Windows下执行cmd命令
如复制 D:tmpmy.txt 到D:tmpmy_by_only_cmd.txt 现文件如图示: 执行代码: private static void runWinCmd() throws IOException, InterruptedException { Process proc = Runtime.getRuntime().exec("cmd.exe /c copy D:\tmp\my.txt D:\tmp\my_by_only_cmd.txt"); int processCode = proc.waitFor(); System.out.println("Process code: " + processCode); } 结果如图示,执行成功 |
Windows下执行bat脚本
删除多余文件,新建mytest.bat,内容如下 copy D:tmpmy.txt D:tmpmy_by_bat.txtexit 现文件如图示: 执行代码: private static void runWinBat() throws IOException, InterruptedException { Process proc = Runtime.getRuntime().exec("cmd.exe /c start D:\tmp\mytest.bat"); int processCode = proc.waitFor(); System.out.println("Process code: " + processCode); } 结果如图示,执行成功 |
Linux下执行命令
如复制 /opt/tmp/my.txt 到 /opt/tmp/my_by_copy.txt 现文件如图示: 执行代码: private static void runLinuxCommand() throws IOException, InterruptedException { Process proc = Runtime.getRuntime().exec("sudo cp /opt/tmp/my.txt /opt/tmp/my_by_copy.txt"); int processCode = proc.waitFor(); System.out.println("Process code: " + processCode); } 结果如图示,执行成功 |
Linux下执行shell脚本
删除多余文件,新建mytest.sh,内容如下 sudo cp /opt/tmp/my.txt /opt/tmp/my_by_sh.txt 现文件如图示: 执行代码: private static void runLinuxShell() throws IOException, InterruptedException { Process proc = Runtime.getRuntime().exec("bash /opt/tmp/mytest.sh"); int processCode = proc.waitFor(); System.out.println("Process code: " + processCode); } 结果如图示,执行成功 |
“0元购”智元灵犀X1机器人,软硬件全套图纸和代码全公开!资料免费下载!
7061 浏览 2 评论
1427 浏览 0 评论
【实操文档】在智能硬件的大模型语音交互流程中接入RAG知识库
7285 浏览 1 评论
防止AI大模型被黑客病毒入侵控制(原创)聆思大模型AI开发套件评测4
1154 浏览 0 评论
不可错过!人工神经网络算法、PID算法、Python人工智能学习等资料包分享(附源代码)
3461 浏览 0 评论
GMT+8, 2025-1-11 19:26 , Processed in 0.635246 second(s), Total 78, Slave 62 queries .
