The ADC (Analog-to-Digital Converter) architecture of Nuvoton’s microcontroller (MCU) is mostly equipped with SAR ADC (Successive approximation ADC), which needs to store the charge in the sample-and-hold capacitor inside the ADC in use. User needs to make sure that the sample-and-hold capacitor after charging is equal to the external measurement voltage before starting the analog-digital conversion to obtain an accurate voltage value. When a longer charge time is required, the user can set a longer sampling time by using the SMPTSEL (EADC_CTL [18:16]) & EXTSMPT (EADC_SCTLn [31:24]) to make the capacitor voltage equal to the external voltage.
例如,SMPTSEL=8,EXTS MPT=200,则采样时间为200,28=210(ADC时钟),ADC时钟为10MHz,21μs采样时间,保持电容器充电。 这确保了外部测量电压相等,以获得精确的电压值。 |
435 浏览 0 评论
996 浏览 1 评论
2382 浏览 5 评论
2697 浏览 9 评论
2519 浏览 6 评论
557浏览 9评论
562浏览 7评论
667浏览 6评论
535浏览 5评论
575浏览 5评论
GMT+8, 2024-9-21 18:50 , Processed in 0.737762 second(s), Total 47, Slave 39 queries .
