1.端侧AI的发展现状与挑战 AI云计算
端侧仅负责发送输入数据,并接收计算结果
优势:
计算资源集中管理和分配
单一计算可达很高的算力和精度
部署便捷
劣势:
算力成本高
流量成本高、延迟大
离线无法工作
2.瑞芯微Toybrick AI开发平台
瑞芯微官方于2019年1月15日正式推出AI开发平台---Toybrick。
硬件上,提供多系列开发平台和参考设计满足不同用户群体。
软件上,提供稳定可靠的系统平台、丰富的开发工具、AI教学案例和开源的社区
社区地址:http://t.rock-chips.com
平台旨在提供高效、便捷、稳定的开发环境,让开发者迅速上手AI应用开发,加速AI行业产品研发进程,提升william hill官网
生态。
RK3399Pro Application Processor
Core
- Big.Little architecture: Dual-core Cortex-A72+Quad-core Cortex-A53, 64-bit CPU
- ARM Mali-T860MP4 GPU, OpenGL ES1.1/2.0/3.0/3.1/3.2, Vulkan 1.0, OpenCL 1.2, DX11
- NPU: 1920 INT8 MACs/192 INT16 MACs/64 FP16 MACs , MAX to 800MHz
Memory
- Dual channel DDR3-1866/DDR3L-1866/LPDDR3-1866/LPDDR4-1866
- Support eMMC 5.1 with HS400, SDIO 3.0 with HS200
Multimedia
- 4K VP9 and 4K 10-bit H.265/H.264 video decoder, up to 60fps
- 1080P other video decoders (VC-1, MPEG-1/2/4, VP8)
- 1080P video encoders for H.264 and VP8
- Security Video Path, OP-TEE, support Widevine Level1, PlayReady
- Video post processor: de-interlace, de-noise, enhancement for edge/detail/color
Display
- Dual display engine up to 4096x2160 and 2560x1600
- Dual channel MIPI-DSI TX, 4 lanes per channel
- eDP 1.3 with PSR, 4 lanes up to 10.8Gbps
- HDMI 2.0a with HDCP 1.4/2.2, up to 4K 60Hz
- DisplayPort 1.2 with 4 lanes, up to 4K 60Hz
- HDR10/HLG display with conversion between Rec.2020 and Rec.709
Camera
- Dual 13MPixel ISP and dual MIPI CSI-2
Other
- Built-in dual Type-C with USB 3.0 and DisplayPort Alternate mode
- PCIe v2.1 (4 full-duplex lanes), up to 2.5Gbps/lane
- Embed RGMII interface three channels I2S, SPDIF output
PMU
RK1808 AIOT Processor
Core
- Dual core ARM Cortex-A35, 1.2GHz
NPU
- 1920 INT8 MACs/192 INT16 MACs/64 FP16 MACs
- MAX to 800MHz
Memory
- 32bit DDR3-1600/DDR3L-1600/ LPDDR2-1066 /LPDDR3-1600
- Support eMMC 4.51, Serial Nor Flash booting
Multi-Media
- 1080P H.264 video encoder
- 2M ISP with 13M MIPI-DSI/ 5M DVP input
- BT.1120 and UVC interface
Display
External interface
- RGMII interface
- PCI-e 2.1, dual link; mux with USB 3.0
- USB 2.0 OTG and USB 2.0 host
- Dual SDIO 3.0 interface for Wi-Fi and SD card
- 8ch I2S with TDM/PCM, 2ch I2S, VAD function
- I2C/UART/SPI interface
Package
- FCCSP420LD 14X14, 0.5mm pitch
NPU 性能
- 功耗不及所需GPU的10%
- Tensorflow、PyTorch、Caffe、MxNet、DarkNet、Onnx等,直接转换和部署
- 丰富的文档、wiki、教程、直播、示例代码;并且不停的在更新
- 相比所需GPU,成本低廉
- 高达3Tops的算力
- 可以很方便集成进任何移动设备和其他嵌入式设备
3.RK AI开发
RKNN ToolKit主要功能
- 模型转换,量化/混合量化,模型优化开关
- 模型预编译,模型分段,批量推理
- 自定义算子,模型多输入
- 多加速棒支持
- 性能预估,内存预估
- 模拟调试,量化精度分析,可视化功能
Toybrick 1808计算棒提供主动和被动两种工作模式
- 被动模式下,模型部署在上位机,计算棒是一个通用计算棒,担当AI加速器的功能;
- 主动模式下,模型部署在计算棒上,计算棒是一个专用AI应用模块;
Toybrick 1808计算棒提供全套模型保护方案
- 加解密过程均运行中TrustZone安全环境中,无法跟踪
- 让您的模型在计算棒上不用担心被盗走,每颗计算棒上的模型存储秘文均不一样,只有当前计算棒可以使用,拷走无效。
多计算棒运行
- Toybrick 1808计算棒支持多计算棒同时运行
