8 个讨论
补充一下,仿真器连接错误提示: Error connecting to the target: Error 0x80002240/-233 Fatal Error during: Initialization, OCS, Control, This error was generated by TI's USCIF driver. SC_ERR_PATH_BROKEN <-233> The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. Board Name: C6747 XDS560 Emulator Cpu Name: ICEPICK_C_0 Abort: Close Code Composer Studio. Retry: Try to connect to the target again. Cancel: Remain disconnected from the target Diagnostic: Run diagnostic utility. 是不是DSP烧坏了? |
1486 浏览 1 评论
TI的DSP0049在PHS载入值跨过CMPA事件会产生丢波现象
751 浏览 0 评论
1152 浏览 1 评论
1340 浏览 0 评论
792 浏览 1 评论
582浏览 29评论
1565浏览 23评论
628浏览 20评论
573浏览 14评论
468浏览 13评论
GMT+8, 2025-7-4 12:28 , Processed in 1.233023 second(s), Total 75, Slave 62 queries .
