各位大神好,现在我使用emwin中的控件image显示图片,由于图片太多,所以放在外部的flash芯片中。程序代码如下:
[C] 纯文本查看 复制代码 unsigned char _acBuffer[320*4*8];int _GetData(void * p, const U8 ** ppData, unsigned NumBytesReq, U32 Off) {static int FileAddress = 0;UINT NumBytesRead;FIL *PicFile;PicFile = (FIL *)p;/** Check buffer size*/if (NumBytesReq > sizeof(_acBuffer)) {NumBytesReq = sizeof(_acBuffer);}/** Set file pointer to the required position*/if(Off == 1) FileAddress = 0;else FileAddress = Off;result =f_lseek(PicFile, FileAddress);/** Read data into buffer*/result = f_read(PicFile, _acBuffer, NumBytesReq, &NumBytesRead);/** Set data pointer to the beginning of the buffer*/*ppData = (const U8 *)_acBuffer;/** Return number of available bytes*/return NumBytesRead;} [C] 纯文本查看 复制代码 void DisplayImageFromExFlash(IMAGE_Handle hObj,const TCHAR* path){ FRESULT res_flash; res_flash = f_open(&fnew1, path, FA_OPEN_EXISTING | FA_READ); IMAGE_SetBMPEx ( hObj, _GetData, &fnew1); f_close(&fnew1);} 发现程序执行到IMAGE_SetBMPEx ( hObj, _GetData, &fnew1);并不会调到int _GetData(void * p, const U8 ** ppData, unsigned NumBytesReq, U32 Off) 中,而是直接执行f_close(&fnew1);过后再执行_GetData(), 导致显示不了图片,请问这是什么原因呢?谢谢 |
798 浏览 0 评论
1154 浏览 1 评论
2531 浏览 5 评论
2863 浏览 9 评论
2713 浏览 6 评论
1086浏览 3评论
195浏览 2评论
461浏览 2评论
374浏览 2评论
455浏览 1评论
GMT+8, 2024-12-24 00:48 , Processed in 0.885545 second(s), Total 45, Slave 37 queries .
