PR6211/14D1,PR6211/53D1料斗秤传感器 PR6211/14D1,PR6211/53D1料斗秤传感器
吴经理 :132,4667,5433/ 0755-26998458 工作Q:1139878854 R6221/6224传感器设计可在严苛条件下工作,用于汽车衡和轨道衡。其允许的机械过载量高达200%,密封外壳以及超高的防雷击保护确保了传感器的长寿与免维护。一致性输出威廉希尔官方网站 使得此传感器无需浪费时间做四角误差调整。 PR6211系列传感器是为了称量仓、罐秤和过程容器特别设计的。独特的设计原理确保了其特别紧凑的结构,因此,可以应用在空间有限的情况下。FlexLock安装套件平衡了机械或容器因热胀冷缩以及支撑结构引起的震动。此产品的一个特殊设计就是:某些型号采用了薄膜或“splutter"威廉希尔官方网站 ,使操作温度范围可达到180°C。此外,结构的整合使过载保护达到500kg。 传感器结构 PR6201/13D1 PR6201/14D1 PR6201/24D1 PR6201/34D1 PR6201/54D1 PR6201/13D1E PR6201/14C3 PR6201/14C3E PR6201/14D1E PR6201/14L PR6201/14LA PR6201/13LA PR6201/15L PR6201/15LA PR6201/15N PR6201/15NE PR6201/13L PR6201/23C3 PR6201/23C3E PR6201/23D1 PR6201/23D1E PR6201/23L PR6201/23LA PR6201/24C3 PR6201/24C3E PR6201/24C4 PR6201/24C4E PR6201/24C5 PR6201/24C5E PR6201/24C6 PR6201/24C6E PR6201/24D1E PR6201/24L PR6201/24LA PR6201/25LA PR6201/25N PR6201/25NE PR6130/08 PR6143/00N PR6143/00N PR6024/62S PR6211/12D1 PR6211/13D1 PR6211/13D1E PR6211/13LT PR6211/14D1 PR6211/14D1E PR6211/22D1 PR6211/23D1 PR6211/23D1E PR6211/23LT PR6211/31D1 PR6211/13D1E PR6211/32D1 PR6211/33D1 PR6211/33D1E PR6211/51D1 PR6211/52D1 PR6211/52D1E PR6211/52LT PR6211/53D1 PR6211/53D1E PR6211/53LT PR6011/00N PR6011/00S PR6011/03N PR6011/10N PR6011/10S PR6011/11N PR6011/11S PR6011/20N PR6011/20S PR6011/30N PR6011/30S PR6011/40N PR6011/40S PR6221/20tC3 PR6221/20tC3 HR-30 Series 系列产品介绍: INTRODUCtiON Model HR-30 is simple, reliable float switch designed for top mounting to tanks or vessels. And give dependable repeatability in the detection of high, low or intermediate loquid levels in almost any tank or vessel. PRINCIPLE A magnet-equipped float the sole moving part moves with liquid level between stops to magnetically actuate a hermetically sealed, glass-enclose HM-95Series 系列液位开关 INTRODUCTION Widely applicable level switch for antioverflow of various liquid tank. Model HM-95 units are siple, reliable float switches designed for top mounting to tanks or vessels. HM-95 units utilize a single switch mechanism and float. PRINCIPLE A permanent magnet is attached to a pivoted switch mechanism. As the float rises following the liquid level, it raises the attraction sleeve into the field of the magnet, which then snaps against the non-magnetic enclosing tube, sctuating the switch mechanism. The enclosing tube provides a static pressure boundary between the switch mechanism and the process. On a falling level, a spring retracts the magnet, deactivating the switch mechanism. |
GMT+8, 2024-9-22 02:02 , Processed in 0.548716 second(s), Total 69, Slave 50 queries .
