`我使用STM32F103进行一项SPI通信实验,用示波器发现片选信号在通信中途会被拉高,而且总是剩余8byte数据时被拉高,如附件图所示(其中绿色是片选信号,粉色是时钟信号): 附件图中我发送3个字节,只有两个字节的片选信号正常,第三字节发送前片选信号就被拉高。我尝试发送过多个字节,也总是在最后一个字节前(8byte)片选信号被拉高。希望知道解决方法的大神帮助一下。 下面是我的代码: int main(void) { SPI_DAC_Init(); DAC_SetVValue(2.8); while(1); } void SPI_DAC_Init(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; SPI_DAC_APBxClock_FUN ( SPI_DAC_CLK, ENABLE ); /* 使能SPI引脚相关的时钟 */ SPI_DAC_CS_APBxClock_FUN ( SPI_DAC_CS_CLK|SPI_DAC_SCK_CLK|SPI_DAC_MOSI_PIN, ENABLE ); /* 配置SPI的 CS引脚,普通IO */ GPIO_InitStructure.GPIO_Pin = SPI_DAC_CS_PIN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(SPI_DAC_CS_PORT, &GPIO_InitStructure); /* 配置SPI的 SCK引脚*/ GPIO_InitStructure.GPIO_Pin = SPI_DAC_SCK_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(SPI_DAC_SCK_PORT, &GPIO_InitStructure); /* 配置SPI的 MOSI引脚*/ GPIO_InitStructure.GPIO_Pin = SPI_DAC_MOSI_PIN; GPIO_Init(SPI_DAC_MOSI_PORT, &GPIO_InitStructure); /* 停止信号 : CS引脚高电平*/ SPI_DAC_CS_HIGH(); /* SPI 模式配置 */ // FLASH芯片 支持SPI模式0及模式3,据此设置CPOL CPHA SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(SPI_DAC , &SPI_InitStructure); /* 使能 SPI */ SPI_Cmd(SPI_DAC , ENABLE); } void SPI_DAC_Write(uint8_t *Data) { uint8_t i=0; SPI_DAC_CS_LOW(); /* 发送当前要写入的字节数据 */ for(;i<3;i++) { SPI_DAC_SendByte(*Data); Data++; } SPI_DAC_CS_HIGH(); } void SPI_DAC_SendByte(u8 byte) { while(SPI_I2S_GetFlagStatus(SPI_DAC ,SPI_I2S_FLAG_BSY) == SET){} while (SPI_I2S_GetFlagStatus(SPI_DAC , SPI_I2S_FLAG_TXE) == RESET); SPI_I2S_SendData(SPI_DAC , byte); } void DAC_SetVValue(float VValue) { uint8_t Value[]={0,0,0}; VValueSet16Bits = VValue/5.0*65536; Value[0] = DAC_NORMAL_OPERATION; Value[1] = VValueSet16Bits / 0x100; Value[2] = VValueSet16Bits % 0x100; SPI_DAC_Write(Value); } 如果对变量的定义有疑问,请留言给我,我会第一时间回复的。谢谢大家! ` |
3个回答
单独控制片选引脚试试,如果程序没问题,可能这个引脚有问题,也可以试着烧写在另一块板子,同样的程序再看看结果
3 条评论
从机的时钟要主机来提供的
2404 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1259 浏览 0 评论
3258 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
3034 浏览 4 评论
5571 浏览 0 评论
GMT+8, 2025-1-23 17:38 , Processed in 0.469431 second(s), Total 49, Slave 43 queries .
