本帖最后由 lm12041204a 于 2020-8-20 10:29 编辑 LM2596有3.3V、5V、12V 固定输出电压 和 可调节输出电压 版本。首先请确认你用的哪个版本。其次请看一下有关CFF和电感的说明。数据表(部分中文)一并附上。 |
3 条评论
2 条评论
主要有三个影响的地方,1.电感值大小是否合理,2.输出电容大小是否合理,3.反馈端的电阻配比是否正确,可以从这三个方面查一下
3 条评论
LM 2596 Table 3. LM2596 Fixed Voltage Quick Design Component Selection Table
2 条评论
Table 3. LM2596 Fixed Voltage Quick Design Component Selection Table 3.电解电容器的电容器额定电压应至少为输出电压的1.5倍,并且通常需要更高的额定电压才能满足低输出纹波电压的低ESR要求。 对于5 V输出,要求电容器额定电压至少为7.5V。 但是,即使是低ESR,开关级,220μF,10V铝电解电容器也将表现出约225mΩ的ESR(请参见ESR与电压额定值的图24)。 ESR的量将导致较高的输出纹波电压。 为了将纹波减小到输出电压的1%或更小,必须选择一个具有较高值或具有较高额定电压(ESR较低)的电容器。 16V或25V的电容器将纹波电压降低大约一半。 |
1 条评论
再看P17 【9.1.3 Output Capacitor (COUT)】 9.1.3 Output Capacitor (COUT) An output capacitor is required to filter the output and provide regulator loop stability. Low impedance or low-ESR electrolytic or solid tantalum capacitors designed for switching regulator applications must be used. When selecting an output capacitor, the important capacitor parameters are the 100-kHz ESR, the RMS ripple current rating, voltage rating, and capacitance value. For the output capacitor, the ESR value is the most important parameter. The output capacitor requires an ESR value that has an upper and lower limit. For low output ripple voltage, a low ESR value is required. This value is determined by the maximum allowable output ripple voltage, typically 1% to 2% of the output voltage. But if the selected capacitor's ESR is extremely low, there is a possibility of an unstable feedback loop, resulting in an oscillation at the output. Using the capacitors listed in the tables, or similar types, will provide design solutions under all conditions. If very low output ripple voltage (less than 15 mV) is required, see Output Voltage Ripple and Transients for a post ripple filter. An ESR value of the aluminum electrolytic capacitor is related to the capacitance value and its voltage rating. In most cases, higher voltage electrolytic capacitors have lower ESR values (see Figure 24). Often, capacitors with much higher voltage ratings may be required to provide the low ESR values required for low output ripple voltage. The output capacitor for many different switcher designs often can be satisfied with only three or four different capacitor values and several different voltage ratings. See Table 3 and Table 4 for typical capacitor values, voltage ratings, and manufacturers capacitor types. Electrolytic capacitors are not recommended for temperatures below −25°C. The ESR rises dramatically at cold temperatures and is typically three times as large at −25°C and as much as 10 times as large at −40°C. See Figure 25. Solid tantalum capacitors have a much better ESR specifications for cold temperatures and are recommended for temperatures below −25°C. |
1 条评论
将就看一下吧。 9.1.3输出电容器(COUT) 需要一个输出电容器来过滤输出并提供调节器环路稳定性。必须使用专为开关稳压器应用设计的低阻抗或低ESR电解或固态钽电容器。选择输出电容器时,重要的电容器参数是100kHz ESR,RMS纹波电流额定值,电压额定值和电容值。对于输出电容器,ESR值是最重要的参数。 输出电容器要求的ESR值具有上限和下限。对于低输出纹波电压,需要低ESR值。该值由最大允许输出纹波电压确定,通常为输出电压的1%到2%。但是,如果所选电容器的ESR极低,则可能存在不稳定的反馈环路,从而导致输出振荡。使用表中列出的电容器或类似类型的电容器,将在所有条件下提供设计解决方案。 如果需要非常低的输出纹波电压(小于15 mV),请参阅输出电压纹波和瞬态以获取后纹波滤波器。 铝电解电容器的ESR值与电容值及其额定电压有关。在大多数情况下,较高电压的电解电容器的ESR值较低(请参见图24)。通常,可能需要具有更高额定电压的电容器来提供低输出纹波电压所需的低ESR值。 通常,只有三个或四个不同的电容器值和几个不同的额定电压才能满足许多不同开关设计的输出电容器。有关典型的电容器值,额定电压和制造商的电容器类型,请参见表3和表4。 不建议在低于-25°C的温度下使用电解电容器。在低温下,ESR急剧上升,通常在-25°C时大三倍,而在-40°C时大十倍。参见图25。 固态钽电容器在寒冷的温度下具有更好的ESR规范,建议在低于-25°C的温度下使用。 |
电源接线检测仪LED1、2电路的二极管是反接的,灯为什么会亮?
4829 浏览 1 评论
2597 浏览 1 评论
各位大神,求电路图,用MC34063设计出一个升降压DC-DC,输出900mA左右
2817 浏览 0 评论
6167 浏览 2 评论
2467 浏览 3 评论
74671 浏览 104 评论
GMT+8, 2024-8-28 10:34 , Processed in 0.646586 second(s), Total 69, Slave 63 queries .
