2021-04-17 10:26:36
- 打开官网,找到WebView的文档(模拟器不支持)
鸿蒙webview的开发指南(原始链接,方便大家识别并点击):https://developer.harmonyos.com/cn/docs/documentation/doc-guides/ui-java-component-webview-0000001092715158
- 创建一个Page Ability,把基本布局弄好
下面是代码
<?xml version="1.0" encoding="utf-8"?>
<DirectionalLayout xmlns:ohos="http://schemas.huawei.com/res/ohos" ohos:height="match_parent" ohos:width="match_parent" ohos:orientation="vertical"> <DirectionalLayout ohos:height="30vp" ohos:width="match_parent" ohos:orientation="horizontal"> <TextField ohos:id="$+id:text_webView_Url" ohos:height="match_content" ohos:width="match_parent" ohos:background_element="$graphic:background_ability_simple_web_view" ohos:focus_border_enable="true" ohos:hint="请输入网址" ohos:max_text_lines="1" ohos:multiple_lines="false" ohos:scrollable="true" ohos:text="www.harmonyos.com" ohos:text_size="50" ohos:weight="1" /> <Button ohos:id="$+id:button_webview_surf" ohos:height="match_content" ohos:width="60vp" ohos:background_element="$graphic:button_element" ohos:text="跳转" ohos:text_size="50"/> </DirectionalLayout> <ProgressBar ohos:id="$+id:other_webView_progressBar" ohos:height="10vp" ohos:width="match_parent" ohos:visibility="hide"> </ProgressBar> <ohos.agp.components.webengine.WebView ohos:id="$+id:webview_webview_webview" ohos:height="match_parent" ohos:width="match_parent" ohos:weight="1"> </ohos.agp.components.webengine.WebView> <DirectionalLayout ohos:height="30vp" ohos:width="match_parent" ohos:orientation="horizontal"> <DirectionalLayout ohos:height="match_content" ohos:width="match_parent" ohos:orientation="horizontal" ohos:weight="1"> <Button ohos:id="$+id:button_webview_back" ohos:height="match_content" ohos:width="match_parent" ohos:background_element="$graphic:button_element" ohos:layout_alignment="horizontal_center" ohos:text="向后" ohos:text_size="50" > </Button> </DirectionalLayout> <DirectionalLayout ohos:height="match_content" ohos:width="match_parent" ohos:orientation="horizontal" ohos:weight="1"> <Button ohos:id="$+id:button_webview_refresh" ohos:height="match_content" ohos:width="match_parent" ohos:background_element="$graphic:button_element" ohos:layout_alignment="horizontal_center" ohos:text="刷新" ohos:text_size="50"> </Button> </DirectionalLayout> <DirectionalLayout ohos:height="match_content" ohos:width="match_parent" ohos:orientation="horizontal" ohos:weight="1"> <Button ohos:id="$+id:button_webview_forward" ohos:height="match_content" ohos:width="match_parent" ohos:background_element="$graphic:button_element" ohos:layout_alignment="horizontal_center" ohos:text="向前" ohos:text_size="50"> </Button> </DirectionalLayout> </DirectionalLayout></DirectionalLayout>
- 把基本的按钮事件弄好
序号按钮功能
1跳转把文本框中的网址打开
2后退在webview中点了新链接后,想回去看一看
3刷新以前的人在网络不好,美女图片出不来的时候用,现在一般是发了一篇帖子后,作者会没事点一下,看看有没有人点赞
4前进跟后退是关联用的,就是点了新链接,回去看了看后,还是觉得新链接更好看,就又要前进.代码
Component.ClickedListener clickedListener = new Component.ClickedListener() { @Override public void onClick(Component component) { int componentId = component.getId(); switch (componentId) { case ResourceTable.Id_button_webview_surf: { urlAddress = textWebViewUrl.getText(); if (urlAddress.isEmpty()) { return; } if (!urlAddress.startsWith(FinalValue.URL_HTTPS)) { urlAddress = FinalValue.URL_HTTPS + urlAddress; } webView.load(urlAddress); } break; case ResourceTable.Id_button_webview_back: { if (webView.getNavigator().canGoBack()) { webView.getNavigator().goBack(); } } break; case ResourceTable.Id_button_webview_refresh: { webView.reload(); } break; case ResourceTable.Id_button_webview_forward: { if (webView.getNavigator().canGoForward()) { webView.getNavigator().goForward(); } } break; default: { System.out.println("没有选择任何的页面"); } break; } } };
- 把WebView照文档上面的要求弄好
没啥好说的,就是规定.我加在了调用load方法打开网址那行代码后面,我还弄了一个跟进度条关联的功能
//允许javascript交互
