CSL的宏定义中包括CSL_FMK Field Make、CSL_FEXT Field Extract、CSL_FINS Field Insert等,在cslr_userguide中这样解释,
Field make macros are used to create a register value from given input, and are written to the hardware register with the pointer to the register member in the Register Overlay Structure. Field make macros may be combined with OR operations in order to modify more than one field or the entire register. Unlike the field make macros, the field insert macros pass the register pointer as an argument, thus modify the specified register directly. Field extract macros read the register and return the value right-justified. 还是看不明白,尤其是CSL_FMK Field Make的含义,求指点啊 |
4 个讨论
CSL_FINS主要是用于Field Insert, Inserts the absolute value (val) at the specified field (field) in the register(reg). 改变一个寄存器中值。 语法: CSL_FINS (reg, field, val) 例如: Set the Enable Mode for timer 3:4 (ENAMODE34) in the Timer Control Register (TCR) to disabled CSL_FINS (tmrRegs->TCR, TMR_TCR_ENAMODE34, 0); |
586 浏览 1 评论
425 浏览 1 评论
619 浏览 2 评论
909 浏览 3 评论
709 浏览 1 评论
192浏览 29评论
1152浏览 23评论
323浏览 20评论
286浏览 14评论
135浏览 13评论
GMT+8, 2025-2-3 00:13 , Processed in 1.062882 second(s), Total 56, Slave 47 queries .
