基于51单片机红外控制LED灯的程序
3088 51单片机 来自手机
2020-8-19 23:27:54   评论 分享淘帖 邀请回答 举报
3个回答
2020-8-20 10:30:56 评论
2020-8-20 10:32:05 评论
2020-8-20 12:03:05 2 评论
2 条评论
  • 2020-8-23 08:36
    闪烁控制在定时器里完成,设置一个标志,标志有效则开始闪烁,标志无效则关闭闪烁。你的需求里并没有关闭闪烁的条件,所以你需要设置一个按键或其他条件关闭闪烁,当这个条件有效后,控制闪烁标志来关闭闪烁
    jf_39852578 回复 人中狼: 2020-8-26 15:30
    应该怎么修改呢? 程序如下:  #include <reg52.h> #include <intrins.h> #define  NOP()   _nop_()    #define uchar unsigned char #define uint  unsigned int #define delayNOP(); {_nop_();_nop_();_nop_();_nop_()};  void delay(uchar x);  void delay1(int ms); void delayms(uint);  void beep(void);  sbit IRIN = P3^2;         sbit LED1 = P1^0;         sbit LED2 = P1^1;   sbit LED3 = P1^2;   sbit LED4 = P1^3;   sbit LED5 = P1^4;   sbit LED6 = P1^5;   sbit LED7 = P1^6;  sbit LED8 = P1^7;  sbit BEEP = P2^3;       uchar IRCOM[7]; unsigned char Y1,Y2,Y3,Y4,Y5,Y6,Y7,Y8,Y9,i,j;  main() {      IE = 0x81;                      TCON = 0x01;                       IRIN=1;     BEEP=1;             LED1=1;     LED2=1;     LED3=1;     LED4=1;     LED5=1;     LED6=1;     LED7=1;     LED8=1;     delay1(10);                  while(1); }  void IR_IN(void) interrupt 0     {   unsigned char j,k,N=0;          EX0 = 0;             delay(15);          if (IRIN==1)                                 {                              EX0 =1;           return;                                 }                          while (!IRIN)                {delay(1);}      for (j=0;j<4;j++)                          {                         for (k=0;k<8;k++)                                 {                                 while (IRIN)                                             {delay(1);}                                 while (!IRIN)                                           {delay(1);}                                 while (IRIN)                                           {                                         delay(1);                                         N++;                                                    if (N>=30)                                         {                                           EX0=1;                                          return;                                         }                                                 }        IRCOM[j]=IRCOM[j] >> 1;                                                   if (N>=8) {IRCOM[j] = IRCOM[j] | 0x80;}                                   N=0;                         }                 }     if (IRCOM[2]!=~IRCOM[3])    {                   EX0=1;      return;           }     IRCOM[5]=IRCOM[2] & 0x0F;        IRCOM[6]=IRCOM[2] >> 4;        if(IRCOM[5]>9)     { IRCOM[5]=IRCOM[5]+0x37;}    else IRCOM[5]=IRCOM[5]+0x30;    if(IRCOM[6]>9)     { IRCOM[6]=IRCOM[6]+0x37;}    else IRCOM[6]=IRCOM[6]+0x30;     Y1=Y2=Y3=Y4=Y5=Y6=Y7=Y8=Y9=0;                     switch(IRCOM[2])    {                         case 0x0C: Y1=0x01; break;       case 0x18: Y2=0x01; break;       case 0x5E: Y3=0x01; break;       case 0x08: Y4=0x01; break;       case 0x1C: Y5=0x01; break;       case 0x5A: Y6=0x01; break;       case 0x42: Y7=0x01; break;       case 0x52: Y8=0x01; break;      }                                                   if(Y1&0xFF)LED1=0;                       else LED1=1;                if(Y2&0xFF)LED2=0;        else LED2=1;        if(Y3&0xFF)LED3=0;        else LED3=1;        if(Y4&0xFF)LED4=0;        else LED4=1;        if(Y5&0xFF)LED5=0;        else LED5=1;        if(Y6&0xFF)LED6=0;        else LED6=1;        if(Y7&0xFF)LED7=0;        else LED7=1;        if(Y8&0xFF)LED8=0;        else LED8=1;                                        beep();     EX0 = 1;  }   void beep(void) {   unsigned char i;   for (i=0;i<100;i++)    {    delay(4);    BEEP=!BEEP;                   }   BEEP=1;                      }  void delay(unsigned char x)    {         unsigned char i;   while(x--)         {                 for (i = 0; i<13; i++) {}         } }  void delay1(int ms) {         unsigned char y;   while(ms--)         {                 for(y = 0; y<250; y++)                 {    _nop_();    _nop_();    _nop_();    _nop_();                 }         } }
撰写答案
