Electronic design automationFrom Wikipedia, the free encyclopedia
(Redirected from Electronic design) Jump to: navigation, search [/url] [url=http://en.wikipedia.org/wiki/File:Kicad_Pcbnew_screenshot.jpg] PCB layout program Electronic design automation (EDA or ECAD) is a category of software tools for designing electronic systems such as printed circuit boards and integrated circuits. The tools work together in a design flow that chip designers use to design and analyze entire semiconductor chips. This article describes EDA specifically with respect to integrated circuits.
By the mid-70s, developers started to automate the design, and not just the drafting. The first placement and routing (Place and route) tools were developed. The proceedings of the Design Automation Conference cover much of this era. The next era began about the time of the publication of "Introduction to VLSI Systems" by Carver Mead and Lynn Conway in 1980. This ground breaking text advocated chip design with programming languages that compiled to silicon. The immediate result was a considerable increase in the complexity of the chips that could be designed, with improved access to design verification tools that used logic simulation. Often the chips were easier to lay out and more likely to function correctly, since their designs could be simulated more thoroughly prior to construction. Although the languages and tools have evolved, this general approach of specifying the desired behavior in a textual programming language and letting the tools derive the detailed physical design remains the basis of digital IC design today. The earliest EDA tools were produced academically. One of the most famous was the "Berkeley VLSI Tools Tarball", a set of UNIX utilities used to design early VLSI systems. Still widely used is the Espresso heuristic logic minimizer and Magic. Another crucial development was the formation of MOSIS, a consortium of universities and fabricators that developed an inexpensive way to train student chip designers by producing real integrated circuits. The basic concept was to use reliable, low-cost, relatively low-technology IC processes, and pack a large number of projects per wafer, with just a few copies of each projects' chips. Cooperating fabricators either donated the processed wafers, or sold them at cost, seeing the program as helpful to their own long-term growth. [edit] Birth of commercial EDA1981 marks the beginning of EDA as an industry. For many years, the larger electronic companies, such as Hewlett Packard, Tektronix, and Intel, had pursued EDA internally. In 1981, managers and developers spun out of these companies to concentrate on EDA as a business. Daisy Systems, Mentor Graphics, and Valid Logic Systems were all founded around this time, and collectively referred to as DMV. Within a few years there were many companies specializing in EDA, each with a slightly different emphasis. The first trade show for EDA was held at the Design Automation Conference in 1984. In 1986, Verilog, a popular high-level design language, was first introduced as a hardware description language by Gateway Design Automation. In 1987, the U.S. Department of Defense funded creation of VHDL as a specification language. Simulators quickly followed these introductions, permitting direct simulation of chip designs: executable specifications. In a few more years, back-ends were developed to perform logic synthesis. [/url] [url=http://en.wikipedia.org/wiki/File:Kicad_Pcbnew3D_screenshot.jpg] 3D PCB layout [edit] Current statusCurrent digital flows are extremely modular (see Integrated circuit design, Design closure, and Design flow (EDA)). The front ends produce standardized design descriptions that compile into invocations of "cells,", without regard to the cell technology. Cells implement logic or other electronic functions using a particular integrated circuit technology. Fabricators generally provide libraries of components for their production processes, with simulation models that fit standard simulation tools. Analog EDA tools are far less modular, since many more functions are required, they interact more strongly, and the components are (in general) less ideal. EDA for electronics has rapidly increased in importance with the continuous scaling of semiconductor technology.[citation needed] Some users are foundry operators, who operate the semiconductor fabrication facilities, or "fabs", and design-service companies who use EDA software to evaluate an incoming design for manufacturing readiness. EDA tools are also used for programming design functionality into FPGAs. [edit] Software focuses[edit] DesignMain article: Design flow (EDA)
Schematic capture program [edit] Analysis and verification
PCB layout and schematic for connector design [edit] CompaniesFor more details on this topic, see List of EDA companies. [edit] Top companies
[edit] AcquisitionsMany of the EDA companies acquire small companies with software or other technology that can be adapted to their core business.[3] Most of the market leaders are rather incestuous amalgamations of many smaller companies. This trend is helped by the tendency of software companies to design tools as accessories that fit naturally into a larger vendor's suite of programs on digital circuitry, many new tools incorporate analog design, and mixed systems. This is happening because there is now a trend to place entire electronic systems on a single chip. [edit] See also
[edit] References
^ http://www.google.com/finance?q=TYO:6947,NASDAQ:LAVA,NASDAQ:MENT,NASDAQ:SNPS,NASDAQ:CDNS ^ "Agilent EEsof EDA – Part I". http://www10.edacafe.com/nbc/articles/view_weekly.php?articleid=782353. Notes
Retrieved from "http://en.wikipedia.org/w/index.php?title=Electronic_design_automation&oldid=447111523" |
4 个讨论
GMT+8, 2025-2-24 18:44 , Processed in 0.584288 second(s), Total 54, Slave 42 queries .