WebConfig webConfig = webView.getWebConfig(); webConfig.setDataAbilityPermit(true); webConfig.setJavaScriptPermit(true); webConfig.setLoadsImagesPermit(true); webConfig.setMediaAutoReplay(true); webConfig.setLocationPermit(true); webConfig.setSecurityMode(WebConfig.SECURITY_SELF_ADAPTIVE); webView.setWebAgent(new WebAgent() { @Override public void onLoadingPage(WebView webView, String url, PixelMap favicon) { super.onLoadingPage(webView, url, favicon); // 这儿我加了一个更新网址文本框中新页面url的功能 if (url != urlAddress) { textWebViewUrl.setText(url); } } @Override public void onPageLoaded(WebView webView, String url) { super.onPageLoaded(webView, url); // 页面加载结束后自定义处理 } @Override public void onLoadingContent(WebView webView, String url) { super.onLoadingContent(webView, url); // 加载资源时自定义处理 } @Override public void onError(WebView webView, ResourceRequest request, ResourceError error) { super.onError(webView, request, error); // 发生错误时自定义处理 } }); webView.setBrowserAgent(new BrowserAgent(SimpleWebViewAbilitySlice.this) { @Override public void onTitleUpdated(WebView webView, String title) { super.onTitleUpdated(webView, title); // 标题变更时自定义处理 } @Override public void onProgressUpdated(WebView webView, int newProgress) { super.onProgressUpdated(webView, newProgress); if (newProgress < FinalValue.PROGRESS_BAR_FINISHED) { otherWebViewProgressBar.setVisibility(Component.VISIBLE); otherWebViewProgressBar.setProgressValue(newProgress); } else if (newProgress == FinalValue.PROGRESS_BAR_FINISHED) { otherWebViewProgressBar.setVisibility(Component.HIDE); } // 加载进度变更时自定义处理 } });
- 完事?or完了还有事?
从上面拷代码的话,估计完事了.但是,我是用的回忆,但是代码却没有回退,所以我还是有必要在这儿把步骤中的问题说一说,方便不拷代码的同学也能跑出一个界面.主要体现如下:
- 权限配置,不多说
"reqPermissions": [
{ "name": "ohos.permission.INTERNET" } ]
- xml中的WebView要带包名
不按上面包名写的话:
- 真机运行后没有WebView的界面.哪怕weight=1,也不行
- 点击跳转按钮后,PageAbility会闪退,回到首屏(调用它的页面)
完事效果:https://www.bilibili.com/video/BV1tK4y1o7Hz/
- 完整代码
- 布局
序号为2的步骤中贴全了
- 按钮背景
<?xml version="1.0" encoding="UTF-8" ?>
<shape xmlns:ohos="http://schemas.huawei.com/res/ohos" ohos:shape="rectangle"> <corners ohos:radius="20"/> <solid ohos:color="#70dbdb"/></shape>
- java代码
package com.javaaier.family.huawei.slice;
import com.javaaier.family.huawei.ResourceTable;import com.javaaier.family.huawei.common.FinalValue;import ohos.aafwk.ability.AbilitySlice;import ohos.aafwk.content.Intent;import ohos.agp.components.*;import ohos.agp.components.webengine.*;import ohos.media.image.PixelMap;/** * @author JavaAIer * @Description : webview控件例子1:用于简单的测试webview的用法 <br/> * 001 简单webview示例 * @Date: 2021/4/16 */public class SimpleWebViewAbilitySlice extends AbilitySlice { String urlAddress; ProgressBar otherWebViewProgressBar; TextField textWebViewUrl; Button buttonWebViewSurf, buttonWebViewBack, buttonWebViewRefresh, buttonWebViewForward; WebView webView; Component.ClickedListener clickedListener = new Component.ClickedListener() { @Override public void onClick(Component component) { int componentId = component.getId(); switch (componentId) { case ResourceTable.Id_button_webview_surf: { urlAddress = textWebViewUrl.getText(); if (urlAddress.isEmpty()) { return; } if (!urlAddress.startsWith(FinalValue.URL_HTTPS)) { urlAddress = FinalValue.URL_HTTPS + urlAddress; } webView.load(urlAddress); //允许javascript交互 WebConfig webConfig = webView.getWebConfig(); webConfig.setDataAbilityPermit(true); webConfig.setJavaScriptPermit(true); webConfig.setLoadsImagesPermit(true); webConfig.setMediaAutoReplay(true); webConfig.setLocationPermit(true); webConfig.setSecurityMode(WebConfig.SECURITY_SELF_ADAPTIVE); webView.setWebAgent(new WebAgent() { @Override public void onLoadingPage(WebView webView, String url, PixelMap favicon) { super.onLoadingPage(webView, url, favicon); // 页面开始加载时自定义处理 if (url != urlAddress) { textWebViewUrl.setText(url); } } @Override public void onPageLoaded(WebView webView, String url) { super.onPageLoaded(webView, url); // 页面加载结束后自定义处理 } @Override public void onLoadingContent(WebView