体管 [39kb] BD249 NPN 硅 POWER 晶体管 [94KB] BD250 PNP 硅 POWER 晶体管 [94KB] BD375 NPN Epitaxial 硅 晶体管 (Comp.to BD376) [43KB] BD376 PNP Epitaxial 硅 晶体管 (Comp.to BD375) [43KB] BD377 NPN Epitaxial 硅 晶体管 (Comp.to BD378) [43KB] BD378 PNP Epitaxial 硅 晶体管 (Comp.to BD377) [43KB] BD379 NPN Epitaxial 硅 晶体管 (Comp.to BD380) [43KB] BD380 PNP Epitaxial 硅 晶体管 (Comp.to BD379) [43KB] BD543 NPN 硅 POWER 晶体管 [85KB] BD529 NPN- 高电压放大、驱动(Comp. to BD530)[NTE188][23KB] BD530 PNP- 高电压放大、驱动 (Comp. to BD529)[NTE189][23KB] BD533 NPN 硅 POWER 晶体管 (Comp.to BD534) [45KB] BD534 PNP 硅 POWER 晶体管 (Comp.to BD533) [45KB] BD535 NPN 硅 POWER 晶体管 (Comp.to BD536) [45KB] BD536 PNP 硅 POWER 晶体管 (Comp.to BD535) [45KB] BD537 NPN 硅 POWER 晶体管 (Comp.to BD538) [45KB] BD538 PNP 硅 POWER 晶体管 (Comp.to BD537) [45KB] BD677 达林顿管, NPN-功率放大.(Comp. to BD678) [42KB] BD678 达林顿管, PNP-功率放大.(Comp. to BD677) [42KB] BD679 达林顿管, NPN-功率放大.(Comp. to BD680) [42KB] BD680 达林顿管, PNP-功率放大.(Comp. to BD679) [42KB] BD681 达林顿管, NPN-功率放大.(Comp. to BD682) [42KB] BD682 达林顿管, PNP-功率放大.(Comp. to BD681) [42KB] BD591 NPN 音频 功率输出、 中功率、开关[NTE196] [25KB] BD592 PNP 音频 功率输出、 中功率、开关[NTE197] [25KB] BDX53C NPN-硅 POWER DARLINGTON 晶体管 (Comp. to BDX54C) [81KB] BDX54C PNP-硅 POWER DARLINGTON 晶体管 (Comp. to BDX53C) [81KB] BDW51 NPN 硅 power 晶体管 [NTE60] [25KB] BU208A 高电压、快速开关 NPN 功率晶体管 [84KB] BU508A 高电压、快速开关 NPN 功率晶体管 [84KB] MJ802 NPN-晶体管 大功率 音频 Amplifier (Comp. to MJ4502)[NTE][24kb] MJ2955 PNP- 功率放大. (Comp. to 2N3055) MJ4502 PNP-晶体管 大功率 音频 放大 (Comp. to MJ802)[NTE][24kb] MJ15003 NPN- 功率放大. (Comp. to MJ15004) [120KB] MJ15004 PNP- 功率放大. (Comp. to MJ15003) [120KB] MJE340 NPN-中功率晶体管 (Comp. to MJE350) [67KB] MJE350 PNP-中功率晶体管 (Comp. to MJE340) [70KB] MJE15028 NPN POWER 晶体管 (Comp. to MJE15029) [218KB] MJE15029 PNP POWER 晶体管 (Comp. to MJE15028) [218KB] MJE15030 NPN POWER 晶体管 (Comp. to MJE15031) [218KB] MJE15031 PNP POWER 晶体管 (Comp. to MJE15030) [218KB] PMD16K100 达林顿管, NPN-功率放大.(Comp. to PMD17K100)[NTE251][27KB] PMD17K100 达林顿管, PNP-功率放大.(Comp. to PMD16K100)[NTE252][27KB] tiP31 NPN Epitaxial 硅 晶体管 (Comp. to TIP32) [38KB] TIP32 PNP Epitaxial 硅 晶体管 (Comp. to TIP31) [38KB] TIP122 NPN EPITAXIAL DARLINGTON 晶体管 [62KB] TIP140 NPN 达林顿[复合]功率晶体管(Comp. toTIP145)[218KB] TIP141 NPN 达林顿[复合]功率晶体管(Comp. toTIP146)[218KB] TIP142 NPN 达林顿[复合]功率晶体管(Comp. toTIP147)[218KB] TIP145 PNP 达林顿[复合]功率晶体管 (Comp. to TIP140)[218KB] TIP146 PNP 达林顿[复合]功率晶体管 (Comp. to TIP141)[218KB] TIP147 PNP 达林顿[复合]功率晶体管 (Comp. to TIP142)[218KB] TIP2955 PNP- 功率放大. (Comp. to TIP3055) TIP3055 NPN- 功率放大. (Comp. to TIP2955) (520101)
22015个成员聚集在这个小组
加入小组12308 浏览 0 评论
5767 浏览 3 评论
17574 浏览 6 评论
2622 浏览 1 评论
3261 浏览 1 评论
1997浏览 2评论
916浏览 1评论
870浏览 1评论
1994浏览 1评论
1265浏览 0评论
GMT+8, 2024-9-20 13:47 , Processed in 1.039005 second(s), Total 74, Slave 53 queries .
