扫一扫,分享给好友
protected void Button2_Click(object sender, EventArgs e)
{ if (this.GridView1.Rows.Count == 0) { Response.Write("";//导入到excel时,保存表里数字列中前面存在的 0 . Response.Clear(); Response.Charset = "GB2312"; Response.ContentEncoding = Encoding.UTF7; Response.AppendHeader("Content-Disposition", "attachment;filename=" + HttpUtility.UrlEncode(FileName, Encoding.UTF8).ToString()); Response.ContentType = FileType; this.EnableViewState = false; this.GridView1.AllowPaging = false; System.Globalization.CultureInfo myCItrad = new System.Globalization.CultureInfo("ZH-CN", true); StringWriter sw = new StringWriter(); HtmlTextWriter htw = new HtmlTextWriter(sw); this.GridView1.RenderControl(htw); Response.Write(style); Response.Write(sw.ToString()); //Response.Write(dt.ToString()); Response.End(); } public override void VerifyRenderingInServerForm(Control control) { //在后台中重载VerifyRenderingInServerForm()方法,否则报错为“类型"GridView"的控件"GridView1"必须放在具有 runat=server 的窗体标记内“ } protected void GridView1_RowDataBound(object sender, GridViewRowEventArgs e) { if (e.Row.RowType == DataControlRowType.DataRow) { e.Row.Cells[3].Attributes.Add("class", "text");//在数字列前存在的 0 的列中加入 class 样式 以便保存 0 } } 注:如果GricView中有分页的话,导出到Excel时就会报错.可通过修改页文件可以修正这个问题:EnableEventValidation = "false". <%@ Page Language="C#" EnableEventValidation="false" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %> |
“0元购”智元灵犀X1机器人,软硬件全套图纸和代码全公开!资料免费下载!
12774 浏览 2 评论
1472 浏览 0 评论
【实操文档】在智能硬件的大模型语音交互流程中接入RAG知识库
8170 浏览 1 评论
防止AI大模型被黑客病毒入侵控制(原创)聆思大模型AI开发套件评测4
1203 浏览 0 评论
不可错过!人工神经网络算法、PID算法、Python人工智能学习等资料包分享(附源代码)
3517 浏览 0 评论
GMT+8, 2025-2-13 20:07 , Processed in 0.458377 second(s), Total 72, Slave 56 queries .
