我想用DM3730下的PCM链接蓝牙,使用McBSP3接口,配置了sound/soc/omap/omap3stalker.c,无法播放,进不了DMA中断,下面是调试信息,是我寄存器没有配置正确么?
aplay -D hw:0,1 -f S16_LE -r 8000 -c 1 beep.gsm 0 chunk_size 1024[ 3014.500061] configured 0 id 1 bus_id 2 sream 0 Playing raw data 'beep.gsm' : [ 3014.505798] id 2 2430 0 34xx 1 44xx 0 Signed 16 bit Little Endian, Rat[ 3014.512145] config->spcr2 560 e 8000 Hz, Mono before set para[ 3014.517883] config->spcr1 32816 ms 1024 [ 3014.523681] config->rcr2 65 [ 3014.527465] config->rcr1 64 [ 3014.530273] config->xcr2 65 [ 3014.533264] config->xcr1 64 [ 3014.536071] config->srgr2 15 [ 3014.539031] config->srgr1 1792 [ 3014.542358] config->mcr2 0 [ 3014.545074] config->mcr1 0 [ 3014.547790] config->pcr0 0 [ 3014.550750] config->xccr 4105 [ 3014.553741] config->rccr 2057 [ 3014.556915] before omap_request_dma [ 3014.560424] after omap_request_dma 0 after set params 112[ 3014.565948] omap_pcm_dma_irq writei before ioctl writei after ioctl hw_writei: frames = 112, xferi.result = 112, err = 0 writei before ioctl writei after ioctl hw_writei: frames = 112, xferi.result = 112, err = 0 writei before ioctl writei after ioctl hw_writei: frames = 112, xferi.result = 112, err = 0 writei before ioctl writei after ioctl hw_writei: frames = 112, xferi.result = 112, err = 0 Aborted by signal Interrupt... |
2 个讨论
272 浏览 1 评论
1012 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
650 浏览 2 评论
243浏览 29评论
1210浏览 23评论
349浏览 20评论
324浏览 14评论
180浏览 13评论
GMT+8, 2025-2-24 08:52 , Processed in 1.605623 second(s), Total 45, Slave 39 queries .