webView, String url) { super.onLoadingContent(webView, url); // 加载资源时自定义处理 } @Override public void onError(WebView webView, ResourceRequest request, ResourceError error) { super.onError(webView, request, error); // 发生错误时自定义处理 } }); webView.setBrowserAgent(new BrowserAgent(SimpleWebViewAbilitySlice.this) { @Override public void onTitleUpdated(WebView webView, String title) { super.onTitleUpdated(webView, title); // 标题变更时自定义处理 } @Override public void onProgressUpdated(WebView webView, int newProgress) { super.onProgressUpdated(webView, newProgress); if (newProgress < FinalValue.PROGRESS_BAR_FINISHED) { otherWebViewProgressBar.setVisibility(Component.VISIBLE); otherWebViewProgressBar.setProgressValue(newProgress); } else if (newProgress == FinalValue.PROGRESS_BAR_FINISHED) { otherWebViewProgressBar.setVisibility(Component.HIDE); } // 加载进度变更时自定义处理 } }); } break; case ResourceTable.Id_button_webview_back: { if (webView.getNavigator().canGoBack()) { webView.getNavigator().goBack(); } } break; case ResourceTable.Id_button_webview_refresh: { webView.reload(); } break; case ResourceTable.Id_button_webview_forward: { if (webView.getNavigator().canGoForward()) { webView.getNavigator().goForward(); } } break; default: { System.out.println("没有选择任何的页面"); } break; } } }; /** * @Author JavaAIer * @Description : * @Date: 2021/4/16 14:46 * * @param intent */ @Override public void onStart(Intent intent) { super.onStart(intent); super.setUIContent(ResourceTable.Layout_ability_simple_web_view); otherWebViewProgressBar = (ProgressBar) findComponentById(ResourceTable.Id_other_webView_progressBar); textWebViewUrl = (TextField) findComponentById(ResourceTable.Id_text_webView_Url); buttonWebViewSurf = (Button) findComponentById(ResourceTable.Id_button_webview_surf); buttonWebViewSurf.setClickedListener(clickedListener); buttonWebViewBack = (Button) findComponentById(ResourceTable.Id_button_webview_back); buttonWebViewBack.setClickedListener(clickedListener); buttonWebViewRefresh = (Button) findComponentById(ResourceTable.Id_button_webview_refresh); buttonWebViewRefresh.setClickedListener(clickedListener); buttonWebViewForward = (Button) findComponentById(ResourceTable.Id_button_webview_forward); buttonWebViewForward.setClickedListener(clickedListener); webView = (WebView) findComponentById(ResourceTable.Id_webview_webview_webview); } @Override public void onActive() { super.onActive(); } @Override public void onForeground(Intent intent) { super.onForeground(intent); }}/** 这一截卡哇伊大喵在config.json用了,我发现用不用没啥区别啊
* https://blog.csdn.net/qq_33259323/article/details/115596296
* "default": { "network": { "cleartextTraffic": true, "securityConfig": { "domainSettings": {
"cleartextPermitted": true, "domains": [ { "subdomains": true, "name": "www.harmonyos.com" } ] } } } }** */
- config.json
"app": { "bundleName": "com.javaaier.family.huawei", "vendor": "javaaier", "version": { "code": 1, "name": "1.0" }, "apiVersion": { "compatible": 5, "target": 5, "releaseType": "Beta1" } }, "deviceConfig": { }, "module": { "package": "com.javaaier.family.huawei", "name": ".MyApplication", "deviceType": [ "phone" ], "distro": { "deliveryWithInstall": true, "moduleName": "entry", "moduleType": "entry" }, "abilities": [ { "skills": [ { "entities": [ "entity.system.home" ], "actions": [ "action.system.home" ] } ], "orientation": "unspecified", "name": "com.javaaier.family.huawei.MainAbility", "icon": "$media:icon", "description": "$string:mainability_description", "label": "$string:app_name", "type": "page", "launchType": "standard" }, { "orientation": "unspecified", "name": "com.javaaier.family.huawei.SimpleWebViewAbility", "icon": "$media:icon", "description": "$string:simplewebviewability_description", "label": "$string:app_name", "type": "page", "launchType": "standard" } ], "reqPermissions": [ { "name": "ohos.permission.INTERNET" } ] }}
侵权投诉
