MC14572,MC14528,MC14013组成的曼彻斯特PCM解码器电路图。 三个CMOS集成电路提供发电缺少的标志,它应该发生在每个级别的数据恢复原始时钟频率的变化NRZL曼彻斯特解码(分相)的PCM信号。可重触发单MVBR NHZL时间稍长原始时钟频率的一半。信号电平与TTL兼容。 C和R的值取决于系统频率。其他电阻是15K,和其他电容470 pF的。
Three CMOS ICs provide decoding of Manchester (split-phase) PCM signals by generating missing mark which should occur NRZL at each change of level data to recover original clock frequency. Retriggerable mono MVBR NHZL times out at slightly longer than half of original clock frequency. Signal levels are TTL-compatible. Values of C and R depend on system frequency. Other resistors are 15K, and other capacitors are 470 pF. |
GMT+8, 2024-12-24 03:47 , Processed in 0.496439 second(s), Total 43, Slave 32 queries .
