事实上,在大多数情况下,它会反过来 - BC5xx是简单的通用小信号晶体管,但2222是一个(相对)高频开关transistor.For这种带宽虽然,你可以使用几乎任何PNP和NPN晶体管。 Actually in most cases it would be the other way round - the BC5xx are simple general purpose small signal transistors but the 2222 is a (relatively) high frequency switching transistor.For this kind of bandwidth though, you could use pretty much any PNP and NPN transistor. |
4 个讨论
我先式 后说{:soso_e113:}
GMT+8, 2024-12-24 20:22 , Processed in 1.194650 second(s), Total 45, Slave 37 queries .
