#define PORT_busy PB_DDR=0x00;PB_CR1=0xff;
#define busy PB_IDR #define PORT_OUT PB_DDR=0xff;PB_CR1=0xff; #define PORT PB_ODR #define EN_SET ***i(PC_DDR,5);***i(PC_CR1,5);***i(PC_ODR,5); #define EN_CLR ***i(PC_DDR,5);***i(PC_CR1,5);cbi(PC_ODR,5); #define RW_SET ***i(PC_DDR,6);***i(PC_CR1,6);***i(PC_ODR,6); #define RW_CLR ***i(PC_DDR,6);***i(PC_CR1,6);cbi(PC_ODR,6); #define RS_SET ***i(PE_DDR,5);***i(PE_CR1,5);***i(PE_ODR,5); #define RS_CLR ***i(PE_DDR,5);***i(PE_CR1,5);cbi(PE_ODR,5); _Bool lcd1602_busy(void) { _Bool result; RS_CLR; RW_SET; EN_SET; delay(5); PORT_busy; result=(busy & 0x80); EN_CLR; return result; } void lcd1602_write_com(u8 com) { while(lcd1602_busy()); RS_CLR; RW_CLR; EN_CLR; PORT_OUT; PORT=com; EN_SET; delay(5); EN_CLR; } void lcd1602_write_data(u8 dat) { while(lcd1602_busy()); RS_SET; RW_CLR; EN_CLR; PORT_OUT; PORT=dat; EN_SET; delay(5); EN_CLR; } void lcd1602_gotoxy(u8 x,u8 y) { u8 add; if(y==0) add=0x80+x; else add=0xc0+x; lcd1602_write_com(add); } void lcd1602_init(void) { delay(100); lcd1602_write_com(0x38); lcd1602_write_com(0x0c); lcd1602_write_com(0x06); lcd1602_write_com(0x01); } void lcd1602_display(void) { for(num=0;num<12;num++) { lcd1602_write_data(table[num]); delay(5); } } |
949 浏览 0 评论
1244 浏览 1 评论
2606 浏览 5 评论
2953 浏览 9 评论
2821 浏览 6 评论
1402浏览 3评论
255浏览 2评论
526浏览 2评论
437浏览 2评论
510浏览 1评论
GMT+8, 2025-3-5 10:11 , Processed in 1.013261 second(s), Total 49, Slave 40 queries .
